Question about Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher
Dishwasher starts to fill then starts make a jackhammer sound
When you press start, you can hear it start to fill, then stops filling and makes a jackhammer sound from the pipes.
Has been working good for the past 3 years. We only use it once a week.
  • 1 more comment
  • rkingtxtx Jan 27, 2009
    No, it will not wash since there is not enough water.
    wow thanks so much for the help. i will give it a shot and see what happens
  • Mark Egan May 11, 2010
    Does the dishwasher continue to wash, and the problem your wanting fixed is the jack hammering?
    President:
  • 1,214 Answers
OK. I bet there is a chunk of mineral build up that it loose inside the water line leading up to the valve. Either the one in the dishwasher, or the one at the cutoff under the sink.
Turn the water off under the sink. Access the bottom of the dishwasher, and disconnect the water line from the valve. Put the end of the line in a bucket or some type of tray, and turn the water on to see if the chunk comes out. Try to turn the water on as hard as you can to try and blow the chunk free. If nothing comes out, look inside the valve where you disconnected it to see if you can see anything.
If it doesn't come out, or you don't see it come out, try connecting everything back up and testing to see if you might have missed it coming out.
Same thing could be happening at the valve under the sink, and that one is a little harder to purge.
One other thing to listen for is to be laying on the floor neat the dishwasher when the stop occurs, listening for what goes "clunk". It might be in the dishwasher, it might be under the sink. At least by isolating where it happens, you'll know where to look.
Posted on Jan 27, 2009
  • Mark Egan Jan 27, 2009
    Let me know what you find, or don't find. There are some other things that it could be, but I need to see where this heads first.
    One other suggestion. Turn the dishwasher on, and let the thump happen. Then turn on ONLY the hot water on the kitchen faucet. Tell me if you get flow at the faucet then. You can also try this same thing, but turn the faucet on first, then the dishwasher. Note if there was a change in flow in the water after the thump, if it happens or you hear it happen.
    Depending on what you find, this may help isolate where the problem is.
Bosch SGS43C12 dishwasher fills with water as normal at start of programme, then you can hear a quiet 'click click' normally the cycle would start, but nothing happens. I can press reset and it drains the...
Where does the clicking sound seem to be coming from? Start the machine and when it's filled with water, try to identify where the clicking noise is emanating from. I suggest putting you ear next to the programme selector and start/stop switch and see if you can hear it more loudly/clearly.
Sounds like a faulty control module to me. Try the above and report back . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not getting enough water in either drawer, although top drawer gets more. Dishwasher keeps beeping during cycle and reads not enough water and then stops running until you press the start...
This sounds like a hard water deposit problem.
Check your water inlet valve for a screen and see if its clogged. Also it may just be a water valve/solenoid problem. As in, it's too crusted up to float up and down.
Some models have a water fill timer, while others use a water fill/pressure switch. This may also bear inspection.
The beep you hear during your cycle is indicating that your water level is too low to cover the heating element, which can cause cracking and lead to a short.
Mar 07, 2010 | Fisher and Paykel DD605FD Stainless Steel...
I have a Maytag MDB4651AWW3 dishwasher that stops during cycle
is it making a humming sound ,then the pump is blocked see if any thing is stuck under spray arm, worst could be is the motor unplug before working on it. thanks
Dec 01, 2009 | Maytag 24 in. MDBH950AWS Built-in...
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Bosch SHV46C
Replace the fill valve that sound is it trying to open
Mar 12, 2009 | Bosch 24 in. SHV46C13UC Free-Standing...
Whirlpool dishwasher will not fill with water
turn the valves to the left if there the screw in type or parraell if the quick open type the first thing a dishwasher does when you start it is drain for a few minutes then stops then fills with hot water run the water as hot at the sink as you can before starting the washer there is a float in the tub that can shut the water valve off if its not seated on the safety switch after the drain at the start of cycles stops then you should hear the water valve open and start the fill let me know and we will go from there
Mar 27, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Maytag 24 in. MDB5601AWS Stainless Steel Built-in Dishwasher Logo
217 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
