Question about Pentair Pool & Spa
Pentek pentair water pump saver by symcom
How to restart
Well water pump won't stop running
if it is a submersible well pump it could be crack in your line leading to the bottom of your commercial welcome and called it to leak water and still feel pressured
if it is a submersible well pump it could have a crack in the line leading to the summer double well pump in the ground it will cause it to leak but the tank will still be build up pressure
Jan 10, 2015 | Pentair Water 123324 1hp Submersible Well...
I overfilled my pool and need to drain the excess
if you have a sand filter. you can economize and perform a long backwash cycle. this will clean the sand and lower the water level. otherwise, just use the drain/waste option. if you have a cartridge filter, your manufacturer should have installed a three way drain valve between the pump and filter. by turning this valve, the water will be diverted from the filter to waste
Sep 29, 2014 | Pool & Spa
My pentair 2 hp challenger pump turns off after 4 second
since it's a new install is voltage set correct on motor ? this seems possible due to short run time you report
May 04, 2014 | Pentair 2 hp Challenger Pump
Pentair chlorinator tablets not dissolving. Also the dispenser tube loses water level when pump is down.
make sure water is running into unit take off top see if water rises run about 3.5 let water rise then close top
Aug 08, 2013 | Pentair 2.0 Hp Whisperflo Pump
Pentair pump flow slows during operation
go to utube see the video on your pump programming sounds like you have the run time on 1200 rpm
Nov 17, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Do I need a pressure tank with a Pentair Water 3/4Hp Pres Wtr System 3075Ss Utility Pumps?
Depends on your application. If you are using it to provide water to a residence or other on/off use, you need a pressure tank and a pressure switch to control it. If you are filling a open air tank, no pressure tank needed. If you are just pumping water out of a well and directly to an ditch type irrigation system no tank needed.
Aug 09, 2012 | Pentair Water 3/4Hp Pres Wtr System 3075Ss...
My Pentair legend isn't picking up debris like it
You will need to take the unit apart and useing a wire clear the jets in the throught then flush with good pressure water. Check your filter to see if it is passing derbs. Also check your finger screen at the wall in the hose connection.
Jul 06, 2010 | Pentair White/Gray Legend Platinum...
My pump will stop and restart a few minutes later during its programmed run time, during warm and cold weather, the pool water is in the 50's.
With these pool pumps, it is probably either that you are getting air pockets or leaks in the suction line or your pump strainer is clogged.
Mar 01, 2010 | Pentair Wf 6 1.5hp Whisperflo Inground...
Water flows out the flange where the motor
dont no were you are,but did it freeze,loose,gasket trouble,is the centre housing cracked?
Dec 08, 2009 | Pentair Pinnacle 1 1/2 - Hp In Ground Pool...
Pool & Spa Logo
54 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
