Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
My briggs and straton mod 917.376460 will not start
I changed the oil, filter, spark plug, cleaned the carb, made sure fuel line is clear, new gas and mower still won't start. I can put a little directly into the carb and it runs for a few seconds. What can it be?
hunter19_46m
  • 7482 Answers
SOURCE: mower will not start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
they were in/out.
SOURCE: Briggs and Stratton 6.5 hp won't start- not sure
Took carb. off and cleaned and put new kit in. Carb. is self choking. Put new primer bulb in. Will run with starting fluid then stop. Not getting any gas. Could carb. be clogged. I soaked it in carb. cleaner and blew out. Any suggestions would be greatly appreciated.
Posted on Jun 04, 2010
daneinwv
  • 124 Answers
SOURCE: I have a Craftsman 625
My name is Dane and I am going to try to help you solve your problem.
I believe that you have clogged jets/passages inside of your carburetor. This can happen when an engine gets little use, allowing the fuel in the system to get old and begin breaking down. If fuel is left in a Carb for more than a year, it can eventually turn into a jelly like consistency, and clog the fuel system. What I believe is happening in your case is that the float needle inside the Carb is not allowing gas to enter the carb fast enough to keep up with demand. That's why it will run for 10 minutes and then shut down. After it sits for a while, the float bowl slowly fills back up and it will run for 10 more minutes.
Now for the bad news. This is an extremely difficult carb to work on. It is all I can do to get these Carbs off an engine and back on again to clean them. They are tough because you have a big air filter housing and 2 long bolts with gaskets and then the carb itself and spacers, that you have to hold together as a unit and start the bolts holding the carb to the engine. If you are a good enough mechanic to do this, you will already know how to do it. If not, I honestly suggest you take it to a shop and let them clean it for you. A new Carb isn't all that expensive, so you may want to consider just letting them replace it instead of cleaning.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thank you! Dane
Posted on Dec 04, 2010
  • 72 Answers
SOURCE: Craftsman Mower - 625 Briggs
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
Posted on May 17, 2011
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
I have gas in my oil and gas is pouring out the spark plug hole wats the cause of this?? sears crafsman lt 1000 briggs and straton intek,18 hp needle valve in carb seems ok,fuel solenoid working wat...
Gas in the spark plug chamber should mean it is flooded.trying to start it for too much time with the choke on will do this.when starting cold,engage choke.turn engine over till it tries to start.if you can't disengage the choke before it stalls,do not re-engage the choke.just keep turning the engine over,or pull starting,whichever you have,until the unit starts.it will.for now,if the sp.plg.hole has fuel in it,blast compressed air to clear it somewhat,re-install sp.plug,never overtightening,just snug,and try starting without the choke.hope this is useful.bart.i am a certified small engine mech.and remember when finished,let unit idle for 2 min. Or so and cool before shutting off.change oil religously every 50hrs.for units over 10hp.,every 25 hours for engines below that.they will last a long time.clean air filter after every two or three uses.never empty fuel when storing,use STA-BIL.
Sep 23, 2011 | Garden
We have a 6.25 /Briggs & Straton we have cleaned
You should have two fuel lines going from the carb to the tank, one has a filter,
make sure both lines are good without any breaks or cracks. if the filter is dirty
you may need to replace it. you can fish it out of the gas tank by making a hook
on a wired coat hanger, try to remove the filter and put the line back in the tank
make sure they are both submerged, if it runs just replace the filter, good luck!
Jun 26, 2011 | Briggs and Stratton 020275 Elite Series...
I have a troybilt mower with a honda 160 engine (#gcv160an5a) that will not start. I have cleaned the carb, replaced the spark plug, cleaned the air filter, new gas and oil. The spark plug is dry after...
You may have to replace the carb.But before you do.Check the the fuel line.There is a small screen in the carb,it may be clogged.Inside the tank is a small cylindrical filter,make sure it is good.Break the fuel line at the in line filter,to make sure gas is getting to there,if it is the problem is in the carb.
May 20, 2011 | Honda Garden
I have a Briggs and Straton 6.5 OHV from a Chipper/Shredder..Will turn over with starting fluid but dies. New gas, plug air filter. Carb taken off and cleaned. Cannot blow air thru the plastic 90 degree...
you have a problem with fuel getting into the carb bowl. so either fuel line is stopped up or the needle valve hole is stopped up. should be a simple problem.
Apr 20, 2011 | Garden
I overfilled engine oil in my Briggs Straton engine on my snow thower ... now can't get it started .... can oil foul the spark plug ?
Hi and welcome to FixYa, I am Kelly. Depending on just how much you over-filled it yes it will fowl the spark plug. Most of the time though a small engine failing to start is either fuel or ignition related. Remove the spark plug and check for ign. spark and OIL in the cylinder by pulling the recoil through. Reinstall the spark plug (Just a note about an oil fouled spark plug.... if you clean it with fuel you must make sure that it is dry or it will not work. Spark plugs are cheap I recommend you buy a new one.
Try removing the air filter and adding just a small splash of gas into the carb. throat. then see if it tries to start. If it does but does not run you have a fuel supply problem. This is caused by debris in the carb bowl and fuel orifice jet. You will need to clean out the bottom of the carb and the orifice. Possibly there is debris in the fuel tank outlet, the fuel filter or fuel bowl below the fuel selector depending on your engine model. .I can help you with carb / fuel system cleaning procedures but would like a "complete" ENGINE model - type - and serial number so I can pass you the procedures applicable to YOUR engine.
Thanks for choosing FixYa,
Kelly
Jan 27, 2011 | Garden
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Gas in oil 12.5 hp briggs and straton will not start
the float in the carb is stuck open, its flooding with gas. the gasoline is going past the rings and/or valves into the crankcase. you need to remove the float bowl and unstick and reset the float to specs, maybe a new seat and needle and change the oil before restarting.
Jul 26, 2009 | Briggs & Stratton Garden
I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Mar 27, 2009 | Garden
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
126 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
