Question about Home
I HAVE THE WELWOTH AND WANT TO KNOW HOW TO INSTALL THE TANK PROPERLY WITH THE 3 BOLTS THAT GO THROUGH THE RUBBER GASKET.HOW TIGHT SHOULD IT COMPRESS THE RUBBER?
MODEL # 11464-0
gypsycat00
  • 224 Answers
SOURCE: I fixed (I think) a broken flaper valve assembly.
Go to home depot and tell them you need a tank-to-bowl gasket. They have them at home depot and it may come with new bolts for the tank-to-bowl fastening. New bolts would be a good idea to pick up anyway. One rubber washer under each head, then a rubber washer at the bottom of the tank. Use a metal washer and nut to secure this to the tank, then use another washer and nut from the bowl to the tank.
Posted on Jul 06, 2009
  • 15 Answers
SOURCE: toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Posted on Jan 26, 2010
  • 760 Answers
SOURCE: cannot get the bolts and
Some manufacturers specify only to use rubber washers inside the tank, and only one bolt on bottom. I usually assemble the bolt with one metal washer on bolt ( or bolt with large head) then a rubber washer, then through tank, then another washer, then a metal washer (brass or stainless) then another nut. Snug these nuts up tight, but be careful not to over tighten or you'll break the tank. Do this to all the bolts. Then set the tank on bowl, with the bolts extending through the bottom. Make sure your gasket is up all the way on the nipple, so the tank will tighten to the stops on the bowl. Now put another set of rubber washer, and metal washer and nut (thumb nuts are fine here) Tighten till tank doesn't rock and is resting on stops. Now it doesn't have to be so tight, as the bolts are already tight in the tank. You can get a fluidmaster bolt kit at home depot that has enough bolts, washers and all
Posted on Aug 03, 2010
  • 28 Answers
SOURCE: Jacuzzi sent me new rubber gasket for attaching
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Posted on Sep 01, 2010
Magaiver
  • 707 Answers
SOURCE: I replaced the triangular gasket
I usually use a small bead of silicon when I install Gaskets their for I am sure not to overtighten..........Hope this helps.
Posted on Sep 04, 2010
Leaky Seal
By leaking do you mean onto the bathroom floor, or is water escaping out the flush valve (the part that the Hydroright is seated in) into the toilet bowl. If the former 1) check toilet tank mounting bolts/gaskets for deterioration or looseness. These are usually 5/16"x3" brass bolts with rubber, plastic, and metal washers with a nut. They can be seen protruding through bottom of tank. 2) check flush valve and rubber gasket between tank and bowl. The flush valve is the one that the refill tube goes into and the hydroright seats into.
If you are only leaking water into bowl I would suggest the blue dome gasket ( part of Hydroright kit) is not properly seated properly into flushvalve, and you may have to re-install hydroright (the instructions explain how to remove and re-install) . I broke my existing/old flush valve at the base when trying to install my Hydroright so maybe it was fortuitous that it broke and I had to install a new one. Hope this helps.
Dec 15, 2013 | HydroClean Hydroright Dual Flush Converter...
Tip
How to install a new flush valve
  • Flush valves are held to the tank by one large jam nut on the bottom of the tank. Installing a new flush valve usually requires removing the toilet tank from the bowl, which can be rather complicated. However, wall-mounted tanks may not need to be removed.
  • If the toilet tank must be removed, turn the water off completely, flush the toilet and hold the trip lever down to evacuate most of the tank water. Use a sponge to remove the remaining water. Disconnect the tank's inlet fitting from the water supply. If the flexible riser tube is damaged, replace it.
  • Then, unscrew the two rubber-gasketed bolts flanking the flush valve. These bolts go through the tank and bowl flange, with nuts beneath. Use caution–forcing the bolts may cause you to break the tank, bowl or both. Use plenty of penetrating oil on the threads. If they still won't budge without force, try wrapping masking tape around a hacksaw blade and sawing with the teeth facing you, so the blade cuts on the "pull" stroke. The layer of masking tape will protect the bowl's glazed surface from saw scratches.
  • The tank should now lift away from the bowl. Lay it upside-down on a throw rug or newspaper padding to protect it, and unscrew the large nut holding the flush valve to the tank. Use channel-locking pliers plus penetrating oil and extreme care to avoid breakage. Clamp a well-padded locking plier/wrench around the flush valve to keep it from rotating inside the tank.
  • Install the new flush valve according to the directions. The rubber gasket goes on the inside of the tank to prevent leakage. The flat washer fits on the outside to prevent tank damage.
  • Use new brass tank hold-down bolts, which will remain workable. Tighten the bolts just enough to compress the tank's soft rubber gasket and keep it from leaking.
  • Install the water supply riser to the tank and turn on the water.
on Jan 16, 2010 | Plumbing
What could be the cause of leak after installing new gaskets and screws, above back/rear screw? 1) not from screws 2)tank not cracked 3)securely tightened all 3 screws 3a)hand tightened(only)large...
