Question about Samsung RS267TD
Ice bucket stuck - Samsung RS267TD
Frost builds up on the inside of the ice bucket and the ice seems to be melting together. Water runs out of the bottom of the ice bucket both inside and through the front.
Make sure the ice Chute door is closing all the way usually when you have frost build up in that area the ice Chute door is stuck open and it's going to have to be repaired
Appliance 911 Sea Breeze
Sep 09, 2016 | Refrigerators
My maytag refrigerator crushed ice will not switch back to cubes
Try replacing the ice bucket. That has the teeth and gears that crush the ice up. It could be stuck. If not then there's a solenoid in the back of the freezer that switches the ice bucket from cubed to crushed. You'll see the rod in the ice bucket slides into a square hole that moves up and down. That's it there.
Aug 25, 2016 | Maytag Refrigerators
Why is ice bucket stuck?
One of 2 things happened. Your ice maker overflowed with water and now the bucket is frozen or the ice maker fell into the bucket and it's wedged. If you can get the bucket out at least a inch it's the second problem
Oct 01, 2015 | Samsung Refrigerators
How to release jammed ice maker bucket
you have ice stuck in it . best thing to do so you dont damage it is to defrost it/remove/clean .
Jan 23, 2015 | Refrigerators
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Electrolux ice maker bucket stuck
Probably the ice maker leaking caused by ice maker itself or faulty water valve. I would think you would have to let Ice thaw that's most likely holding bucket from coming out and then replace Ice Maker or water valve or both.
Aug 23, 2017 | Electrolux Refrigerators
Ice and water dispenser: set on cubed ice, but continues to dispense crushed ice?
Actuator solenoid in back behind bucket stuck. pull down and make sure bucket flip rod inserted.
Aug 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
I HAVE KITCHENAID SIDE BY SIDE REF. THE OUTLET OF ICE BUCKET FROSTS OVER , NOT ICE.
Hello, Thank You for using FixYa. I will be helping you today. Sometimes ice gets stuck in the ice door causing it to build up frost and ice. When this happens the bucket gets stuck and wont come off. Using a hair dryer and melting it is the way we get them off. This is a common issue. Removing the ice bucket one time a month and running hot water through it and clearing any frost in the chute usually prevents this from happening.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Samsung RS267TD Logo
27 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
