Question about Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive
How to enable WI-FI function on Compaq Presario 2500 lap top.
Just purchased Bt Home Hub and it states I need to turn on wireless using switch or sortware. I have tried using the wireless network set up wizard but it doesn't apear to have done anything. when i go in to wireless configuration, the screen is blank for devices to switch on. On do not have a flash card for the recommended set up in the wizard.
How do i turn on the wireless connection to enable me to use BT Home hub
    Problem Solver:
  • 11 Answers
Go to "network connections"
It should say Local Area Network and Wireless network (if your card is installed properly). Right click the Wireless Network and make sure it is enabled. Then click "View Available Wireless Networks" and choose your network.
If you are trying to setup a secure wireless network, that may be a completely different issue.
Posted on Feb 27, 2009
I want to change from a bt voyager 105, to a bt home hub how easy / hard to do I am not really computor minded. telboy..
It is not hard just you need to reconfigure your router WAN settings.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 01, 2010 | Computers & Internet
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
The wireless function on my HP Entertainment PC is not working. The indicator light is orange. The diagnostics state there is no network to connect to; that is untrue, since I am using another older HP...
First check in your laptop that wi fi switch is turned on.
Check your wi fi network adapter driver are installed correctly and enabled.
Then click on wi fi connection icon and then check for network .
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | Computers & Internet
Just got bt wireless broadband but computer will not conect via wireless. computer only 4 years old thought it would have had wireless mode built in??
First check in your router your wireless option WI-FI is enabled.
Then check in laptop Wi fi driver are instaler and working properly.
Also make sure your wi fi is enabled in network plces property and wi fi switch on laptop is turned on in laptop.
Aug 07, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Wi fi
Could you make sure that wifi switch is turned on.
This will be physicall button on the laptop of function keys combination that enables wifi.
If wifi switch is on you should be able to see wifi networks in range. IF you see networks but can not connect this will be network security issue. MAke sure that wireless network router is properly setup and security key you enter is correct
Jun 08, 2009 | Compaq Presario 700 470024-192 Notebook
Cant enable wi-fi
You will need to check that the router is on first, then go to the internet settings on your computer, if the wi-fi doesnt show up try and SCAN so your computer will look for it. When it is found you will need to give it a password and then its ready to go
May 20, 2009 | Compaq Presario 700 470024-192 Notebook
How to enable wi fi on compaq presarion F500 using Vista
start-controlpannel open
network connections-wireless netwoking open
next
network name(ssid)-enter your router network group name
next
ok
Feb 24, 2009 | Compaq Presario 700 470024-192 Notebook
How to turn on wireless on Acer Aspire 4520 laptop
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Sep 04, 2008 | Computers & Internet
Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive Logo
4,785 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
