Question about Canon MultiPASS MP390 All-In-One InkJet Printer
For a while the black ink wasn't printing and only the color... and because I was not able to print using black ink, I stopped using printer, and now color doesn't even work It just prints blank pages. What's the prob'
  • amarie145 Apr 28, 2009
    I have a Canon MP390 that has suddenly decided to stop printing anything on paper. It goes through the motions, but nothing shows up on the paper! We've tried everything - blowing through the top, cleaning the print head, replacing cartridges, soaking in hot water, soaking in alcohol.....nothing has worked.
    Is there any hope, or should we just resign ourselves to having to buy a new printer?
    Any help would be greatly appreciated.
    Thank you!
    I have a Canon MP390 that has suddenly decided to stop printing anything on paper. It goes through the motions, but nothing shows up on the paper! It seems like we've tried everything - blowing through the top, cleaning the print head, replacing cartridges, soaking in hot water, soaking in alcohol.....nothing has worked.
    Thank you!
The print head is clogged. I had the same problem with only the black ink. I tried to soak it over night and let it sit on a paper towel soaked with windex. this didnt work so I figured it was time to replace the printer as the print head was probably just as expensive as to buy a new one. So with nothing to loose I got out my trusty can of WD40 removed the print head, removed the ink cartridges from the heads, sprayed the bottom and filled the top where the ink cartidge sits and within 15 minutes the WD40 began to flow on the paper towel. After a while I cleaned out the excess WD40 and replaced the cartridges and head to the printer and it worked perfectly. Good Luck. You have nothing to loose.
Joe B
Posted on Feb 02, 2009
My Epson Workforce 1100 suddenly stopped printing black when printing in color. This happens when printing from Microsoft Word, Wordpad, Lightbox (photo manipulation) and Adobe Reader. It prints black...
normally most printers even like mine an epson NX110 will use color then black when using text but with grayscale only your forcing it to use black ink more and no color ink set in normal mode some color ink does get used ironically but it is normal for it to use color some as it reserves the black ink being used
Apr 22, 2017 | Epson WorkForce 1100 Wide-Format Color...
My color inks are out of ink but still in the printer...i just replaced the black ink. when i try to print, it will not allow me and says to replace the color inks first. i followed the instructions to...
The Lexmark Impact S305 printer requires all the cartridges to have ink in them to continue printing - even if you're printing using black ink only. To print true black, you actually use some of the color ink.
Note: Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality if you want to print color in the future.
Sep 23, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Printer will not print in color
try to check  the printer setting of your printer maybe it enabled the black color printing setup in your printer. Then try also to remove the color ink cartridge then installed it back and try to print it again.
Jun 19, 2009 | Canon i860 InkJet Photo Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
PRINT IN BLACK WITH COLOR CARTRIDGE?
Yes, you can print out in black from a color cartridge, however it is not advised as you will run out of colored ink twice as fast as it combines all the colors to get black.However it works great when your in a pinch and need black ink.
Just go to your printer properties when you print and the option will be in there someware.
Dec 26, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
218 people viewed this question
old marine
old marine
