Question about Toshiba Satellite A135-S4527 Notebook
Internet card and sound card not recognised on toshiba laptop
We recently had to replace the hard drive on our toshiba laptop because of coffee damage. the laptop runs fine now with the exception of the internet /ethernet card and the sound card. the laptop keeps saying that these are not installed. I would replace them and reinstall them if I knew what parts I was looking for. But I dont. I have taken the laptop apart a few times to fix it and clean the heat sink and replace other parts. But I simply do not know which parts i should replace or if there is another way to fix the internet card and sound card problem.
  • 1 more comment
  • Amie Sugat Jan 27, 2009
    its a Toshiba satellite (8100/81005 ??). I am not so worried about the sound card as I am the internet. I need internet to run my business...
    its a satellite A100/A105 series
    I could not find a diagram of the internal hardware on the Toshiba website.
    Champion:
  • 203 Answers
Go to your manufactor website page find suport page and get your driver's from there. if u put your brand name o laptop it will be more helfull for all
Posted on Jan 27, 2009
Toshiba DWC120 2TB Harddrive not recognised
Before connecting anything to an USB port you need to install the software for the device. Then you can connect it.
But when you have an old laptop it could be it can't handle the 2 TB.
First install the software that came with the drive. Then see if the laptop can handle the 2TB.
Dec 20, 2013 | Toshiba 2TB Desktop External HDD Hard...
My Toshiba px1394u-3g50 external hard drive is not working, light flashing and not recognised
Try connecting the hard drive to some other laptop and see if its getting recognized. Issue could be either with the hard drive itself of it could be with the usb port which you are using to connect the hard drive to your laptop.
Jan 17, 2012 | Computers & Internet
When the laptop is turned on, it only gets to the logo page which says In touch with tomorrow: toshiba. It does not boot at all, and only gives the options of hitting f2 or f12 for booting options, neither...
The problem is not with the battery or the AC power supply
( I assume you tried pressing F8 safe mode before the loading screen appeared?)
Get into the Bios by pressing ( I think its F2 or F10) as soon as the laptop starts up (before loading screen).
Check in the main page, that the laptop "sees" the hard drive. If it does not, then the hard drive has failed. (you can check this by substituting another drive and seeing if the laptop recognizes this in the Bios).
See also that the DVD rom is recognised
In the Boot order screen, check that the boot order is set to 1st boot DVD/CD drive and the 2nd is set to hard drive.
Using a windows install disc, boot to CD and see if windows wants to install (if the hard drive is recognised in the Bios but has an internal fault, Windows will tell you before it installs the OS)
If the drive IS recognised and windows installs ok, let it go to the 2nd repair option, where it looks for previous installations of windows and let it repair the system (your files will not be wiped)
If Windows reports that there is no HDD, then you should try a spare HDD and see if it will format and install .
At best, it sounds like the MBR has been corrupted, in which case the over the top install above should fix it, at worst, the hard drive has failed and will need replacing
Jun 19, 2011 | Toshiba Satellite A215-S4807 Notebook
I recently had my hard drive replaced/upgraded on myToshiba P105 S6104 on a Windows XP SP3 system. Now the sound doesn't work through the computer speakers or headphone jack. How do I get the sound to...
go into the device manager via the control panel, (or F1 => "device manger") find your sound card and replace the drivers with factory drivers available for download from your manfactures website.
Jun 11, 2010 | Toshiba Satellite P105-S6104 Notebook
Problem with Toshiba MK8025GAS hard disk
check the connection of the hard disk and make sure the cable is properly connected. also chek the setting on the CMOS. it should be recognised at CMOS level, make sure it is set on auto
Aug 21, 2009 | Computers & Internet
Got a new hard drive installed and now there's no sound.
first you need to check your device manager to
see if you have any devices with a "!"
if not when your step dad took it apart
he might have not reconnected the internal speakers.
If you have some headphones handy connect them and see if they produce sound .
Here is a link to various drivers for your laptop
Mar 27, 2009 | Toshiba Satellite A105 Notebook
Windows XP does not recognise hard drive
Try pressing F6 to install special driver while booting the install CDROM
Mar 27, 2009 | Computers & Internet
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
I guess you put the SD adapter into the card reader right out of the box? You first may have to partition/format it after unpacking it. Under WinXP I can recommend an utility "DiskPart" which you can start from the command prompt (Run... -> cmd). For further instructions (if it sounds to you to be the problem ) contact me again.
Dec 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Toshiba Satellite Pro L20 fitting DVD Writer
Try to find the correct driver from Toshiba for the driver, your current one wont work for the dvd.
Mar 27, 2008 | Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
