Question about Bubble Magic 20 Gallon Mini Washing Machine
Bubble magic washing machine drains slowly
The machine drains in a trickle; both gravity draining or pumping
How to drain water from my lg WFT75A31EP washing machine after washing the clothes?
If the drain pump is faulty and you are unable to pump the water out of the tub, simply take the drain hose and lower it into a container to catch the water which will be drawn out by gravity.
If this fails, check the drain hose for foreign materials clogging it.
Nov 16, 2015 | LG Washing Machines
Whirlpool neptune mah3000 wont drain , I can hear it and see small trickle of water. My wife thinks she lost a small nylon stocking. Eventually I get nd code. Even when I lay the hose down I only get a...
You are going to have to open up the machine and check you drain pump. If there is something blocking the intake of the drain pump it should be easy to get out, but if it has shredded in the pump, replace the pump.
Jul 17, 2011 | Washing Machines
Door locked with clothes and water trapped in side. Drum moving slowly and "clunking"
If you remove the drain hose from sink, drop it down low into a bucket,this will gravity drain and allow you to open the door to remove clothes, clunking could be object stuck in the drum or the pump even,at worst Drum bearing failure..Good luck
Apr 01, 2011 | Zanussi ZWF1430W Front Load Washer
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
Kept flashing f21. I hit stop. Now the door won't unlock.
You did not mention whether the washer actually pumps the water out of the washer when you are getting the F21 code. If the washer pumps the water out okay, then the pump and drain system are okay.
Excessive suds can prevent the pump from evacuating the water properly and will sometimes result in an F21. When the suds dissipate, the washer will then be able to pump out the water. Look for this type of condition if necessary.
If the drain pump runs but the washer will not drain the water, see if the washer will gravity drain. Pull the drain hose out of the stand pipe or sink and place it in a shallow pan at floor level. If the washer will gravity drain okay but will not drain when the drain pump is running then you will likely need to replace the drain pump.
If the washer will not gravity drain, then you still have a clog somewhere in the drain system. If you have not pulled the hose between the tub and the pump, then you could have a clog in this area.
If the washer does drain normally, then you could have a failed pressure switch, air pressure hose problem, wiring failure or a failed control board.
Jan 06, 2011 | Kenmore HE2 Plus Front Load Washer
Washing machine wont drain
Hello,Do you hear the pump running when it is supposed to? If no and the machine is still under warranty, take advantage. If you do hear the pump running, but nothing comes out--lower the drain hose down near the floor to see if it will gravity drain into a bucket or pan. If it drains, then the pump isn't moving anything even though it is turning--it must be replaced. If it doesn't drain freely, then something is blocking the drain--a pinched hose either to or from the pump, or maybe a stray sock blocking the outlet from the outer tub.
Thanks
May 19, 2010 | Tecnik TKL9260 Front Load Washer
Getting an OE error code on WM2016CW washer. Have checked the hose for bends and emptied the drain filter? Still getting error message?
OE error is because the machine is slow to empty..Check and see if the machine is draining slowly or not at all..Sometimes coins get caught in the impeller itself...The type of pumps used on LG machines can fail because of muck and detritus getting behind the impeller back plate..Dismantle pump. Mark pump and body to help with re-assembly. If impeller comes out of motor body, you'll have to feplace the pump motor..Universal pump motors are generally ok.. Gravity drain to empty machine.. Good luck....Nomess
May 19, 2010 | Washing Machines
My lg washing machine is a semi automatic model 6.2 kg . water is not getting drained don't know why?
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Apr 09, 2010 | LG Washing Machines
My washing machine wont drain water
Do you hear the pump running when it is supposed to? If no and the machine is still under warranty, take advantage. If you do hear the pump running, but nothing comes out--lower the drain hose down near the floor to see if it will gravity drain into a bucket or pan. If it drains, then the pump isn't moving anything even though it is turning--it must be replaced. If it doesn't drain freely, then something is blocking the drain--a pinched hose either to or from the pump, or maybe a stray sock blocking the outlet from the outer tub. The last item usually isn't considered a warranty problem. Hope this helps!
Mar 28, 2010 | Tecnik TKL9260 Front Load Washer
Bubble Magic 20 Gallon Mini Washing Machine Logo
43 people viewed this question
Top Bubble Magic Washing Machines Experts
Are you a Bubble Magic Washing Machine Expert? Answer questions, earn points and help others
