Question about Keurig Mini B31 Plus Red Coffee Maker
Our brand new keurig mini plus wont heat or dispense water
Out brand new keurig mini plus has stopped heating and dispensing any water. We have only used it 6 times, and now it wont do anything. It just sits there flashing the red light like its heating the water, then it just shuts off after a few minutes, the water is still cold when i pour it out.
    New Friend:
  • 17 Answers
I had the same problem with my Mini ! I also had this problem with my last Mini which was given to me and I tossed out. So I replaced with the new one which just went on the fritz. Called Keurig who were very helpful and told me to descale, but I explained the machine is almost new. So I prodded them for what else could cause the problem and its water that is too cold.
Turns out the problem is that I was using very cold water and the machine can sense the water is cold and will not heat. It does not heat so it wont damage the heating element. I was using 40 degree water from the fridge.
My symptoms were: I would fill it, that the blue light would flash, I would push the button, then the red light would flash and then nothing it would shut off after a while. Now with not so freezing water it works fine!
Hope this helps as I threw out a good machine because the water was too cold!
Posted on Jul 29, 2014
  • Muriah Armstrong
    Muriah Armstrong Nov 06, 2014
    Thanks! That ended up being the problem!
  • Anonymous Sep 06, 2016
    This happened in my camper, I used bottled water out of my nice cold fridge and it wouldn't work thought it vibrated something loose being on road, so Hubbie disassembled unit right before I saw this post.... Tried room temp water and worked fine. now hes trying to reassemble, What a joke! no coffee whole weekend thx to cold water!
5 Suggested Answers
  • 40 Answers
SOURCE: The Keurig is heating up the water, yet is does
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
Posted on Oct 07, 2010
  • 28 Answers
SOURCE: my keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Posted on Feb 07, 2010
  • 60 Answers
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
supernova278
  • 1932 Answers
SOURCE: I have a brand new
After heating it switches off.This is because once the water get heated up ,It activates a cut off switch which stops the heater.This is a safety feature.
Can you be specific.? shuts off in the sense.?After that you can not use at all or can use.?
Thank You
Posted on Sep 29, 2010
K75 brand new filled with water blue light flashes but will not dispense or heat up
Handle may not be completely down and make a positive contact. Open and close again, press firmly on the handel and it should start up.
Feb 01, 2014 | Keurig B70/K75 Coffee Maker
Keurig mini plus b31 only half cup of the water dispenses
Reset the out-flow and dispensing format. See Manual for instructions.
Feb 16, 2013 | Keurig B31
Just got a new Keurig mini. Plugged it in, put in the water, closed the lid, put a cup on the plate, pushed the power button, pushed the "coffee cup" button and nothing is happening.
My wife's mini single cup B31 quit dispensing hot water into the K-cup. It would go through every stage and the pump came on but no water, no coffee. Try this: unplug the unit, take the drip tray off and lay the Keurig on its back, with the top opened so you can see the dispensing probe and the rubber ring that seals to the top of the K-cup. The dispensing probe is sharp, with two small channels, one on each side. (Be sure you can spill a little water when you try this) With a kid's water blaster, or a rubber bulb, squirt water up the channels on each side of the probe. Do this a few times, then try to run it normally.
That worked for me, and loosened the few coffee grounds that were plugging the outlet.
Mar 14, 2010 | Keurig Coffee Makers & Espresso Machines
I have similar problems to a number of others here do- the water does not always heat up, it stops dispensing the water, it makes a loud vibrating noise, the water sprays out in all directions and it is...
They replaced my entire unit when my heater stopped working and the unit would auto power off after trying to heat up the next batch of water. I would contact Keurig and see what they will do for you.
Contact info from their website.
Phone:
1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week Fax:
1.781.245.1869 Mail:
Keurig, Inc.
At Home Customer Service
55 Walkers Brook Drive
Reading, MA 01867
Feb 06, 2010 | Keurig B60 Coffee Maker
My Keurig B60 is suddenly not dispensing water when a K-cup is in the machine. Dispenses fine with no cup in chamber.
I solved it by running the machine a couple of times without a K cup in it. The second time through, a few grinds ended up in the cup. After that, the machine works fine.
Dec 03, 2008 | Keurig B60 Coffee Maker
Keurig Mini B31 Plus Red Coffee Maker Logo
952 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
