Question about Moen Home
M5305 doesn't fill up tank - Moen Home
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: water keeps running, toilet not
Hi snowjobs847...
Try resetting your float level to a lower water level in the tank, the extra pressure put on the seal may make it reseal.
If the above did not work:
You need to replace your "ballcock"...the ballcock (inlet valve) is non-repairable, has to be replaced with a new one if you cannot get it to stop leaking.
Please take time to rate me
Posted on Sep 04, 2011
Toilet Tank Fills Doesnt stop filling
You can get a new seal at almost any hardware store. Turn the water off. Just give the grey cap about a 1/4 turn and it will come off. Pull the black rubber out and put the new one in. The rod inside the ballcock eventually pierces the rubber diaphragm. The cost is about $2.
Aug 21, 2013 | Home
Tank isn't filling up
Make sure your hose doesn't have any leaks. Also, check the check valve for dirt or wear. Your pressure regulator could also be stuck in the blow off position.
Feb 02, 2012 | Porter Cable C2002 150 Psi 6 Gal...
I have an infrared grill... sometimes it just doesn't heat up that well...Other times it goes to 600 degrees... I think when the gas goes below three poounds there's a problem, but I also have it...
More than likely it's over fill protection valve (OPD) in the gas tank valve. It will affect the grill's regulator when the tank valve is opened to quickly. It should always be opened VERY, VERY Slowly (Slow motion, slow).
Hope this helps you and thanks for choosing FixYa.
Sep 21, 2011 | Char-Broil CharBroil 4637318 Grill
Water keeps running, toilet not shutting off totally, tank will fill then we have to pull up float and hold it a while to stop water, doesn't overflow, just keeps running, doesn't shut off...
Hi snowjobs847...
Sep 04, 2011 | Home
Car is burning lots of fuel, doesn't always start on first crank, and doesn't seem to have as much get up and go..especially around 40 mph
oil change is ok air filter clean plugs ok no check engine on using ac more often or injectors are dirty put a injector cleaner in the tank at next fill up
Aug 13, 2011 | 2007 Kia Sorento LX 4x4
I fill the tank up, but it seems too light to be full, so I drain it and it only has about 1 gallon if that in it. Whats wrong?
How are you filling the tank, and is this in an RV or what? Open pressure relief valve when filling and when water comes out pressure relief valve, you know your close to full. If it doesn't come out there when valve is open, check for by-pass valve(s) in wrong position and not filling the tank.
Aug 11, 2011 | RTO Atwood Water Heater - 6 Gal LP
I don't have an owners manual for my 1999 dodge
20 gallons, (in the tank,, less than a gallon in the fill tube
Jul 21, 2011 | 1999 Dodge Caravan
My flapper was leaking, so I replaced it. Now, when I flush, the water leaves the toilet bowl, fills the bowl, and wants to flush again. All the water wants to leave the tank, but the toilet doesn't...
Reset the fill valve so that it does not fill the tank so full....this will be easier then trying to find a different flapper that will drop down faster, which is the only other thing you can do...
heatman101
May 15, 2011 | Plumbing
Can't fill gas except very slowly. Pump kicks off even at slowest filling. Someone suggested evap canister??
Usually a bad vent valve, unless your truck doesn't have one. If it does, the vent valve is near the tank attached to a hose from the tank or filler pipe. It has an electrical connector and another hose going to the canister. Sometimes it's mounted to the canister. The valve is usually default open and allows vapors to go from the tank to the canister. Take your off to see if it's open. If you need specific instructions, please reply with your model, year, and engine info. If not, replace it. Please let me know if you have questions, and thanks for using FixYa.
May 02, 2011 | GMC Sierra 2500HD Cars & Trucks
Home Logo
27 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
