Question about Dewalt Tools & Hardware - Others
Dw 431 dewalt belt sander wont run got pants stuck in it
Don't think I shut it off in time was on auto high speed
SOURCE: BELT SANDER ADJUSTMENT
The Front Roller may have become Hard and the belt won't hold when you adjust just rough up the roller.
Posted on Jun 25, 2009
SOURCE: I have a Canadian tire model 55-3550-2 belt/disc
I went to a bearing/powertransmission supplier. The number on the belt was all they needed. Picked up a new belt for $6.50.
Posted on Nov 28, 2009
seanpwright
  • 2030 Answers
SOURCE: Dewalt DW433 belt sander stop working, why?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Apr 02, 2010
  • 34 Answers
SOURCE: I use Dewalt random orbital sanders regularly
The velcro pads wear out and need to be replaced periodically. You can buy new pads on-line at any Dewalt parts seller.
Posted on Aug 09, 2010
Testimonial: "Thanks much,. I suspected that that was the case but have been unable to find the replacement part. I'll try again."
SOURCE: dewalt d26451 type 1 random orbital sander. why
I have the same problem with a Porter Cable orbital sander I recently purchased. Whats happening is the sander is catching the edge of the board you're trying to sand and jerking back and forth as the sander base spins. It seems that if the board your're sanding is at least as wide as the sander base, the problem goes away, which does little good because there will be many times I we'll need to sand wood that is less in size. But you may try using a lesser grit sandpaper and see if that alleviates the problem somewhat.
Posted on Aug 31, 2010
Velcro pad that the sandpaper is fixed to has come off the plate. What's the best glue to use to re-stick the pad with?
You may try a two part epoxy, or gorilla glue. Let dry for a day or two. Sometimes 3m spray adhesive also works. Let tack before sticking together though.
Oct 19, 2012 | Dewalt DW 411 HAND PALM SANDER
Can I use the track Dws 5022 for my circular saw dw 368?
I don't believe as I think those are only meant to be used with the track saws.But you can call 1-800-4-DEWALT and find out for sure.
Aug 05, 2012 | Dewalt 59" Tracksaw Track Dws5022
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
Jul 14, 2012 | Dewalt DW 411 HAND PALM SANDER
DeWalt DW 421 palm sander. Sander was working. All at once it lost power.Did not quit, just slowed down. When I lifted it off the board it sped up,but when I tried to sand again it slowed down-lost power....
From your description it sounds like the bearings on the armature seizing up . Mainly the bearing on the bottom towards the pad. I see it a lot . It'll seem ok when turned on but under a load it can stop , slow down , smoke ....I'd start by checking the bearings. If it was the cord power would cut in and out completely. It doesn't have a variable speed switch or any speed sensors on that model. .if you have any questions feel free to ask and give as much detail as possible plz.
Oct 01, 2017 | Dewalt Tools & Hardware - Others
Dewalt DW433 belt sander stop working, why? While sanding shutters, my sander just stopped. Any fixes?
Apr 02, 2010 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
The belt slips off my Belt Sander
All sander will have two adjustments. The first is to release the sanding belt by retracting the position of one of the rollers. The second adjustment moves one of the rollers belt tension from side to side. The roller angular position is changed, sometime by a single knob or screw, and sometimes by two separate adjusting screws.
Jun 19, 2009 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
Tools & Hardware - Others Logo
63 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
