Question about Canon Rebel XT / EOS 350D Digital Camera
Dust in lens
I seem to have some dust just underneath the front lens element on my 18-55mm EF-S. Is there a (safe) way to remove this to get the dust out?
    Genius:
  • 2,985 Answers
Not by a user This seems to be a faulty item so Canon Customer support should be advised.
Posted on Jul 22, 2007
Real hard to see & not focused 5 feet in front of whatever trying to look at.
Try this, take both lens out. All you have to do is just unscrew the lens. Use a very good optic lens clean with anti-static charging elements in the clearner. Only remove lens in a room semi free of dust, mites--little monster that live in the carpet, flaky skin, pet hair, etc. If it is dust inside of the NV devise, use a computer air spray to clean the inside. Assembly in reverse order. stewbison
Aug 06, 2011 | Night Owl Optics Explorer NOCX3 Monocular
Error 99 on canon 300d
Canon's error 99 is a catch all for several things the short answer is an electronic connection. Something isn't making contact and the first place to go is to the "gold" contacts between the lens and the camera body. Make sure the camera is off and remove the lens, place the camera lens side down on a clean dust/lint free surface or put a body cap on. Take the lens and holding as vertical as possible with the gold contact points down use a soft rubber red pencil eraser to lightly clean the contacts. You can remove any rubber dust and partials with a lens cleaning cloth NOT TISSUE. Make sure the area is clean of lint and dust, place the rear lens cap on or stand the lens up on a clean dust and lint free surface. the camera is a bit more tricky as you need to clean the contacts inside the mirror box. Hold the camera as best you can face down and again use the pencil eraser to lightly clean the contacts. Holding the camera as mus as possible lens side down. This will minimize any dust, dirt or lint getting into the camera body and eventually ending up on the sensor. Remove any rubber dust with a lens cloth not tissue and don't use any liquid, don't use a puffer either all that will do is drive dust partials into the camera. Once that's done install the lens, next remove the battery and do the same cleaning trick with the battery contacts, if you have a battery grip do the same thing. Okay now check out the camera if everything is go and works then you are good to go. If not then I would suggest doing a camera firmware update, all updates can be found on the Canon web site they are free and will correct any issues your camera has with the internal programming which may also be the cause of your error 99.
Jan 11, 2011 | Canon Digital Rebel / EOS-300D Digital...
My lens locked suddenly Canon EF-S 17-85mm f/4-5.6 IS USM Lens on a 20D body
Possible power problem make sure the camera has sufficient battery power and is functioning as it should (less the lens) if this is okay then the problem is between the lens and body gold contacts. It's a quick and easy repair you can do yourself. Shut the camera off remove the lens and put the body cap on the camera if you don't have a body cap place the camera on a clean lint free surface like a glass table or counter top. Use a new clean red pencil eraser to gently rub the gold contacts on the lens. Hold the lens as vertical as possible when you are doing this to minimize the rubber dust getting into the rear lens element. Clean the area of rubber dust with a puffer blower or lens cloth not a tissue. Set the lens down on the clean lint free surface and gently clean the gold contacts in the camera body keeping the camera lens mount down to minimize any rubber dust from getting into the sensor area. Clean the contacts with a lens cloth only do not use a blower/puffer, re-install the lens and it should come on. When installing the lens make sure it makes a solid click and locks securely in place.
Jan 06, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
How to clean the focusing lens?
First question: where is the dust?
If the dust ist outside the cam: no problem. Try a soft brush and remove bigger particles, then take a thin microfibre cloth and clean the dust film on the lens. Be careful - every sand particle scratches the coating, so use the brush!
If the dust is internal it's more complicated.
May be the dust is on the focussing screen. If you dismout the lens, there is a litte lock on the top inside the cam. Do not open without having special tool. Each fingerprint on this little plastic plane is not removable. It's an extreme sensitive fresnell lens.
