Question about Compaq Presario 5000 PC Desktop
PC DO NOT BOOT
Compaq Presario 5000 no booting, p/supply run, cpu fan running hardisk run but it is formated (empty) , monitor display his setting page; no black or blue page.
  • 1 more comment
  • Anibal Arcelay
    Anibal Arcelay Jan 29, 2009
    IT`S OK BUT THE OTHER PROBLEM IS THAT THE MONITOR HAVE NO SIGNAL NEITHER A BLACK DISPLAY JUST THE MONITOR SETTINGS, DO I NEED TO INSTALL A VIDEO CARD? HOW WITH NO OS ???? THANKS AGAIN FOR YOUR HELP
  • Anibal Arcelay
    Anibal Arcelay Jan 31, 2009
    IT WAS WORKING GOOD, AND THE NEXT DAY MONITOR DID`NT HAVE SIGNAL JUST SHOW IT SETTING IMAGE; EVERYTHING IN THE SYSTEM SEEMS TO WORK GOOD; NOW IN THINKING IN MOTHERBOARD BUT DON`T KNOW HOW TO TEST, I HAVE A PCI CARD TESTER BUT I`M CONFUSE WITH IT FUNCTION DONT UNDERSTAND IT... THANKS FOR YOUR ATTENTION
  • Anibal Arcelay
  • 58 Answers
It seems that you don't have any Operating System installed. You need some bootable OS setup disk, and change BIOS settings to boot you PC from CD. Insert disk and restart PC, then follow onscreen instructions to setup OS.
Posted on Jan 27, 2009
  • PC fix Jan 29, 2009
    Was it working before, what happened!
    Video card don't need any additional installation, it should be detected even if you don't have hard disk!
Why compaq presario SR3270nx won't boot but fan runs?
Hello There "A"
Usually PCs that won't boot its for any of these reasons:
1) Voltage on outlet check this*
2) bad Power Supply.
3) bad RAM
4) any near CPU capacitors, on the motherboard.*
Carl
May 04, 2014 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Will not boot,,,nothing appears on monitor
Does it have any power at all? Do any lights come on? Does the fan come on for the power supply or the CPU? Any beeps heard? Did it run properly before or is it a new build?
Please provide more details.
Jan 23, 2011 | HP Compaq Presario SR1211NX (829160534404)...
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
My PC won't start? every time i start it the fan just spins fast and loud and nothing happens, the screen doesn't show. this happened when i took the PC apart. it a Compaq presario sr1610nx
Initially test the monitor in another pc, if display available use the monitor in Compaq presario sr1610nx. Load to BIOS by restarting and tapping F1, if the display available, the computer is ok. restart and tap F8, if the advanced boot option screen comes up, the software is ok.
Restart the computer and tap F10 and proceed with a destructive recovery to reload the operating system on the computer
May 07, 2010 | Compaq Presario 5000 PC Desktop
Hello i have a compaq presario 5000 when i turn
This is a compicated problem. First when it boots enter setup by pressing the F10. Once you are in set up reset all settings to default. Save changes and exit CMOS. If that does not help the situation have someone make you a boot disk, reenter setup and put the floppy as the first boot drive and then CDrom. Insert the boot disk, follow the instructions to boot. Once you are up and running try to roll back the computer to the last recovery point that worked. If that does not work you may need to see a local repair tech.
Feb 04, 2010 | Compaq Presario 5000 PC Desktop
Compaq presario 5000 desktop won't boot!
oh that means you have a power failure so you have to take it for a repair
Sep 24, 2009 | Compaq Presario 5000 PC Desktop
Changed power supply now it does not read monitor mouse or keyboa
Try re-seating all of the cards and memory in your PC. Unseated cards are usually the #1 cause of PCs not booting.
Mar 10, 2009 | Compaq Presario 5000 PC Desktop
Will not boot but runs and will not talk to monitor
hi mikebal26 this is nichu,ok let me make you clear that your system is not booting because your cpu is not recognising some of the hardware it may be either your hdd,ram or any other.
if your system does not boot it has nothing to do with your monitor and fans.fans keep rotating whenever you switch on your pc.check inside the cpu especially with your ram .
so first when you turn on the system press delete to check it in the bios settings , in that check bootable addins and in the bootable devices set
1st priority to-cd rom,
2nd priority to hard disc drive,
3rd to priority to floppy drive.
.save the above settings and then boot this will turn on your system .
this will solve your problem
bye,
take care & have a nice day.
Nov 12, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
141 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
