Question about Acer Aspire 5580 Notebook
No battery recognized
I have an Aspire 8930 and the battery logo on the desktop shows that there is no battery, upon clicking it it sais no battery detected.. i had the battery replaced and still nothing .. it works fine when plugged into an ac adapter but the minute it is pulled it shuts off the laptop.. so it not only does not recognize that there is a battery it also does not charge it .. what can i do, ? is it a software issue or hardware ?
    Novelist:
  • 117 Answers
Could be both. first go to the website for support and download the latest bios flash. flash your bios and see if you get your battery back. i have seen this issue appear before on HP units and the only solutions were update bios, if that didnt work. replace motherboard.
Good Luck!
Ruben
Posted on Jul 19, 2009
Cant find scanned document on my Aspire how do i find?
Going with it's an Acer Aspire 5315 Notebook PC, which according to Acer Support comes with Windows XP (Home or Pro), or several basic versions of Windows Vista,
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5315/Aspire5315sp2.shtml
WinXP:
1) Desktop screen
2) My Documents; Click on Start, then on My Documents
3) Downloads; Click on Start, then on My Documents. DOUBLE-click on Downloads.
Win Vista:
1) Desktop screen
2) Documents; Click on the Windows logo button, then on Documents
3) Downloads; Click on the Windows logo button, then on Documents. Then click on Downloads.
Anyway you can try scanning a document again, and see where scanned files go? Then delete the scanned file.
Look at the window, and what is stated at the top. This is where the scanned file will go.
Regards,
joecoolvette
Oct 27, 2012 | Acer Aspire 5315 Notebook
My acer aspire 8930 suddenly stopped charging the battery. We put it in my husband's identical laptop and it charged fine. I researched on net and using info found, turned laptop on with battery r
Just because all systems look go. Does not mean the power cord is working correctly and the charging portion of the power supply unit may not be working you will still be able to power the computer on but not charge replace that unit and you should be back up and charging again. You know it is not a battery problem it is the cord and component due to your test. Makes sense to me also one other factor to consider, the battery may be charging but will not hold the charge be sure to fully charge the battery and see how long it takes to drain down. Just a suggestion. John
Apr 14, 2012 | Acer Computers & Internet
When i press the power button the VAIO logo shows then a Intel logo after that there is just a blank screen and windows wont load. what should i do?
Upon starting go to bios settings, click "F2" to access the bios, go to to exit, choose "Default Maximum setting", save upon exit....restart.
Hope that helps you out, msg. me is there are still problems.
Thanks for asking FixYa!
Aug 15, 2011 | Sony VAIO VGC-RA840G PC Desktop
I have a aspire 5610 , the problem is when the laptop coming up just showing windows logo and after that nothing , i did try with monitor and thats showing same thing , i want to know the problem is with...
If you are seeing the same thing on your Notebook screen and an external monitor then it is most likely NOT the monitor, and VGA would be more suspect. Before doing much else though, right click a blank spot on your desktop and click "Personalize"; go through the various video items there to try to make things more useful. Let me know, OK?
Dec 02, 2009 | Acer Aspire 5610-4648 Notebook
Product Code for Acer Aspire Laptop 8930
on the back of your laptop should be a sticker with the product code on it
Oct 27, 2009 | Acer Aspire 3680 Laptop
Acer Aspire SA85 stays on Acer logo
Hi bob,
Usually system stops at the startup screen or the startup logo, when it finds some fault in detecting the IDE drives(ie,your harddisk or cd drive), if you dint get any get stuck in the logo, you have to see what happens at the background by clicking on f1 key or f12 or TAB or some key to show the activity rather than logo.....
After seeing the error we can conclude or decide about the problem, but when you were not able to see the screen after pressing any key as specified in your manual, Or it hangs after the LOGO screen, this must be problem with your harddrive, try changing the harddish or try connecting once again by removing it...
Enjoy Rate!
RNJ VINOD KUMAR
Jul 01, 2009 | Acer Computers & Internet
Acer Aspire 8930 windows premium loses network/win exe
No, it is not a hardware error, it is purely software, i would recommend, trying to turn off your network\wireless adapter by switch, and then turning it on after a min or so.
Good luck
Jun 19, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Problems with signal connecting my acer aspire 8930 to lcd tv
check the cable and display setting of the graphic adapter
Jun 12, 2009 | Acer Aspire L100 PC Desktop
I've lost my toolbar on my acer aspire one netbook
Press and hold Windows Logo Key + Press the "E" key
Type Control Panel
From here you can address your Display and Taskbar issues.
For the task bar:
Click on Taskbar and Start Menu Properties
Uncheck Lock the taskbar, Auto-Hide the task bar, and then click apply and ok
For the desktop icons:
Click Display
Click the Desktop Tab
Click the "Customize Desktop" Button
There you can place a check next to the icons you wish to show.
Let us know if you have any issues after changing these settings.
Apr 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer usb cam makfunctioning
try consulting the mfg for updated drivers. Try removing the usb port it's using and letting it redetect the port, also see if there is special software that comes with the usb camera and reinstall that. If all fails reinstall windows.
Nov 19, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5580 Notebook Logo
448 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