Don't try to clean that with cloth or brush. Only airflow is allowed.
If this dosn't help - use the Canon service or replace the focussing screen with a new one (as Example Canon EF-D).
Dec 31, 2010 | Cannon EOS 50D Digital Camera
Dust behind lens
If the dust is inside the lens, then you are unlucky. Canon lenses (except for a select number of the L series lenses) are not dust or weather sealed. So each time you work the zoom mechanism on a inexpensive EF 75-300mm f/4-5.6 III lens, the mechanism is working like a giant billows allowing air (and dust and moisture) to flow through the lens and camera body. Sometimes large dust particles can accumulate on the different lens elements, but it does not have any impact on the quality of the photo
If the dust is creating problem fro your picture get it fixed from service center i will suggest you should not try to open it
Regards
Nov 27, 2009 | Canon PowerShot Pro1 Digital Camera
Focus hutning with Canon EF-S 17-85mm f/4-5.6 Image Stabilized
I had this problem too, then my camera started getting Error 99 (there is some problem) and not working.
If you look at this website and follow the steps under Update 2
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
I think you will fix your problem. The connections between lens and camera probably have a little dust in them, use a soft rubber eraser to clean them. Make sure no dust or pieces fall into the camera or lens when cleaning!
Jul 28, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Dust inside the canon ef 24 85mm lens
CAUTION! DO NOT EVEN THINK ABOUT DISASSEMBLING YOUR LENS. In 1964, I made the mistake of doing the same thing for a single focal-length lens for my Nikon F. This lens did not even approach the mechanical complexity of a modern zoom lens. Lenses are put together like jigsaw puzzles. I removed one screw and found to go further, I needed to do another. In fifteen minutes, the lens was in 50 pieces on the table. It cost over $175 to have a camera repair man reassemble it. This was a a time when the top of the line Nikon sold for $300 vs. $5000 today. Usually dust between elements does not affect performance, but if it is degrading your pictures, take the lens to a professional. This is not a job for an amateur.
Nov 21, 2008 | Canon 24-85mm f/3.5-4.5 EF USM Lens
I have a Nikkor 18-70mm f3.5 lens which has dust throughout all the lens elements, where is the best suitable place to fix this problem
The lens has several stacks of glass, you would have to do a complete teardown to reach all of the surfaces (front and back) of each set of optics. Small amounts of dust will have no effect on image quality. Shy of having a clean room to work in, it is unlikely that you would get all of the dust out.
Aug 23, 2008 | Cameras
I have dust under outer lens on my 75-300mm f/4 -5.6 III USM
Front element? You can remove this without alignment worries. The lens zoom mechanism tends to **** in the dust.
Have a look at the front element outer ring. There are 3 black screws. Remove these using jewellers screwdriver (y'know, a very small posi-drive one!). Remove this plastic outer ring. Now you can see three small silver screws, that are about the same size - when you try to unscrew them, they just rotate...
This is as they are not screws, but as mentioned elsewhere - they are plugs (if you notice, they are slightly under the casing. Get a small flat bladed screwdriver, and gently prise them out. Now you can just drop the front element into something sensible - like a microfibre cloth (give it a clean whilst you're there.
Get a rocket blower (NOT canned air), and blow away the dust, and you can use the microfibre cloth (or similar) on the small inner front element.
Then replace the outer front element - you will see where it drops into place - there are plastic guide tabs. Push back the silver 'screw' plugs.
Then screw back on the plastic outer ring and you're done - takes 20 minutes at the most.
Jul 02, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Help.Dust under first lens layer.
Same here. dust usually doesnt show up on photos as it is out of the focal plane. Many SLR lenses have dust in them and do NOT affect picture quality. I am in the process of attempting to take one apart. I have seen a damaged one that was seperated at the first 2 joints but it was glued back. this is one tough nut! http://picasaweb.google.com/pishta68/8080lens/photo#5199141246863292738
Mar 30, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
