Question about Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump 3/4-JET
3/4 HP shallow jet pump,runs and won't shut off,and will not pump,water through it..what's wrong??.
I have a 3000 gallon water tank outside filled up.,and it is hosed underground into the basement.from there it is connected to,the pump..all was fine and well,until this afternoon..the pump keeps running,and no water is being pumped.,but with the pump off I have good pressure..it runs throughout the Ouse..,but my up p isn't pumping it anymore,I don't know why..it is the Impeller..gone bad??...Thaks."
3 Suggested Answers
  • 512 Answers
SOURCE: I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Posted on Sep 16, 2012
hunter19_46m
  • 7482 Answers
SOURCE: I have a utilitech convertable pump. It is used as a shallow well pump at the moment. It worked fine untill last week, the hot water tank went bad and we replaced the tank and all the above ground li
Hi mid_age_elf
Your problem is that your "water bound"...
Your water tank must have a cushion of air for the pressure switch to work properly.
Turn off your pump and drain about 1/3 of the water from your tank.
Once you have an "air cushion" the pump and switch will work properly.
You can also add air pressure using an air compressor and an air valve installed on the top of your water tank or maybe on the side or bottom of the tank.
You would put air into the tank until about 1/3 of the water is gone replaced with the air.
Once that is complete your problem will be solved.
Please take time to rate me
Bud
Posted on Oct 25, 2012
I have a 36 gallon utilitech water tank hooked to a 1/2hp shallow well jet pump my pump runs constantly and I think it's because my tank has no water in it any help would be greatly appreciated
do you have a pressure tank or what, are you doing a gravity type deal with a pump to back it up, all pumps need pressure tank too. or your pump will constantly be on or your tank fill hole is not tight a pump is designed to trip the breaker if it wired direct, if it is not wired direct like wired to an extension cord, then who knows what it will do burn up I imagine if it is constantly going on without water pumping thru it need more details
Nov 17, 2015 | Jet Plumbing
Why does the pump lose pressure? there are no visible leaks, of water or air
for the pump to lose pressure there has to be a leak somewhere please check and make sure you have a one way valve on the bottom of your jet pump that will not allow the water to run back into the well
Nov 29, 2014 | Utilitech 1/2-HP 9-GPM Shallow Well Jet...
Once the water is shut off the pump keeps running
the pump is controlled by the storage tanks pressure switch , if it continues to run well after the pressure tank has refilled with water , either the switches manual override has been activated (lever) or its defective or blocked off with mud
Jun 27, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Very low water pressure and excessive pump running
Clean electric switchcontacts with crocus cloth. Adjust higher cut in pressure on this switch.
Apr 12, 2014 | Wayne WATER SYSTEMS SWS50-12P 1/2 HP...
I have a Mastercraft1/2 HP self priming Shallow well jet water pump, the water fell below the intake in my well and I quickly noticed and turned off the pump. We had water delivered and I'm not su
If water is back up above the intake, it should prime itself in a few minutes. As long as you don't let the case get hot to the touch it should be okay to run dry.
If it fails to prime and pump up pressure, you may have to prime it.
Oct 20, 2012 | Plumbing
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Do I have to hook my tank to draw water from my well?
A bladder tank is designed to give a certain amount of gallons of "draw down" before the pump turns on. The pump will work with or without a bladder tank but will come on every time water is used. Well pumps (Jet or submersible) can run for extended periods of time without causing harm to the pump, but a pump that turns on and off constantly will eventually burn out because it is so hard on the pump.
Jet pumps need to keep "head pressure" to efficiently create the vacuum necessary to draw water from the drop pipe, this is partially what a well tank does.
RJ
Feb 12, 2011 | Flotec Corrosion Resistant Shallow Well...
I have a 1 hp ace pump on a 30 gallon bladder tank the pressure switch keeps clicking off and on until the switch burns up have replaced 4 times in 2 months have adjusted switch until pressure is very low...
There are tow screw adjustments on the switch. One is the high shut off and the other is 'differential'. This is the one you need to adjust. It gives the 'window' that the system needs 'between' on and off.
Aug 30, 2009 | ACE JET PUMP For shallow well
Shallow well pump cycles on and off quickly? Stays on while water is running than shuts off when valves are closed.
Do you have a tank in this system? If you don't, this is the way the well pump will operate.
If there is a tank, it will have a pressure switch on it which controls the pump -- it'll cut the pump on when the tank pressure drops to 28 psi, and cuts the pump off at 40 psi.
If you have a tank, the pump behaving as you describe indicates there is something wrong -- need more info.
May 05, 2009 | Flotec Corrosion Resistant Shallow Well...
Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump 3/4-JET Logo
61 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
