I have the pioneer vsx 255 receiver and i dont want to switch it off completely. How do i set it to standby?
2 Suggested Answers
ABKSeeker
  • 69 Answers
SOURCE: Pioneer VSX-D606S subwoofer set up
is the square button also labled as down arrow button, push the down arrow button and will give access to the lcd screen setup options on the receiver center speaker size lfe att settings cross over rear channel size ect. i don't have the manual either took me a year to fix the issue.
Posted on Feb 14, 2010
How do you troubleshoot a Pioneer VSX-1023 A/V receiver?
Try to do the factory reset on the Pioneer:
Switch the Pioneer into standby (turn it off).
1. Simultaneously press old the buttons on font panel for 5 seconds - BAND & STANDBY/ON
2. "Reset" on the front panel press
AUTO SURROUND/STREAM DIRECT
3. Then press ALC/STANDARD SURROUND
OR
Simultaneously pressing "down" and "on/off" for 5 seconds to reset the Pioneer
Mar 05, 2015 | Pioneer VSX-1023-K Receiver 7.1 Channels,...
How too reset pioneer 4800
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button,
press and hold the STANDBY/ON button
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
OK? shows in the display.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
Jun 15, 2014 | Pioneer VSX-819H-K A/V Receiver
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
How do i reset my pioneer vsx 919 ah amp reciever back to its original settings
In the manual, page 72
Resetting the system
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
The display shows RESET? OK.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
Feb 01, 2011 | Pioneer VSX-919AH-K A/V Receiver
Reciever keeps shutting off!
If your reciever is in a tight enclosed space, than it will overheat and shut down to protect itself. Try to get some ventilation to it by either opening the cabinet door, adding a fan, or pulling it completely out of the enclosed space.
Jan 05, 2011 | Pioneer VSX-33TX Receiver
My pioneer vsx-519V-k amp won't turn on. Just bought it about 4 months ago. we were using it with music and a microphone when it conked out and won't turn on anymore. Have checked the power source, the...
Have you checked within the set, the fuse and if the standby circuit is working. thre could be a failure of this sub votage which is required for the switch on of the main power. If you do not have any standby indication you must check this section, however if you arre getting the standby you would have a failed output or a shorting that is triggering the error amp to swtich off. If you are familiar with the circuits you can check but I would suggest that since you will need more experience to look into the main board for tracing the fault. In such case check for the service centre nearest to the place you are in using a google search for Pioneer - Audio systems- sevice. Helpful I hope. Good day.
Jul 06, 2010 | Pioneer VSX-518-K Receiver
Pioneer VSX-815-K receiver with sub in standby
Have you looked in the manual?
No sound from subwoofer. • Make sure the subwoofer is switched on.
• If the subwoofer has a volume knob, make sure it’s turned up.
• The Dolby Digital or DTS source you are listening to may not have an LFE channel.
• Switch the subwoofer setting in Speaker Setting on page 40 to YES or PLUS.
• Switch the LFE Attenuator Setup on page 61 to LFEATT 0 or LFEATT 10.
May 13, 2010 | Pioneer VSX-815-K Receiver
24 people viewed this question
 Grubhead
Grubhead
