Cannot remove novo vision from flashing on my monitor
Novo vision box is flashing on my monitor and is cursor resistant. turning off the computer and restarting does not remove the box. am unable to log in to my computer because the novo vision box blocks screen access.
Press the power button of the monitor for a few second in 'of' mode then 'on', the popping add on the windows will just disappear.
This help solve my problem.
Posted on Aug 18, 2013
4 Suggested Answers
pankaj_dic
  • 1250 Answers
SOURCE: My laptop is showing blank screen after restarting
try starting your laptop in safe mode by presssing f8 during the booting process, then check whether its boot or not
Posted on Oct 28, 2008
  • 26 Answers
SOURCE: i dont have a cursor, unable to log on computer.
DO A POWER DRAIN OF THE LAPTOP BY DISCONNECTING THE POWER CHORD REMOVING THE BATTERY AND PRESSING AND HOLDING THE POWER BUTTON OF THE LAPTOP FOR 20 SECS
ALSO IF WE CAN REACH THE DESKTOP MAKE IT SURE WE CLEAN THE COMPUTER OF UNNECESSARY FILES BY TYPING THIS COMMAND IN THE RUN BOX
1.START BUTTON> RUN>TYPE IN %temp% >and then hit enter and select all the folders in this windows and delete it
2.START BUTTON>RUN> TYPE IN prefetch and then hit enter and select all the folders in this windows and delete it
3.start button>run box type in cleanmgr.exe and select the drive usually operating c and try cleaning the files
WE ALSO HAVE TO THE BIOS UPDATE OF THE LAPTOP FROM THE MANUFACTURER WEBSITE if needed
If this does not help then take your laptop to the day when the laptop was working fine by doing a system restore
system restore can restore within a period of 90 days
if then this will be the path to system restore
start>all programs>accesories>system tools>system restore
if not then get the recovery or the restore disc from the manufacturer and take the computer to factory condition.
have a nice day!!!
Posted on Jun 23, 2010
  • 19 Answers
SOURCE: I have an asus g74sx when I turn it on it only gets past the asus title screen then to a blank screen with a cursor flashing on the top left corner. I've tried hitting f9 but all it does is restar
Try hitting f12 or f10 at bootup this should give you bootup repair options
Posted on Feb 19, 2012
Xo vision xtab factory reset
I had been trying to locate how to access the recovery options for the XO Vision XTAB tablet as well. Mine would show the XO Vision logo on start-up and then show a cursor in the upper left corner for a few seconds and then showed "ANDROID" a little further down and to the right of the upper left hand corner with a flashing cursor right behind it.
I was finally able to get into the recovery options press HOME, VOLUME UP, & POWER at the same time and hold for about 6 seconds or so. You need to let go before the XO Vision logo goes away. Wait until the logo goes away and a cursor should display in the upper left hand corner and then you'll get to the recovery / update options screen.
Use the VOLUME UP / DOWN keys to navigate the menu and then you'll press MENU to select the option. After that let it run through its processes until it completes. My attempt was unsuccessful at a factory reset and I'm still not sure how to fix it, however, you may have better luck.
Apr 08, 2013 | XO Vision Xtab Android Ebook Reader
Samsung 931bw screen flashes on and off
unscrew the back cover of the monitor then remove to access the power supply board, look for a leak or blown up electrolytic capacitor. just replace with the same rating and value a panasonic brand of capacitor much better with low esr.
Jun 28, 2012 | Computers & Internet
GVision L15AX-JA driver
Opened the box and found black mold and fugus all over the
gvision touch screen.
Feb 26, 2012 | GVision L15AX-JA-452G 15" LCD Monitor
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Dell monitor e17s fbp.. wont turn on
Flashing power LED light means you may have shorted (Emitter to Collector) out transistors (c5707) or bad fuse (fuse has high resistance) PF751. Those are what you need to check. see pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
http://s807.photobucket.com/albums/yy352/budm/Dell%20E15x%2017x%20series%20PWR%20INVERTER%20BD/
Post back what what you find so we can guide you further.
Feb 27, 2010 | Dell E173FP 17" LCD Monitor
Tengo un problema horizontal en mi monitor dell
que tipo?
fluatuação ou mas pequena que ecran es fonte de alimentacion, com problemas, tiene que reparar-la. normalmente, e um pouco ingrato que se pierde mucho tiempo reparar-la, e o custo de uno novo monitor, normalmente nao compensa reparar-la.
Feb 09, 2010 | Dell P793 17" CRT Monitor
Amber light on in box and monitor no pics at all
if the Box (System Tower) is Flashing AMBER,seems to be Powersupply is gone.unplug all the cables,press the power button for more than 10 sec then put all the cables and try to turn on
Jan 02, 2010 | Computers & Internet
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Samsung tv le37r8
Using a monitor
1..connect computer/media center to your monitor,
2 click on nvidia nview display settings,
3, select the current display tab and samsung,
4 then apply,
5,then when the confirmation box appears click yes within 15 seconds.
Using your samsung.
Attach a scart to your media centre, from your t.v with the p.c cable still attached, turn over using the source button until you can see a pc picture on your screen (EXT1or2), do steps 2 & 3 THEN move your cursor to the apply button (do not move the cursor from this position), press your source button till you get PC channel (which has no picture yet) then press your mouse button to apply, ( your picture will flicker on), and before the picture goes confirm with the yes button. You now have light! eureka :)
Jan 01, 2008 | Televison & Video
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
