Question about Water Heaters
Fault f46 glow worm boiler
What doesn't mean?
3 Suggested Answers
  • 659 Answers
SOURCE: Glow worm 45 60 boiler
You have to have 12" clearance on all sides.
Posted on Apr 03, 2009
mrhotandcold
  • 248 Answers
SOURCE: Combi boiler Glow worm 24ci digital fault
refere to glowworm expert advise
Posted on Oct 12, 2009
Glow worm 45-60 standing boiler making banging noises when in operation
The noise you refer to is called Kettling, it is caused by the hot water in your boiler not being able to leave the boiler quick enough, if the problem developed quickly and your system is a "fully pumped " system this would generally point to your pump either has failed or is on its way out, i.e . your radiators would not heat up as the hot water is stuck in the boiler hence the banging......( if you know where the pump is you can generally feel if it is running by a small vibration ) if you have gravity hot water and pumped heating circuit then I would assume that it is noisy when just doing HW, and the banging is a problem that has gradually got worse it can indicate that the boiler is scaling up (are you in a hard water area). if this is correct there are various additives that can be put in the system to help quieten it down, I suggest you really need a heating engineer to diagnose fully.
Feb 07, 2014 | Water Heaters
Burner not quite right
You need to get an engineer urgently , there could be a flue problem , i would suggest shutting the boiler off until then
Jan 23, 2014 | Water Heaters
Apr 03, 2009 | Water Heaters
Apr 02, 2009 | Water Heaters
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
How water problem
Your should be able to find the information here. Don't forget to check under discontinued products. www.glow-worm.co.uk
Dec 03, 2008 | Water Heaters
How do i servis a glowworm compact boiler
Hi, perrycallow,
I'm Harvey the Master Plumber,
You want to know how to service a Glowworm compact boiler
Glowworm is a United Kingdom company and here is the information you asked me for, to get their technical service line:
Technical Help: 01773 828300
technical@glow-worm.co.uk
Thank You,
Harvey your Master Plumber.
Please give me a good rating before you sign off.
Sep 06, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
