Question about GE GSM1800NWW Spacemaker 18" Built-In Dishwasher EnerStar Qualified - White
My detergent dispenser on my gsm1800 dishwasher won't latch
  • GE Master
  • 17,129 Answers
Click this link for tips: Detergent dispenser
Posted on Jan 24, 2013
SOURCE: dishwasher detergent left in dispenser
there is no solution for it because of its design. i have same GE and same problem. It is happening because top rack is right front of the detergent cup and it is not opening 180 degree while it is washing. it opens only 15 or 20 degree and water just doesnt get in there as much as suppose to be because only water can get in there from the bottom sprayer arm because detergent cup lid is not allowing water to get in the cup from middle and top sprayer like any other dishwasher! i called them so many times and they are just jerks! they blame anyting about my house but their dishwasher. their tec. showed up 4 times and they just keep blaming hot water temrature etc. water temprature doesnt matter if water cant get in the detergent cup, right? but they dont want to admit that because they are like programed robots to give you same answers and just blame you but GE dishwasher. please fill out complain form with Consumer Complaint Department. you should be able to find their address and web site on the internet. Please do so, maybe we can get refund or replacement or something. Never ever buy GE again. Just get a Bosch.
Posted on Apr 10, 2009
SOURCE: smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Posted on Apr 15, 2009
erpaalai
  • 999 Answers
SOURCE: Detergent left in dispenser cup
You either do not have enough water getting itno the machine or it is not hot enough. 5 years old so I would suspect a plugged screen on the fill valve.
Eric
Posted on Dec 11, 2009
heatman101
  • 43501 Answers
SOURCE: The detergent cup lid stopped
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on May 10, 2011
Daniel S
  • 4323 Answers
SOURCE: My dishwasher won't power on. Checked breaker and
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the RINSE ONLY button and hold it for 15 seconds, if it's still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 13, 2011
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
Maytag dishwasher detergent cup won't open on it's own...
The detergent dispenser is sold as a complete assembly, it's reasonably easy to replace, it just unscrews once you have removed the front panel of the dishwasher,
Mar 07, 2012 | Dishwashers
The detergent dispenser won't open and we have a housefull of guests arriving tomorrow mornng. Help! (We are using liquid detergent so dispenser is not stuck with powder.)
heatman101
Aug 04, 2011 | Miele Dishwashers
Finish dishwashing product does not dissolve
Many dishwashing detergents need a water temperature of 140 degrees to dissolve. If your water is at the correct temperature, the only other suggestion I have is to make sure the detergent dispense is not blocked by large objects such as baking sheets, frying pans etc. If the dispenser cannot open fully, the detergent won't dissolve.
I hope one of these suggestions helps you. If it does, please rate my effectiveness. Thanks.
Jun 02, 2011 | Dishwashers
The detergent flap does not open
Check the dispenser for easy close & open. Trouble could be- latch relay not getting energized- wires might have snapped - relay driver - command not reaching from the controller etc.
If you check all the points you will get an idea. I feel micro-controller may not have any problem as other cycle is OK.
Further assistance contact the authorized service center.
May 22, 2010 | Miele 24 in. G665 Built-in Dishwasher
GE GSM1800NWW Spacemaker 18" Built-In Dishwasher EnerStar Qualified - White Logo
110 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
