Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Sony KDF-50WE655 will not power up. Red blight blinks 4 times
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} My Sony KDF-50WE655 will not power up. Flashes picture/sound for 1 maybe 2 seconds then shuts down and red standby light flashes 4 times over and over. Bulb appears to be OK I have checked cover is secure and it lights for the few seconds. Tried unplugging for a length of time and restarting - didn't help. Sony says get a service tech. Any help would be greatly appreciated.
  • 2 more comments
  • chauncymcnab Jan 27, 2009
    Sorry about the previous post I pasted it from a word doc. here goes agian.
    Thanks. I'll try checking fans but since it never actually fires up for more than a couple of seconds, will it have time to over heat?
    A thousand thanks!
    One fan was not working. A small piece of plastic had wedged in it, probably from transportation. I freed it and it fired up right away.
    This of course begs the question; where did the plastic come from? AAARRGGHHH!!!
    Thank you so much!
  • jrobins1 Apr 03, 2009
    I have the same problem. Replaced one of the fans, and now the tv comes on for a little longer then shuts down??? What to do now?? I would like to find a diagram of the inside of this tv. Can someone help?
Tv wont turn on at all
Posted on May 26, 2011
  • 10,594 Answers
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Posted on Jan 27, 2009
  • Shahid Electronics
    Shahid Electronics Jan 27, 2009
    Bad heat sensor can be cause of that problem as system control get signal of over heat just after powering up TV.
    That's great TV is working fine.
    Have nice time.
We Have a Sony KDF-50WE655, we've replaced the lamp and housing and we still have no picture or sound. Can you help?
Make sure that lamp cover is fixed back on its position securely after lamp replacement, turn On tv to check.
If still no picture or sound then check power/standby light is blinking?
If yes, count it how many times it blinks after 3 seconds long pause and let me know to diagnose possible cause of problem.
Thanks.
Aug 01, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
No picture - green light flicking on and off
Bulb light indicator flashes?Projection bulb use alot,an awile like about 1 or 2.The projection bulb must change it at end of it life cycles.
Apr 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Green Power light blinks for about 60 secs, then
YES New lamp needed the model number will be on old one does not take long to change if still got hand book shows how change
Nov 07, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I bought a SONY GRAND WEGA LCD Projection HD-TV about 2 years ago i rarely use it about 6 to 7 times,i turned it on lately and the screen shows no picture ,power light blinks yellow for a few seconds then...
Its possible that one of your fans has failed, and or it could be the lamp itself. Sony television will not power on if a fan is faulty. Open the back of unit and look at all fans to make sure they are running, if so then replace your lamp.
Oct 12, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF 60WF655 standby/power light blights 10 times then repeat
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
Feb 09, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDF-50WE655 shuts down - red light blinking 4 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 02, 2017 | Televison & Video
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
676 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
