Question about Honeywell HZ-680 Oil Filled Radiator Heater
I need operation instructions for HZ 680
Purchased used heater and recieved no instructions as to what the switches indicate when lit. Please help for efficient and safe usage.
  • rjil2006 Apr 06, 2009
    I need a manual for HZ 680 heater.
I happened to be sitting here with a manual looking for a retail price so I could price it for a yard sale on Sat. I could email a scan (It's not lenghty)
Posted on Jan 28, 2009
Model hz709 manual
Was there any physical damage to the heater when it fell over?
The HZ-709 has safety features that might prevent its subsequent operation.
1 - It has a tip over switch but the heater should operate normally when it's upright again.
2 - A thermal cut-off fuse will permanently shut down the heater should it operate at a higher than normal temperature. Was it operating when it fell over, or could it have overheated?
If it's none of those, try contacting the manufacturer Kaz directly by email, Facebook, Twitter, etc. as the HZ-709 has a 3-year warranty.
Digital Electric Radiator HZ 709
Jan 31, 2014 | Honeywell HZ-709 Oil Filled Radiator...
Need a switch for a honeywell HZ680 oil filled heater
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 10, 2011 | Honeywell HZ-680 Oil Filled Radiator...
I have a Honeywell Oil filled heater, HZ 680 series. When both switches are turned on, they light up but there is no heat. Also, a funny smell then the switches automatically turn off. Is there anything...
These heaters last about three years,and are throw aways,unless you have some in the ole shed like I do.Checking the switches is the first thing to do,remove them to see if they are burned up on the other side where the connection is.If they are,that could be the smell,or the thermostat is melted down,and smelling,again,throw away,,or save it,and buy a new one,and you will have parts for when it goes out,if the switches are melted down,a compatible switch,if found,can be replaced in the heater,but something made the switches melt down,most likely a heating element in the tanks,non replacable.
Jan 05, 2011 | Honeywell HZ-680 Oil Filled Radiator...
Our HoneywellHZ-690 oil - filledheater is leaking and I want to know if it is safe to use.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
Dec 03, 2010 | Honeywell HZ-680 Oil Filled Radiator...
Heater is clicking on and off and on and off every minutes when both switches are on
Pl check the manual. There are certain heaters designed this way! I can not comment unless the manual is read.
Sep 23, 2010 | Honeywell HZ-680 Oil Filled Radiator...
All of a sudden the heater is not heating up. The
make sure the thermostat dial is not turned all the way down. The red rotary dial, set it to 6.
Dec 15, 2009 | Honeywell HZ-680 Oil Filled Radiator...
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual that you need. Hope this helps. If you need anything else, let me know.
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
NEED NEW POWER ON SWITCH
email me at hokrazees85@tmo.blackberry.net
I have the part you need
Trevor
Jan 13, 2009 | Honeywell HZ-680 Oil Filled Radiator...
Instruction Manual for HZ-705
HZ 709 This model# is the closet we'll are gonna get unless I can find my manual and get it scanned. Scroll down to page 4.These instructions will give you a basic idea how this heater works. Good Luck :-) http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
Jan 02, 2008 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Honeywell HZ-680 Oil Filled Radiator Heater Logo
421 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
