Question about GE Profile WPRE6100G Top Load Washer
Can't get agitatir out
How do I remove agitatir from washer
    President:
  • 1,314 Answers
Just grab it by the bottom under it and **** up hard if that dont do it get a piece of rope and a 2x4 run the rope under the edges of the agitater around the 2x4 and use it to pull it
Posted on Jan 29, 2009
  • robert samples Jan 29, 2009
    yank dont know why i cant use ****
    yank up hard lol
How do you replace the windshield washer pump on 2008 ford focus, wipers work but no spray comes out
The hose could be clogged ! Do you know where you add the washer fluid ? Somewhere on the bottom of that plastic bottle is the washer pump .
Removal and Installation
> WARNING: Windshield washer solution contains methanol, which is poisonous. Observe all cautions and warnings indicated on label of washer solution container. Failure to follow these instructions may result in personal injury.
> CAUTION: When replacing the windshield washer pump be careful not to damage the rubber grommet.
> CAUTION: Do not operate the windshield washer pump before filling the reservoir. Failure to do so could result in premature pump failure.
  1. NOTE: When installing the reservoir, the filler neck must be lubricated using a water-based lubricant.
    Remove the bolt and the windshield washer reservoir filler neck.
  1. Remove the RH fender splash shield. For additional information, refer to Section 501-02 .
  1. Remove the foam filler and remove the retainer.
  1. Remove the 2 screws and the accessory drive splash shield.
    • To install, tighten to 5 Nm (44 lb-in).
  1. Remove the nut, 2 bolts and position the A/C accumulator aside.
    • To install, tighten to 9 Nm (80 lb-in).
  1. Unclip the A/C lines from the inner fender well.
  1. Drill out the rivet and remove the bracket.
  1. Remove the 2 bolts, slide the windshield washer reservoir assembly forward to release it, and position the washer reservoir aside.
    • Install the upper bolt followed by the lower bolt, and tighten to 5 Nm (44 lb-in).
  1. Disconnect the windshield washer tube assembly from the pump and release the windshield washer tube assembly from the washer reservoir.
  1. Disconnect the electrical connector from the windshield washer pump.
  1. Release the wiring harness from the reservoir, and remove the washer reservoir.
  1. To install, reverse the removal procedure.
Apr 07, 2015 | Ford Cars & Trucks
How to replace the winshield washer fluid resevoir 2001 pontiac grand am 3.6L
  1. Remove the left front fender liner.
  2. Remove the air intake duct.
  3. Remove the connector from the washer pump.
  4. Remove the hose from the washer pump.
  5. Remove the connector from the level sensor.
  6. Remove the brake control module.
  7. Remove 3 screws and the washer solvent container from the vehicle.
    Reverse to install.
Oct 17, 2012 | 2001 Pontiac Grand Am SE
Washer Tank removal
1.Disconnect the negative(-) battery terminal.
2.Remove the front bumper cover. (see below)
3.Remove the washer hose and the washer motor connector.
4.Remove the washer reservoir after removing 2 bolts.
There is a writeup and diagrams here: http://www.hyundaiforum.com/forum/showpost.php?p=30154&postcount=3
Mar 09, 2011 | 2002 Hyundai Accent
Where is the windshield washer motor located? Is it near the heater motor? I had mine fixed and now the heat comes out of the dash for the defroster
Windshield Washer Pump Removal & Installation To Remove:
  1. Remove the air cleaner assembly.
  3. Position the pump and reservoir aside.
  4. Disconnect the electrical connectors.
  5. Disconnect the washer hose.
  6. Remove the pump and reservoir.
  7. Remove the washer pump.
WARNING
Windshield washer solution contains methanol which is poisonous. Observe all cautions and warnings indicated on label of washer solution container.
NOTE: Windshield washer fluid should be collected in a container after the windshield washer hose is disconnected.
To Install:
WARNING
  1. Install washer pump in reservoir.
  2. Install washer pump reservoir assembly.
  3. Connect washer hose.
  4. Connect washer electrical connector.
  5. Install air cleaner assembly.
The windshield wiper fluid pump is located in the tank which is not in the heater motor or defroster area in the dash.
