Question about RCA Scenium HD65W20 65" Rear Projection Television
NOT TURNING ON
WHEN I TURN THE TV ON, IT SOUNDS LIKE IT WANTS TO GO ON BUT THEN TURNS OFF. THE LED LIGHT, ON THE POWER BUTTON,COMES ON AND THEN TURNS OFF 3 TIMES IN A ROW,BEFORE SHUTTING OFF COMPLETELY. THE FUSE NEXT TO WHERE THE PLUG REACHES THE SET IS GOOD,SO IM NOT SURE WHAT ELSE TO DO. ANY HELP WILL BE APPRECIATED. THANKS.
I am experiencing the exact same problem as you described. I had a tech, come and look at it and am told that its a motherboard problem. Here's the kick in the teeth, there are no MBoards available and I may have to wait 1-3months for one. What sucks is that when I first bought my TV the exact same problem occured within a 3 days of purchase...long story short I was given another New in the box tv to replace the tv that rca could not fix. If you have a personal warrenty, use it to finest detail, some contracts have a lemon clause and may cover you if you should get to a point of "TV HELL" Your not alone here and I just wanted to let you know what I've experinced to date. RCA is now Thomas Electric something or another Call their customer relations department and let them know your situation, how you've read that others have experience your same problems ect. 1-866-465-7157. best of luck
Posted on Jul 24, 2007
SOURCE:
How do i get the codes for a GE universal tv remote
You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Dec 10, 2010 | GE Televison & Video
GE 5-Device Learning Remote i need the code for my sanyo tv so i can reprogram it
Manual code entry
Auto configuration
Thank You
Oct 23, 2010 | Televison & Video
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Codes for ge universal tv remote and how do i program it?
Manual code entry
Auto configuration
Thanx
Oct 05, 2010 | GE Televison & Video
What are the codes for a zenith tv? I cannot find my manual
Manual code entry
Auto configuration
Thank You
Sep 19, 2010 | GE JASRM24912 Remote Control
I would like to help me program my remote control my TV, I hope is a trademark relistic solve my problem thanks
Manual code entry
Auto configuration
Thanx
Aug 07, 2010 | GE JASRM24912 Remote Control
I don't know the code or how to program it to my magnavox tv or zenith dvd/VCR player
Manual code entry
Auto configuration
Thanx
Aug 05, 2010 | GE RM24912 Universal Remote Control
To program my TV JVC
Manual code entry
Auto configuration
Codes for JVC TV are
3 digit codes:
013, 012, 026, 054, 055, 060, 065, 067, 069, 089, 141, 197, 247, 901
4 digit codes:
0060 0026 0197 0069 0160 0247 0923 0012 0065 0067 0141
Thanx
Aug 04, 2010 | GE JASRM24912 Remote Control
Need code for slyvania tv & instructuins on how to do it
GE
Manual code entry
Auto configuration
Thanx
Aug 01, 2010 | GE JASRM24912 Remote Control
RCA Scenium HD65W20 65" Rear Projection Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
