Question about Maxdata Pro 650T Notebook
Black window shows just before any file chosen opens
There is always a small black window that pos out right when you open another window .It doesn't last. it will only show for about 2 seconds and then it disapears.
what could this be?
How do I get a photo printed
You will find most printing options are in the menu associated with the actual page that you load your photos on , this can sometimes be a matter of clicking the right mouse button but it will depend on what program you are viewing your photos in , if you had loaded your photos into windows folder called pictures you would click that then open that file and it would show you all of your photos (usually as small thumb nails) and if you click on a photo using your right mouse button it will then show a menu and ask what program do you want to use to open to view each photo "open with " if you scroll to that option the black arrow will show "photo viewer " if you select that option in the top bar above the photo it will say PRINT click on that and follow your way through the options to allow you to print . to sum it up load your photos into windows pictures folder open it click on a photo with right mouse button , open in photo viewer look for print click on that
Oct 26, 2017 | Epson Office Equipment & Supplies
How do I get ride of all WordPad files
WordPad comes as part of Windows, it doesn't really have any files (documents) you can however associate file types to it. .txt and .rft If you want these types of files to open in say word. Right click any .txt file and any .rft file, select Open With, "Choose Default Program", Select Word and make sure "Always use the selected program" is check" and those file types will now always open in Word. If this is not what your looking for please comment back and elaborate on your issue you are having.
Thanks.
Nov 28, 2011 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
How let Lexmark S305 only use black cartridge to print black. Now the color cartridges getting empty by only printing black, and with "only use black ink" selected. (Besides that, the cartridge...
Please follow the steps below on how to print using black ink only on your Lexmark S305 printer:
For Windows:
  1. With your document/file open, click File.
  2. Click Print.
  3. Click Printing Preferences/ Properties.
  4. In the Lexmark S300 Series Printing Preferences window, select print using black ink only.
  5. Click OK to save the settings.
  6. Click Ok again to print your file.
For Mac operating system:
  2. Click Print.
  3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media in a drop down box and select print in black and white.
If you wish to set this as your default print setting, please follow steps below:
For Windows:
  1. Go to Control Panel.
  2. Open Printers and Faxes.
  3. Right-click on Lexmark S300 Series print object and click on Properties.
  4. In the Lexmark S300 Series Properties window, go to Advanced tab. Click on Printing Defaults.
  5. Under Ink Use, select Print using black ink only. Click OK.
  6. Click OK button in the Lexmark S300 Series Properties window to save the changes.
Your printer will print in black only the next time you send a print job to the printer.
For Mac:
  1. With the file (you wish to print) open, click File.
  2. Click Print.
  4. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Note: The 100 standard cartridges yield around 175 ISO Pages. You can also save on ink and stretch your ink investment if you use only 100XL high yield cartridges. These contain almost 3x as much ink as a standard cartridge for a small increment in price.
Aug 07, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
JPG images are not showing and are replaced with a small white square with a red x in the center. How to fix this?
Right click at the file > Open with > Choose default program > Click Windows Photo viewer (or ACDSee) > Check the box below Always open with this.... > click OK.
If this helpful RATE please.
Jan 29, 2011 | Kunaki Computers & Internet
Need color code for kenwood kdc mp 245
black - ground, red - switched or ignition, yellow - constant (memory) power, white - left front spkr pos., white/black - left front spkr neg., gray - right front spkr pos., gray/black right spkr front neg., purple - right rear spkr pos., purple/black - right rear spkr neg., green - left rear spkr pos., green/black - left rear spkr neg, blue - antenna remote, blue/white amp remote turn on.
Nov 02, 2010 | Kenwood KDC-325 CD Player
Hi there when i log into slide show expressions i get a ' black/blank window right in the middle of the title page. pse HELP i need to remove this window
This is quite normal. It just means that no project is opened up yet. You need to either create a new project / slide show or open an existing one. The little black window in the middle is only "reserving" the spot where the chapter icon will appear on your menu page once you've newly created a chapter or slide show. Later on, the little black window will be replaced with one showing one of the photos you have inserted - you can choose which photo you want to display as chapter icon. You can also alter the position of these chapter icons in the "Design" tab.
Aug 17, 2010 | Individual SlideShow Expressions
I need to know wat colours do wat on a kenwood KVT-739 car Stereo DVD player wiring
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Aug 16, 2010 | Kenwood Car Audio & Video
My POS-X XPC500-Series won't turn on. The lights and fans kick on, Genesis logo shows, the a "no signal" shows up on the screen. Then the screen goes black. Any info? Thanks Brian
It is possible that an internal monitor cord got disconnected. You can do a random inspection to see if there is a loose cord once you open up the computer. If you are not comfortable with doing that, then take it to a certified computer repair shop for their diagnosis.
Jan 01, 2010 | POS X POS-X XPC500-Series POS Computer...
Does not display preview of pictures in explorer in small, medium, large icons after update of vista
All you can do is to try to reinstall said update. If you can identify the specific update, try reinstalling it. If not, download and install the latest Vista service pack.
Sep 15, 2009 | Microsoft Windows Vista Home Premium with...
I purchased a used Donnelly 0110103 rear view mirror that has a compass and map lights. I'm going to install it in my Pontiac Vibe that has a mirror with map lights. The Donnelly has 4 wires (the Vibe has...
black=neg
black with slim white=door switch
black with wide blue or wide dark green=accesories(switch controlled pos)
black with slim light green=live pos(always connected for map lamps)
If you wire it as such,map lamps would come on both when you open the door and with doors closed when you turn on the switches.
Apr 23, 2009 | 2005 Pontiac Vibe
Maxdata Pro 650T Notebook Logo
Top Maxdata Computers & Internet Experts
Willem.
Willem.
Sulkhan Abesadze
Sulkhan Abesadze
tim brauer
tim brauer
Are you a Maxdata Computer and Internet Expert? Answer questions, earn points and help others
