Question about HP Computers & Internet
Display adapter for intel 82945 GME internal graphics A3
Maanita
  • 1142 Answers
SOURCE: Intel(R) 82852/82855 GM/GME Graphics Controller
Your solution is here
Device drivers for Sattelite A15S-129 is similar ti 127
Posted on May 26, 2008
Geekman
  • 32281 Answers
SOURCE: looking for intel(R)4 series internal chipset
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link :- http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a folder on C:\drivers Then install the various drivers from this folder.
Posted on Aug 27, 2009
todd0708
  • 247 Answers
SOURCE: latest graphics driver for Toshiba a55 s1063
run the update utility,be sure to allow active x control to run when drop down box appears say run,otherwise it wont work follow this link to get started
http://www.intel.com/support/graphics/detect.htm
hope this helps,aloha from maui todd0708
Posted on Oct 22, 2009
  • 10406 Answers
SOURCE: I would like to hook a flat screen tv up to a Dell
Most laptops have a video-option:
* output only to the internal screen
* output only to the external screen
* output to both screens
Set your screen-resolution to 800-by-600, which your TV should support, and then "toggle" the option to choose "output to both screens'.
Posted on Jan 02, 2010
rajendrasngh
  • 393 Answers
SOURCE: emachines t2682 upgraded from XP to Win 7. Windows
Windows 7 driver are not available for your PC.
You can use XP driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select XP
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
Posted on May 24, 2011
I have acer aspire 4315 intel graphics external display working internal display not working
You can eliminate Graphic Adapter. So the things to check are, Monitor, backlighting, inverter, ribbon cable, on the rear of the monitor, pinched wires, on/off switch, that controls the backlighting when the lid is opened or closed. Here is a video that may give you some ideas: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Jan 11, 2013 | Acer Aspire 4315-2963 Notebook
My notebook is acer travelmate 4000. I connected the external monitor with vga port but the result is blue on external lcd TV. I did the step for display setting but I could not find the dual monitor in...
Please try to configure to the graphic Properties.
found at the task bar or at the control panel.
Enter to the device and set use Multiple Display.
This feature available to the Inter (R) Extreme Graphic.
Jul 13, 2011 | Acer TravelMate 2300 Notebook
I want graphic for intel d845epi/d845gvsr motherboard
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if your computer came with a motherboard disc the drivers could be on it
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/%7Bvalue=http://www.download.com/intel-r-82852-82855/3000-2098_4-94913.html
Intel(R) 82852/82855 GM/GME Graphics Controller:
The Intel 82852/82855 GM/GME graphics controller is the display adapter component of the Intel 852GM chipset. The Intel 82852/82855 GM/GME graphics controller, combined with the Intel Extreme Graphics Driver allows the output of high quality 2D/3D video and graphics to the monitor . hope this helps
May 19, 2011 | Intel D845GVSR Motherboard
I have an HP Pavilion dv1000 that I upgraded to Win 7 and the only thing that I can not find a driver that will install is the video controller. Has anyone found one that will work with laptop? Any help...
The video chipset for that model seems to be the Intel 82852/82855 GM/GME Graphics Controllers Driver, which you can get from the Intel website. Windows 7 should also have a built in driver for that as well, since that chipset is very common.
Downloads at:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Laptop+graphics+controllers&ProductProduct=Intel%C2%AE+82852%2f82855+Graphics+Controller+Family
Mar 22, 2011 | HP Pavilion dv1000 Notebook
My Onboard display just stopped working all of a sudden and all i did was unplug the monitor cable in and out. The pc works fine wen i put an other card in so the problem is definately the onboard display....
This is most likely a setting for your motherboard that has changed: go to your CMOS setup/configuration options and select the primary display adapter as your onboard/internal adapter.
In general, taking the external video adapter out will force the motherboard to revert to the internal adapter: try this first and during the boot sequence hit the function key that will get you into the motherboard Setup options.
Hope it helps.