The defroster/heat control door is located in the dash board area:
Air Door Actuators, Cables or Motors Removal & Installation Air Inlet Door Vacuum Control Motor To Remove:
  1. Remove the instrument panel lower insulator cover.
  2. Disconnect the vacuum connector.
  3. Remove the control arm clip and the spring.
  4. Remove the nuts and the air inlet door vacuum control motor.
To Install:
  1. Install the vacuum motor on the mounting bracket.
  2. Connect the control arm and spring.
  3. Connect the vacuum hose to the vacuum motor.
  4. Install the lower instrument panel lower cover.
Floor Defrost Door Vacuum Control Motor To Remove:
  1. Disconnect the negative battery cable.
  2. Remove the left lower dash insulator panel and disconnect the lamp.
  3. Remove the two pin-type retainers and remove the fill panel.
  4. Remove the DLC mounting screws.
  5. Detach the vacuum line.
  6. Remove the lighting module.
  7. Remove the screws and the bracket.
  8. Remove the floor/defrost door vacuum control motor.
Floor/Defrost vacuum motor mounting screws for-10-00-246.gif
To Install:
  1. Connect the vacuum lines and install the floor/defrost vacuum motor.
  2. Install the bracket and lighting control module.
  3. Install the DLC bracket and mounting screws.
  4. Install the fill panel.
  5. Install the left lower dash insulator panel.
  6. Connect the negative battery cable.
Panel Door Vacuum Control Motor To Remove:
  1. Remove the instrument panel.
  2. Reach through the door opening and remove the pin.
  3. Disconnect the panel door vacuum control motor vacuum line.
  4. Remove the screws and remove the panel door vacuum control motor.
To Install:
  1. Install the panel door vacuum motor.
  2. Connect the vacuum line to the panel door motor.
  3. Reach through the opening and install the pin to the linkage.
  4. Install the instrument panel.
Jan 19, 2011 | 2003 Mercury Grand Marquis
Replace windshield reservoir
Windshield Washer Motor REMOVAL & INSTALLATION 1987-95 Vehicles
  2. Drain or siphon the washer solvent from the reservoir.
  3. For 1987-91 vehicles, remove the brace.
  4. Unfasten the reservoir screws.
  5. Detach the electrical connectors and washer hose.
  6. If necessary, remove the reservoir from the vehicle.
  7. Remove the washer pump motor from the reservoir. Fig. 1: Location of the windshield washer fluid reservoir and pump - 1987-91 vehicles 89636g50.gif
    To install:
  8. Install the washer pump motor on the reservoir. Make sure the pump is fully seated in the reservoir gasket.
  9. Position the reservoir in the vehicle.
  10. Attach the electrical connectors and washer hose.
  11. Install the reservoir retaining screws.
  12. Install the brace.
  13. Fill the reservoir with washer solvent.
  14. Connect the negative battery cable, then check for proper washer pump operation.
1996-99 Vehicles
  3. Detach the electrical connectors from the washer.
  4. Disconnect the hose from the washer pump.
  5. Loosen the nut at the bottom of the washer reservoir.
  6. Unfasten the 2 nuts, then remove the washer solvent reservoir.
  7. Remove the washer pump from the container.
  8. If necessary, remove the solvent lever sensor switch from the washer solvent container. Fig. 2: Exploded view of the washer fluid reservoir, pump and level sensor 89636g51.gif
    To install:
  9. Install the solvent level sensor switch in the washer solvent container. The tab on the solvent level sender switch must be lined up with the slot in the hole.
  10. Install the washer pump into the reservoir, making sure the pump is pushed all the way into the container seal.
  11. Install the washer solvent reservoir and secure with the 3 nuts. Tighten the nuts to 44 inch lbs. (5 Nm).
  12. Attach the electrical connectors to the solvent level sensor and washer pump.
  13. Connect the hose to the washer pump.
  14. Fill the reservoir with washer solvent.
  15. Connect the negative battery cable, then check for proper washer pump operation.
Nov 09, 2010 | 1997 Pontiac Bonneville
Cannot remove front rotor. Caliper and pads
Raise vehicle and remove wheels. Disconnect brakeli
ne from caliper (if necessary). Remove caliper.
