Question about Thetford Norcold RV Cooler/Freezer
Norcold n811 120v heating element test - Thetford Norcold RV Cooler/Freezer
    Top Expert:
  • Thetford Master
  • 7,897 Answers
On board check 12 volt element and 120 volt element if voltage to it bad element if none bad board
Posted on Dec 13, 2017
My norcold n611vrt wont work on eletric
check electric fuse inside control box and check heating element
Jun 26, 2017 | RVs
I have a Winni Minni with Norcold refrigerator 682. I have change board and element,but its not working on electric only on gas, prpblems ?? I live in Norway.
Sounds like your selector knob may net be making proper contact with electricity. You have changed everything else. You could check power available with a multimeter to your element. If power not available to your element, back trace to source and check for burned wires or breaks in wiring.
Hope this helps!
Apr 18, 2016 | Refrigerators
Norcold 6120 gas heats and electric warmer heats still doesn't cool has no ammonia smell
Only offering I have for a consumer is to run a "highpot" test on the cooling unit. This will bypass all the controls from the board and test the function of the cooling unit. Remove the leads from the board for the heating element and connect leads directly to 110 volts. Run for 3 hours to see if cooling is stating in the freezer. If cooling detected let run for 6 hours. So on and so forth. DO NOT RUN FOR MORE THAN 12 HOURS LIKE THIS!!!!!!! If no cooling detected in the first 3 hours the unit is "stopped up" and will have to be replaced.
Oct 04, 2015 | Refrigerators
My Norcold model 663. Is not switching to AC.
Is the fan in the freezer section running?
IS the heating element on when it should not be?
Is the defrost limit switch not shutting the heater off?
Is the defrost drain /trap clogged?
Aug 21, 2014 | Refrigerators
I have a Norcold 323 Refrigerator in a camper that will not cool when operating on AC but does work on gas, ( I cant test the DC as I dont have a 12 volt power sorce). After running in on gas for a while...
the unit runs on gas(LPG) so the unit is operational
by ac I take it you mean mains power and by dc you mean 12 volts it being a 3 way cooler
you cannot "jump start" a gas system so I am a bit lost with that statement
check the heating element in the unit for continuity as both the mains and 12 volt power only heat and element that boils of the coolant liquid in the system the same as the lpg flame does
it could be a relay problem for the electrical part
May 26, 2017 | Thetford Norcold N323 1.7-cu ft 3-way...
I have a Norcold 9000. It works fine on electric & propane, but will not keep cool on battery power.
Have you tested for 12 vdc at terminals where element is connected to board? If yes, and 12vdc is present, then I'd pull element out and bench test it carefully. Just let it cool down, and attach 12vdc from a battery or other source to it and see if it heats up. Careful not to burn your fingers or hand when feeling outside of element for heat. If no heat felt, replace it.
Jun 01, 2010 | Thetford Norcold RV Cooler/Freezer
I have a norcold refrigerator in my rv. it works
Check if you are getting voltage to the heating element should be 120 volts
Apr 27, 2009 | Thetford Norcold DE0051 Refrigerator
Norcold freg.dont know model but its in a 1999 sportsman rv. will run on gas. But will blow fuses on 110. It will run for a few hours sometimes but often just keeps blowing fuses.
Heating Element is shorted out, circuit board is bad, or you have a 110 volt wire shorted to ground. If it does operate for a few hours the latter is not likely. Do an ohms reading on the heating element, should be 35-45 ohms. If it is infinite the element is shorted
Mar 18, 2009 | Refrigerators
Norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Thetford Norcold RV Cooler/Freezer Logo
130 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
