Rotel ir codes for uverse - Audio Players & Recorders
I have a 321 bose system, and I cant find the device code for my uverse reciever
there are 8 different versions of the 321 so the code is going to depend on what version you have. Motorola makes the boxes for uverse, so i would start there. some of the uverse boxes use newer codes then what is prestored in the Bose remote. you may have to use the uverse remote and program the Bose volume in it.
please rate if this was helpful!
Apr 07, 2011 | Bose (321GS) System
I can find codes for a black standard uverse remote which is 1040. But I cant find a code for silver standard uverse remote. Uverse says to talk to DYNEX. Can you help?
i currently use uverse and none of there remotes work for dynex tv's i suggest buying the logitec harmony 520 or 420 or above remote from amazon read the reviews there around 40 dollars and lets you control everything and they connect to you pc you just plug in you model number and the remote learns all the commands as well as lets you set up activities that will allow you to control multiple devices without having to switch between hitting the tv button, home theater button, uverse box etc.
hope this helps.
Mar 14, 2011 | Televison & Video
Need a code for att uverse for the remote for vizio lcd
Click Here for the list of Manufacturer's Code for AT&T Uverse
May 13, 2010 | Zenith ZEN700 Remote Control
IR codes for JVC DVD/VCR combos
I can't say specifically if they do or do not; but from my experience JVC uses a lot of similar codes. Even DVD players made by Rotel were re-badged JVCs that used the same codes.
Hope this helps!
Thanks
Jan 20, 2010 | JVC HR-XVC17S
Need remote code for ATT Uverse IR remote for an ESA ET419 TV
hi ! i have a code for your TV hope this would work 1483 goodluck!
Aug 26, 2009 | ESA ET413E 13" TV
Att uverse receiver hooked up to sharp aquos tv, remote quits
first try new batteries and be sure you have pressed the AT&T mode button at the top left of the remote - if you still have issues then on the sharp tv menu - turn off any energy saver mode, Optical Picture Control, taking the picture mode from dynamic or vivid to standard, and if that doesn't work - try changing the backlight settings if your tv has one.
Aug 23, 2009 | Denon AVR-1908
Uverse standard remote control stops working at night
The remote stops working the Uverse box or the TV or both?
Try putting the Uverse box behind the plane of the TV screen so the I.R. that the TV emits doesn't get to the front of the Uverse box.
Mar 20, 2009 | Samsung HL-S5687W 56" HDTV
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
16 people viewed this question
 Grubhead
Grubhead
