Question about Samsung Audio Players & Recorders
How to connect satellite radio?
Right now I have my tv hooked to the red-white-yellow connectors with a cable. My sirius tells me to connect to the red-white connectors but there's only the one set (where my tv is connected). Do I need to get a different cable for my tv such as the HDMI or the blue-red-green (sorry don't know the correct terms!). Thanks!!
Oh I have the Samsung HT-Z410 system (love love it!!). Thank you in advance~!
  • lorit949 Jan 28, 2009
    But I CAN use an HDMI for tv correct? isn't it supposed to be better quality? Thanks so much!! Didn't think about having a multi tap.
  • lorit949 Jan 29, 2009
    I got it...thanks again!!
    Scholar:
  • 93 Answers
No you don`t need HDMI cableing, and do not use the blue, green, red, this is for video 1080i, if your Samsung doesn`t support more than one audio input ( the red and white RCA female plug audio inputs) get a multi tap or a piggy back plug, this will allow you to have 4 inputs into 2 inputs, think of it like an extention cord, one plug into an outlet yielding 3 inlets.
Posted on Jan 28, 2009
  • Mike Lynch
    Mike Lynch Jan 29, 2009
    You can use a HDMI cable for true 1080p picture quality which is only available in Blu-Ray disc players, High definition broadcast TV or HD as its called is only 1080i, this can be accomplished by HDMI cable or the 3 RCA type connector which you describe as BLUE,GREEN, RED, these are called component video, now the yellow rca sigle video in is called composite video and it is the low end quality video aspect, usually located right by the audio in (white R and red L) RCA jacks, hope this is not to confusing :} check out www.about.com hometheatre video resoulution and HDMI facts.
My TV does not have yellow plug just red and white. How do I hook up ?
The yellow socket is for something called "baseband video" That old technology was superseded by "S-video" which is a round connector with several pins inside. both of these systems required the red and white connectors for the audio.
The newest connection is HDMI, which is an about 1 inch wide flat connector with several contacts on it. It has the best picture. If you are hooking up a newer DVR or Cable / Satellite box, Check for newer connectors and buy a matching cable. Newer DVR's and cable / satellite boxes with HDMI plugs send the audio over the same cable along with the video. You do not need to get the most expensive HDMI cable to get a good picture.
Nov 22, 2016 | Televison & Video
I have sound from satelite box through bose 321 but no picture on tv
First, you need to run the coax cable from your satellite dish to the "cable in" input on the back of your satellite receiver, not the Bose. If your satellite receiver has an HDMI OUT, and if the Bose has an HDMI IN,run hdmi OUT from the rec. to the Bose IN, then keep your HDMI connection from the Bose OUT to the TV IN as is. Make sure you've selected the correct input on the TV menu. As it is right now, you're not delivering any video signal at all to the TV!! -only audio(red and white). There are a couple other ways, but they won't give you the same quality. I assume this is HD, right? If you CAN do it this way (i.e. if you have enough HDMI ins and outs), it's the best possible hookup and you won't need the composite (red, white and yellow) at all. By the way, it's the yellow connector that carries the video signal; the red and white are audio left and right. If you can't hook it up all HDMI, disconnect the "separate cable" (I'm not sure what that is or what kind of cable or what it's for)and plug in the yellow connector into video IN on the Bose.
Feb 08, 2015 | Bose Av321 Series Ii Media Center For 321...
Help
Hi, Flat panel television instruction manuals are not very easy reading material, there are many connections on the back-you need to plug in some sort of input-always coming from the " out to T.V." of another device. Cable coax's are most common-the cables aren't very flexible that's one way to tell them apart from an RCA cable-usually with red, white, yellow,green and blue colored ends. The red, white and yellows are what we'll focus on for now-the yellow's are for a picture-connect them from an " out to TV" to " video input" on the back of tv, then for sound likewise- red and white colored from an"audio out " to "audio in " if coming from a VCR-you may use the rather un-flexible " screw on" coax connector-same if coming from a satellite/cable box-some satellites require tuning tv channel to # 60 for a picture-other wise it's channel 3 or 4. although you will get a better picture using yellow, red & white rca cords. I hope this has been of some help, prodzilla
Mar 31, 2011 | Televison & Video
I have a blu-ray disc player. Model Bd-C5500. It seems to be telling me I am not connected to HDMI cable. I have connected the cable to the HDMI out terminal on the rear of the player to the HDMI in on the...
HDMI and the red, white, & yellow cables are two different sources. Try using the remote to switch playback source from HDMI to the other choice not sure what Samsung calls the red, white and yellow connectors. I can tell you that the red cable is audio right, the white cable audio left and the yellow is the video.
Jun 28, 2017 | Sony HESV1000 200 Disc Blue-Ray Server
I am wanting to connect my portable wharfdale dvd player to a tv. where can i get the right connection cable. thanks
Usually somewhere like radio Shack will have those cables, they are called AV, Audio Visual Cables, You need 3 Cables, with "Male Jacks" at both ends, usually Red & White, (The Audio), & Yellow, (Video). They connect color to color at each end, and on the TV you select "Aux", "Extern", but NOT a channel. If you have "Component Video, then you will need a set of 3 & 2 cables, (5 all together) Blue, Red, Green, ALL Video, & White & Red, Audio. you select the "Input" on the TV the same as for AV. So with AV, you use 3 cables, with Component, you use 5. If HDMI you need a single HDMI cable. cables.
Feb 21, 2010 | Televison & Video
How do you connect to a direct tv box
1st, what kind of Tv Box ? with SCART Connector? or RCA Connector?
2nd, the recoder has a Scart connector or Females Rca connectors.
check for Video IN and L/R input Rca Connector
then use a Scart/RCA cable to connect DVD to TV Box.
Nov 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
How do you hook up to dish network? there is no spot on the back of the tv to hook up the regular tv cord coming out from the cable box.
At the bottom right of this model there should be a connector labelled Antenna/Cable - if not there, use the ones labelled Composite Inputs and connect the yellow red and white cables fom the output of the satellite box there. (you'll need a the a/v cables)
Oct 05, 2009 | RCA D52W23 52" HDTV CRT TV
Clarion vrx935vd how to hook it up. i have a black cord and i think its a adapter and i dont no where to find it or whats it called but i dont no how to find it or hook it up.
the adapter would be for a sirius satellite radio
here is the wiring diagram
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Sep 20, 2009 | Clarion VRX935VD Car DVD Player
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
Hooking tv up to my vcr/dvd combo
hook the antenna to the VCR rf conecter IN. buy some RCA jacks and a three way deal and hook the red to sound red out ,white to sound output white, and yellow is always video hookit to yellow vido out on the vcr/dvd. The other ends go to the inputs on the TV....same color code. or you can just hook a cable to rf connector OUT on the vcr and other end to( it with problably just same antenna in) to TV.
Aug 29, 2007 | Sanyo DS31520 31" TV
93 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