Hello, W/D here.
Most probably, the tank-to-bowl gasket has not seated properly. They are usually neoprene, and tend to bight on the bowl socket rather than to slide into the socket where it can be compressed properly. Remove the tank bolts and look at the gasket. Re-install, using a water based lubricant on the bowl side, with the gasket installed on the tank flange. Wiggle the tank and gasket back and forth a few times, and the gasket will start properly into the cast socket on the bowl. Install the bolts and tighten to finger tight. Wiggle the tank a bit more, and level the top. Tighten the bolts uniformly.
You mention that the flush valve was hand tightened only. If this gasket is not snug (a bit more than hand tight), a leak can occur there as well.
Best regards, --W/D--
Apr 05, 2011 | Kohler - Toilet - Two-piece - Highline -...
New Glacier Bay Toilet leaks between tank and bowl. I have taken off the bowl and re-attached several times and the bowl leaks at the factory installed gasket every time, one side or the other. It appears...
Hello, W/D here.
The gasket you are talking about is hard to get into the hole properly. It tends to want to "bunch up" on one side or the other. The easiest way that I know of to install it is to place the gasket on the tank and then to wet the seal and wiggle the tank as you set the tank onto the back of the bowl. Water based jelly also works (better). Just apply sparingly if using the jelly; place a little around the seal, and a little around the molded socket of the bowl, and place the tank on the bowl. wiggle the tank back and forth lightly, then align the tank with the bowl and insert the bolts. If you have a mirror and flashlight, use them to help inspect your work as you go.
Feb 28, 2011 | Home
Replace toilet tank bolts
Go to a plumbing supply house and get 2 or 3 bolts, 2 or 3 rubber sleeves for the bolts, and a new rubber gasket to go between the tank and toilet. Turn the supply water off, sorry, but, you don't know how many people don't do that. Disconnect the supply line from the tank. Flush the toilet, to remove water from the tank. Unbolt the tank. On the back underside of the toilet, you have 2 or 3 nuts to remove, depending on the toilet. Lift off the tank. Turn over the tank and set it on a towel. Now, gently tap down the bolts. Turn tank over and pull out the bolts. Turn tank back over and remove the tank and bolt gaskets, just push them in. Turn tank over. push in the new gaskets. Replace tank gasket, and gently tap down new bolts. Remount the tank. tighten the nuts, be careful, always tighten the nuts about the same. never tighten one all the way, and then another. YOU can crack the tank when tightening. Just nice and snug. Re hook the water supply, and turn on. Always check for leaks. If dripping, just tighten a little more. Just remember to tighten the all the nuts a little at a time. Keeping the tank level when tightening.
Dec 24, 2010 | Sterling 402315-0 White Windham Two-Piece...
Toto Pacifica Gmax elongated toilet problem. Same problem I cannot solve. I can replace the flapper, no sweat. But I have replaced the large ring gasket, located on the plastic exit port of the tank,...
Hi, Dayne here
Those large gasket seldom leak unless the two bolts are not tight enough. DO NOT over tighten. The water is probably coming from the bolts themselves. The rubber washer goes on the inside of the tank, and then a nut should be on the outside with a metal washer. Tighten pretty tight, but not too tight.
Thanks.
Dec 12, 2010 | Home
Cannot get the bolts and rubber washers to seal properly in the holding tank of our new TOTO Drake toilets
Aug 02, 2010 | Toto Home
Installing new jacuzzi 1.6 gallon maxima toilet. despite following the instructions, the water is leaking from between where the tank connects to the bowl. Please help.
Yes, it seems the folks who wrote the instructions have never actually done any plumbing.
first place a rubber washer on the bolt, then put it through the hole in the tank. Then place another rubber washer on the bolt, followed by a metal washer and a nut. Tighten the nut, not the bolt.
Using a screwdriver hold the bolt in place, and tighten the nut until snug and the rubber washers are compressed slightly.
Follow this step with all the "tank to bowl" bolts.
Now the bolts are tight to the tank and will not leak water.
Then place the large rubber gasket over the flush valve hole on the bottom of the tank. and set the tank on the bowl with the bolts through the bowls holes.
Place a metal washer on the bolt, and then a nut.
Tighten each nut equally until the tank has no wobble.
Oct 01, 2009 | Jacuzzi Bath Maxima EL61 959 White...
I need torque specs.for head and centerhead when replacing new gaskets.
never have used a torque wrench to install toilet tanks. Put gasket on tank and insert bolts with rubbers washers through gasket and set tank on bowl in a level and straight postion and start nuts tightening them evenly until tank starts to snug to bowl. Hand tight is usually sufficient, you will see the rubber gasket and washers will compress to bowl and tank forming a seal (EVENLY) and tank will be firm to bowl. DO NOT superman torque these nuts! Compare the torque to finger strength on a wing nut. Hope this helps ,"if I understood the question."
Mar 22, 2009 | Kohler KOHGP51487 Authorized Original...
Home Logo
59 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
