Question about HP LaserJet 1020 Printer
Cannot print with hp laserjet 1020 - cannot install printer - spooler service error message keeps coming up
  • ang7 Jan 29, 2009
    I have the same problem too.
  • Frank
    Frank May 11, 2010
    what operating syetem are you using?
  • 1,218 Answers
Check the following information........
http://www.fixyourownprinter.com/forums/printer/68459#2
Posted on Sep 14, 2010
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
I can not print on my HP Laserjet 1020. It first asks that I install a printer before printing but when I try to install the printer it says that the local print spooler service is not running. It then...
try to restart the spooler system.
to do it:
1) click start
2) on the search box type Services and hit the enter key
3) on the windows that appear after you hit enter. Find priter spooler
4) once you find it. double click it.
5) on that window. and make sure that the startup type is automatic and finally click start.
Note: if the spooler service is already running stop it and restarted back in.
hope this helps
Jan 18, 2011 | HP LaserJet 1020 Printer
HP Laser jet 1020 printer. The local print spooler service is not working. What is the problem and how do I fix it?
Google print spooler problems, there is alot of advice on google.
You need to go into services and turn it on, but you may need to alter some registry settings
Aug 04, 2010 | HP LaserJet 1020 Printer
Print spooler error
reinstal the driver with print spooler running, good luck
Apr 06, 2010 | HP LaserJet 1020 Printer
HP Laserjet 1020 Spooler not starting
First uninstal old drivers then install again.
Then go to start menu then type in run "services.msc" then press enter
then you can seee right pane check there you find Print Spooler just double click on it then set
stratup type as automatic then click on depndancy tab then set restart the service .
then apply and ok.
Jul 15, 2009 | HP LaserJet 1020 Printer
Printer Spooler Service not working
Reinstalling drivers usually fix this problem.
Reinstall drivers with printer connection cable unplugger, either using driver CD or download from the link below.
HP LaserJet 1020 Printer series - Download drivers
May 10, 2009 | HP LaserJet 1020 Printer
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
Shared HP 1020 Printing problem
Your question is not clear.
Please give some configuration info. e.g
Operating system?
Explorer Version?
Jul 15, 2008 | HP LaserJet 1020 Printer
1020 Spooler SubSytem
ok, so for this, always had an issue with this one,
so, what i did is started the spooler, the way to do this is you have to go into control panel>>>admin. tools>>> services>>>printer spooler>>> and then you have a blue icon on your left where you have to click on the button that says start the spooler, now i recommend you minimize this window,
next step is that you add the printer through the add a printer wizard in most cases the printer should already have the basic driver installed into the computer. and way to add it to to start the add a wizard, click on add a port make sure the box where it reads plug in play is unchecked, so the only icon you have checked is the local port, next you choose the port that is usb001 from here you choose hp>>> then laserjet 1020, let the printer driver install and finally your done.
Jul 09, 2008 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
171 people viewed this question
Seeker5211
Seeker5211