Jan 22, 2011 | Intel Computers & Internet
I would like to hook a flat screen tv up to a Dell latitude D505 laptop with an Intel 855 GME graphics controller. The TV screen is black. I have the latest driver. What can I try?
Jan 02, 2010 | Dell Latitude D505 Notebook
What graphics adapter upgrade do I need to make
Hi.
The graphic adapter is the video card installed inside the laptop, and normally does not get replaced, as this is integrated with the motherboard.
After installing Windows 7 you will need to install all drivers.
I would recommend using Vista on this laptop, since factory drivers for Windows 7 had not been released. You will have to install general drivers not designed for this laptop.
If you want to install Windows 7 here you get the instructions.
I quote the part concerning video adapter drivers:
"Update the Video Driver
  1. Preparation
    1. Be sure there are no other video drivers installed (you will want to start out with just the standard VGA driver)
    2. Download the latest 82852/82855 drivers from Intel's website
    3. Extract the drivers somewhere, but do not install anything
  2. Turn Off the Digital Driver Signing Check
    1. Create a shortcut on the desktop to cmd.exe
    2. Right-click on the shortcut and select "Run as administrator"
    3. When the command window opens, execute the following commands:
      1. bcdedit /set nointegritychecks ON
      2. bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS
    4. Reboot
  3. Install the Video Driver
    1. Open the Device Manager
    2. On the menu, go to Action > Add Legacy Hardware
    3. Acknowledge the initial dialog screen
    4. Select "Install the hardware that I manually select from a list (Advanced)"
    5. Click Next
    6. Select "Display Adapters" and click Next
    7. Click the "Have Disk..." button
    8. Navigate to the path where you extracted the Intel drivers. The *.inf file will be in the Win2000 folder
    9. IMPORTANT: Do not select the 82852/82855 GM/GME drivers, select the 945GM driver (yes, this is counter-intuitive)
    10. If prompted to reboot, DO NOT REBOOT
    11. If told the 945 device might not work right, acknowlege the error, then run Action > Scan for Hardware Changes
    12. "Intel(R) 82852/82855 GM/GME Graphics Controllers" and a "Mobile Intel(R) 945GM Express Chipset Family" devices should now be listed under "Display Adapers
    13. Disable the 945GM device
    14. Reboot
  4. Verify the Video Driver Installation
    1. Upon rebooting, Windows 7 may roll back one or more of your display devices to Standard VGA
    2. Open Device Manager
    3. Check the Display Adapters
    4. If there is only one 82852/82855 GM/GME device, or if there is a new "unknown" device, precisely repeat the above driver installation section (include the instructions for disabling the 945GM device); in the case of an unknown device, run the "Update Driver" action for that device instead of running the generic "Add Legacy Hardware"
    5. When everything is working, you should have "Graphics Properties" and "Graphics Options" menu items in the pop-up menu when you right-click on the desktop
    6. The "Graphics Option" item should have sub-items for display rotation
    7. Reboot and verify that Windows 7 no longer rolls back your display drivers after rebooting
  5. Protect the Video Driver Installation
    1. Go to Control Panel > System and Security > Windows Update
    2. Windows will likely tell you that an important update is available
    3. Click the "important update is available" link (do NOT click "Install updates")
    4. Right-click on the "Intel Corporation - Display - Mobile Intel(R) 945 Express Chipset Family" update
    5. Click "Hide update" from the context menu
    6. If the display driver gets updated to what is currently on Windows Update, the system will revert back to the Standard VGA driver.
  6. NOTE: When using a driver install hack different from the method described here, I have read reports that a system might Blue Screen when using Windows Media Player to play DVD's; however, alternate media players, such as VLC, reportedly do not exhibit this issue. I do not know if this method will have this same problem, but I thought I would mention this workaround in case someone does experience this issue."
You find driver software at Intel Download Center
Regards.
Oct 26, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Latest graphics driver for Toshiba a55 s1063
Oct 22, 2009 | Toshiba Satellite A55-S1063 Notebook
Drivers for vista
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
69
Jan 18, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
102 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
