Hi my ideal icos he24 boiler boosts up but then just cuts off again. This happens when the honeywell is asking for hot water or central heating, The boiler drops back into a ticking over mode. Thanks Jeff.
billyvangogh
  • 108 Answers
SOURCE: need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Posted on Oct 26, 2009
SOURCE: ideal response 120 seems to fire up but burner
If this an older style boiler remove thermostatwires
at boiler terminal board and put jumper between R and W, if boiler starts you have bad thermostat.
If it does not come on then it appers that you have
a problem with the spark ignition or glow coil is
bad
Posted on Jan 09, 2010
SOURCE: Ideal Mexico Super 2 CF100 boiler. The water
We have the same boiler that is still working fine (touch wood) but the water supply expansion tank as been disconnected (i don't know why) but we top the radiator system up by finding the highest point of the system (a towel radiator in the bathroom) unscrew the end and top it up by filling it with a jug, not the most sophisticated way but it works fine and has done since we moved here 6yrs ago Dave G
  • 7 Answers
SOURCE: my honeywell timer for the back boiler heating is blank
need to contact the people who worked on it yesterday to come back and look at it again because it sounds like you have no power to now.
Posted on Jan 29, 2010
  • 36 Answers
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Posted on Jan 31, 2010
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
Honeywell technical support
This boiler, from memory, has an electric diverter valve.
If the system has dirty (sludge/scale laden) water then the diverter valve may not return under spring pressure, and therefore not divert all of the hot boiler water to the hot water heat exchanger, leaving some going to the rads.
If I am right then the rads will not get fully hot.
If the valve has failed completely, or electrically, then the rads will get fully hot and there will be no hot water output (hot water will be cold).
Aug 19, 2014 | Heating & Cooling
Boiler not responding to thermostat
The thermostat controls the gas valve is this sticking open , There must be a over heat that should cut in . Rebinded ??
May 07, 2017 | Honeywell Programmable Thermostat Heater
I have a Honeywell ST499A/ST699B "Central Heating Microelectronic Time Controller" managing the operation of my house boiler. The time controls are set properly. PROBLEM: If I want either hot water or...
I have an old Honeywell ST499A/ST699B thermostat. It still works OK but when we have a power cut I have to re-programme everything. Presumably this is because the battery needs replacing. I cannot find a way of opening the control box to get into the unit to replace the battery and in any case I’m not sure if the battery is renewable?
Oct 12, 2009 | Honeywell Programmable Thermostat Heater
Boiler is a baxi control for heating is honeywell.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
Valient combi boiler is not heating the water properly
vailant boilers are one of the best on the market and should last you more than 6 years depending on installation and servicing.
the engineer you had should not have replaced the diverter valve if the boiler was firing up when the taps are opened. if you was getting luke warm water with the boiler alight it is a classic symptom of a blocked plate heat exchanger on the central heating side.
a new heat exchanger can cost around £100 depending on the age and model of the boiler.alteranatively it could be descaled but may clogg again. it would be a good ideal to fit a magna clean filter on the system to help prevent further debris if you have a dirty system .if you don't trust your engineer i suggest you ask another. find out if he is registered first and don't pay until you are satisfied with the work. if you are asking the same engineer back try and get a discount off the work as he has failed to rectifiy the original fault and fitted the wrong part due to wrong diagnostics. if he is registered you can complain to the governing body ie corgi or gas safe register.
good luck.
Jan 16, 2009 | Water Heaters
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
