Question about Garden
Dose anyone know hot to start a polaris d bat quad , it will not fire up when blue smoke
4 Suggested Answers
  • 93 Answers
SOURCE: polaris quad screen shows a wrench and say service
It will come on when ignition is on because it is diagnosing the system. Should go OFF when unit is started or moved.
Posted on Oct 01, 2009
kel1guy2002
  • 3740 Answers
SOURCE: my 2002 polaris trailblazer wont start it has fire
If you have oil and gas and it will fire then try a new plug. A bad plug when removed will appear to be fine but under compression can fail.
Also try a splash of good gas in the throat of the carb or intake (if fuel injected) with a new spark plug. My bet is it fires just fine.
If this is a fuel injector type engine you could have a bad injector control unit or a clogged injector.
If it fires with gas in the intake manifold then suspect carb or injector system. (which ever applies)
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
  • 58 Answers
SOURCE: 2012 Polaris Ranger 500 smoking, less when warm
sounds like comutator needs replacing
Posted on Oct 05, 2012
2007 Polaris phoenix 200, has new fuel cleaned carb,good blue spark,fires don't start or run,plug lil wet but not flooded or soaked
If you have spark at the right time, fuel, air.... you might try a spray of staring fluid. I would then check the compression. If it is too low it will not start.
Mar 31, 2017 | Polaris ATV
I have a 2010 polaris iq touring 4 stroke turn the key and nothing happens not even a try what could it be
Dead battery .,? Pull charge,.,or replace.,.go from there .,. First Try jumping it to even see if it fires if it dose then you know u need new battery...
Dec 19, 2016 | Polaris ATV
Replaced battery and solenoid, not it wont start and smoke rolls out from under the tank/console area, what should I check?
The startr motor is fried or u hav worn cables w alot of resistenc. Fixit bfor car fire
Oct 23, 2015 | Polaris ATV
Looking for polaris d bat 400 1985 diesel manual
which cables go to battery on polarus d bat quad
Mar 20, 2011 | Polaris ATV
2004 Quest 500--Starts fine. Will run for about 1/2 hour. Starts to sputter and back fire then stops. I remove plug and its black. Change plug and starts and runs as new. Then it repeats itself again....
The problem would appear to either be with the mixture or with the head. Too rich a mixture (too much fuel) will cause black plugs - when you take them out do the engine and plugs smell of petrol? You need to adjust the carburettor. Mark where the throttle screw is to start with and then slowly screw it (in - I think) to reduce the petrol flow.
The other alternative is that their is a problem in the head. Does the engine blow a lot of blue/black smoke out when it is hot. If yes it means a full engine strip down!
Mar 03, 2011 | RTO 125cc Full Size Adult Quad ATV
Polaris quad screen shows a wrench and say service
May 16, 2009 | Polaris ATV
Snowmobile
First off, you need to put this under a different product.
For another, check the battery before you ask dumb questions!
Most efi sleds use a battery. Check it.
Feb 01, 2009 | Polaris New Genuine Polaris Snowmobile...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
