Question about Dell Latitude D600 Notebook
My latitude d600 will not start.
My dell latitude D600 will not power on and the green light on the adapter goes out when plugged into the computer but works well on other computers(same model) I have tried on battery alone with the same result.
What may the problem be?
    Problem Solver:
  • 13 Answers
Is the connection on the Laptop loose? Most power connectors are soldered onto the motherboard and are notorious for becoming loose. If the connector is loose you it may be shorting out the adapter. I would have a professional look at it before plugging the adapter back into it. If you are shorting out the adapter it could present a fire hazard. Most laptop repair companies will resolder the connector for around a $100.
Posted on Jan 27, 2009
  • 31 Answers
Your power supply is bad.
Posted on Jan 31, 2009
My dell d600 will run on batteries ok. I own 3 ac adapters and all flash green when plugged into computer. I removed battery and it still won't power computer it's like something in computer is shorting...
Most likely, if 3 different known good AC adapters will not power the system, then there is a problem with the DC in power jack on the motherboard. The easiest fix is a motherboard replacement (about $100 on ebay)
Dec 19, 2009 | Dell Latitude D600 Notebook
Dell D600 Power Up Issue
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
Sep 08, 2009 | Dell Latitude D600 Notebook
No power when cord is plugged in
A possible short on the power input plug at laptop end
Sep 07, 2009 | Dell Latitude D600 Notebook
I have a dell laptop latitude d600 and it will not turn on. the power supply light is on and when u plug it into the computer it turns off and the computer will not turn on and the power supply light goes...
There are 2 possible points of failure here. The AC adapter or the Motherboard. If possible, try a different D-Series AC adapter from a known good system and see if there is any change. Also test your adapter on a known good Dell if possible. If the adapter is the fault, then replace it. If a known good adapter has the same issue, then the motherboard is at fault and needs replacement. Motherboard are about $100 on EBay
Jun 04, 2009 | Dell Latitude D600 Notebook
No power to dell latitude d600
have you checked your ram? remove it and see if it powers on and qickly turn off. if it powers on replace ram after shutdown. if problem not fixed coud be cpu problem or mobo.
Jun 02, 2009 | Dell Latitude D600 Notebook
+-+-+ Green LEDs on Battery of Latitude D600
On off on off on means the battery has failed and needs to be replaced. With the battery removed, the system should run on hte AC adapter
May 16, 2009 | Dell Latitude D600 Notebook
Laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Mar 02, 2009 | Dell Latitude D600 Notebook
Mains switch on
some shortage inside the computer, go for technical assistace from qualified technician
Nov 04, 2008 | Dell Latitude D600 Notebook
Dell D600 laptop
Try pulling out the battery and the plug the adapter into the laptop. See if you can power it on then.
Mar 31, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600
remove the battery and adapter..keep the power button pressed for 10-15 seconds....again plug in the battery\adapter and turn it on...
Feb 08, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
183 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
