Question about APC Smart-UPS 1000VA UPS System
POWERWARE 9125 BYPASS LED ON - APC Smart-UPS 1000VA UPS System
MY UPS IS NOT GIVING SUFFICIENT BACKUP WHAT SHOULD I DO?
This appears to be an older model UPS, and it might be time to think about purchasing a new one, especially if this one has been through several outages/surges. Once a UPS like this is surged, the protection fuses can blow. In addition, if the battery has had a long lifetime it might be worn out.
Mar 16, 2011 | Powerware 9125 1250VA (051460085501) UPS...
I, Bypass battery and nomral mode are blinking UPS bypass unavailable. I need help please
Here is the link to all of the documentation:
http://powerquality.eaton.com/Products-services/legacy/9125-info.asp
You can also contact Eaton. Eaton bought Powerware 5-6 years ago.
Toll Free: 1 800 356 5737
E-mail (Hardware): SinglePhaseTS@eaton.com
Mar 01, 2011 | Powerware 9125 UPS System
UPS will not power up.
replace the battery of your UPS .
Dec 18, 2010 | Powerware 9125 UPS System
I am looking for schematics for a Powerware 9125 6000G.
This may not help, but it is the best I can find:
http://www.hmcdistributor.com/web/wp-content/uploads/2007/07/powerware-ups-9125-users-guide-5000-6000-va.pdf
Mar 11, 2010 | Computers & Internet
The bypass mode indicator is blinking, what do I need to do?
my be its indicating that the bypass mode is not available because power input is not of range that the ups is designed to take, check the ratinng of ups and use amultimeter to check whether the input matches the input. also depending on the type of ups this could be a code for a fault. please avail the ups type.
Oct 13, 2009 | Powerware 9125 UPS System
Powerware 9125 power problems
Most modern ups units will not start at all without the batt, so disconnect the extra packs beg, borrow some new or old good batt blocs same spec as the original internal ones, as this is just a test any set of batts that is just ok will do.
fit them to the ups unit and see if it will start. if it will then you will need to replace all the batt blocs in the whole system.
If it does not start then the ups is faulty.
If you are not happy fitting /working with batteries then get a tech to do this work for you, batteries are very dangerous, they are always live and need to be handled with care at all times.
Hope this helps, thanks for asking FixYa
Jul 28, 2009 | Eaton Powerware® 9125 UPS System
Battery test failed
1. Replace the batteries because they NEED to be replaced. It is not wise to ignore alarms.
2. Remove the battery backups. Without good batteries they are useless so why waste your time silencing alarms. Just make sure that the computers are plugged into a surge-protected outlet and you save your work frequently when there is bad weather.
FYI: Retail UPS batteries are only good for 2-3 years and high-end commercial batteries are only good for 3-5 years.
I hope this helps.
Jul 20, 2009 | Powerware 9120 UPS System
Attaching a generator to Powerware 9120 UPS
Power ware has a powerpass bypass switch for $200.00.
There is two inputs on this bypass switch. One for power, and one for the generator.
One ouput for your UPS. There you have it... There is your soluiton. I might add one other thing called a Power Guard, PMM117, to monitor the power of the backup generator. The time delay of this device will prevent over current from cooking your UPS power supply.
They also have a Hardwired version that is more expensive for you 5, 6 ,10KVA UPS. So a automatic bypass switch is what you need.
Jul 15, 2009 | Powerware Invensys 9120 Model 1000i...
Bypass alarm flashing on a Powerware 9125 UPS
it is possible the bypass alarm is flashing because the i/p and o/p are not within range to switch without a break.
they need to be nearly equal in volts and freq so when the ups switches the ups o/p is continuous.
you should be able to check this with your ups software.
Mar 26, 2009 | Computers & Internet
APC Smart-UPS 1000VA UPS System Logo
22 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
