Question about HP Photosmart C6180 All-In-One InkJet Printer
HP C6180 AIO won't print in black with new HP catridge. Colors ok
OS is Windows XP SP3. Have cleaned all contacts several times. Have tried HP Tech support to no avail. Did have non-HP black cartridge installed for a while. Have reloaded driver several times but does not help with this problem.
  • 2 more comments
  • jwysong Feb 01, 2009
    HP C6180 AIO won't print in black with new HP catridge. Colors ok problem, and notify you when a new solution is offered.
  • Anonymous Mar 27, 2009
    it uses the colors to print black and sucks up the ink, but will not print from the black cartridge, I've tried 3 different cartridges.
  • kastri Apr 03, 2009
    Can't print in black since the April 1st. Both from Photosmart c6180 and from c5180.They print in Color ok. OS is Windows XP SP3. Have changed black catrige 3 times from 3 different shops. Have tried all tests and HP Tech support. After all test we did together one more time they advice me to replace the printers paying the 80% of their value... both machines are located in diferent places so it has nothing to do with power. Both was working fine till the March 31st. it seems that the printers "expired" on april 1st...
  • Anonymous May 03, 2009
    All colors will print fine but the black photo ink. I just replaced the ink and this didn't happen before.
    President:
  • 8,637 Answers
Normal 0 Try
Disconnectthe printer or at least be sure it is turned off. I'd doboth and when the CD software program asks you to connect the printerto the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Black printer ink not working as well at 100%
There are several possible issues with the refilled cartridges. Nozzle clogging; dirty contacts; static electricity transfered from your bare hands to contacts on cartridge damaging the circuitry; and more.
Clean the contacts on the cartridge using a pencil eraser. If that doesn't help, you should get a new cartridge and see if it fixes the problem.
Nov 14, 2013 | HP OfficeJet Office Equipment & Supplies
HP won't print black, but other colors work. New refill kit...
I purchased a c6180 in Jan 09 have just got the black working fine. After pulling the nachine apart, thinking maybe to soak the head, found micro pump for ink air in black line Run copy black only (took maybe 12x25 times) then head clean Try head clean after 50 copies Voila! Black Cannot rule out that reseating all connections helped
Apr 21, 2009 | HP Office Equipment & Supplies
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 won't print borderless photos
Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp printer error massage no black ink supply NEW CARTIDGE IN have tried reinstalling several time
Hi Jack,
What I understand from your message is that, when you try to print from the computer, you are receiving a message "No black ink supply"...
Solution: If you have installed the full featured AIO software on your computer, then open the HP solution Center on your computer, then click on the settings>> print settings>> Printer toolbox.
Then click on the Configuration Tab and uncheck the option "Display the ink level message". Then click on the Device tab and try to print a Diagnostic page and then click Ok to close the solution center. Then resart the computer and try printing..
I am pretty sure this will resolve the issue..
With Regards
Mike.....
Feb 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
H/P C6180 black not printing
Had the same problem for weeks. Had to go thru all three levels of print head cleaning in the HP Toolbox menu to get black to work again. The head cleaning option on the printer itself was insufficient. Unless you've already gone thru all three cleaning levels this may be worth a try.
I walked thru the steps via the HP website FAQs for the 6180. Basically: Open the HP Solution Center, select Settings->Print Settings->Printer Toolbox, then click Clean the Printheads. After the first cleaning you'll be asked if the test page printed OK (mine didn't), click the Intermediate Cleaning box. You'll be asked again if the test page printed OK (mine did, but an independent MSWord print test was still streaky), click the clean again (sorry, don't remember what this one was called) for the third and deepest clean.
This last one worked for me, now it's back to normal printing. From what the HP website says I'm guessing that my black print head was dried up. That's a reasonable explanation for my situation, we had let the black sit dormant for a couple of weeks after the black cartridge ran out before we tried to install a replacement.
Hope this helps, sure was frustrating for me. Good luck.
Nov 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP PSC 1210 Printer
just chek ur black catridge is working or not just try to clean it and install
Oct 19, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
Dec 19, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
246 people viewed this question
Ben Johnson