On models with free wheeling hub, set control handl
e to FREE position. On all models, remove hub
cover, bolt/washer and hub body. Use tapered punch
to open slits of conical washers. Remove axle shaft
snap ring (if equipped).
Straighten tabs of outer lock washer. Using Spindle
Socket (09607-60020), remove lock nut, lock washer
and adjusting nut. Remove thrust washer and outer b
earing. Remove axle hub and rotor. Remove grease se
al
and inner bearing. Press hub bolts out of axle hub.
Remove retaining bolts, and separate rotor from hu
b.
Mar 20, 2010 | 1996 Toyota Land Cruiser
Mercury villager 1994 washer pump not working
the pump motor likely is bad. get a used washer fluid reservoir at a pick n pull yourself or at car-part.com. page with * is lowest cost.
Pump and Reservoir, Windshield Washer Removal
  1. Disconnect the battery ground cable (14301).
  2. Raise and support the vehicle.
  3. Remove the RH wheel (1007).
  4. Remove the RH front fender splash shield (16103). Refer to Section 01-02 for the removal procedure.
  5. Remove the windshield washer reservoir top bolt.
  6. Disconnect the windshield washer reservoir fluid level sensor electrical connector.
  7. Disconnect the rear window washer pump electrical connector from the rear window washer pump.
  8. Disconnect the windshield washer pump electrical connector from the windshield washer pump (17664).
  9. Place a suitable drain pan under the windshield washer reservoir (17618) and drain the washer fluid.
  10. NOTE: The rear window washer hose end is color-coded, matching the connector on the rear window washer pump. Match the colors to ensure proper installation.
    Disconnect the washer hoses from the windshield washer pump and the rear window washer pump on the windshield washer reservoir.
  11. Loosen the two windshield washer reservoir side bolts.
  12. Remove the windshield washer reservoir by sliding it out of the side slots.
  13. Remove the windshield washer pump.
    Installation
To install, reverse the removal procedure. Tighten the lug nuts (1012) to 98-118 Nm (72-87 lb-ft).
Sep 09, 2009 | 1994 Mercury Villager
How to remove and replace windshield wiper reservor
Here are the steps to remove the reservoir:
  1. Remove the battery and battery tray from the vehicle .
  2. Remove the inner wheel housing from the vehicle.This is the plastic liner.
  3. Disconnect the electrical connector from the washer pump.
  4. Disconnect the electrical connector from the washer solvent level sensor.
  5. Disconnect the washer hose from the washer pump.
  6. Remove the upper bolt from the washer solvent container.
  7. Remove the lower bolts from the washer solvent container.
  8. Remove the washer solvent container from the vehicle.
Sep 03, 2009 | 1999 Chevrolet Silverado 1500
Wash wipe on a Focus 2000 model
I blieve it's the same pump taht runs the rear and front washers.
The windshield washer comprises the following parts:
  • Windshield washer reservoir, below the front left-hand fender
  • Washer pump, on the outside of the washer reservoir
  • Two washer nozzles on the hood/bonnet, adjustable.
Windshield Washer Pump and Reservoir Removal
All vehicles
  1. Remove the windshield washer reservoir filler neck.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the right-hand fender splash shield (wheel shown removed for clarity).
  1. Remove the washer reservoir.
    • Disconnect the electrical connectors.
    • Pull off the hoses.
  1. Remove the windshield washer pump with rubber gasket (shown with reservoir installed).
    1. Disconnect the electrical connector.
    1. Disconnect the hoses.
    1. Lift out the pump.
Feb 27, 2009 | 2000 Ford Focus
Whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Jun 28, 2008 | Whirlpool GHW9400 Duet Washer
GE Profile WPRE6100G Top Load Washer Logo
35 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
