Question about Hunter 28096 Westminster 52" Ceiling Fan with Light
Remote required to turn on light but fan turns on with light switch
I pulled the chains to have the light and fan on and used the remote to turn the fan off before turning off the light switch but when I flip the light switch on the fan is running and I have to find the remote to turn the light on. This is very annoying because it is the main light as I come into my house and I have to find the remote in the dark. Plus I am bound to lose the remote sooner or later. Was it wired wrong?
    Top Expert:
  • Hunter Master
  • 34,763 Answers
Before you conclude the fan was wired incorrectly, try this:
1. Shut off power to the fan (at the circuit breaker)
2. Remove batteries from the remote and press all the buttons to eliminate the possibility of a stuck button. Reinstall batteries
3. Turn on power to the fan and try operation
Posted on Jan 23, 2013
Casa Vieja ceiling fan w/remote; worked well. Then wall switch was turned on/off, chains pulled. Everything working: fan high, med and low, and light on/off/dim - except now fan won't turn off !
The chain pulling and switch flipping causes the simple logic in the remote receiver to become confused. Your only hope for restoring normal operation (short of replacement) is to disconnect power at the source, then remove remote battery and press all buttons to eliminate "stuck button" problem. Reconnect power and test operation using only the remote. If normal, you will have to decide whether to disable pull chains, wall switches, or both. If not normal, you will have to try an infinite number of combinations of pull chains, wall switches, and power on-off to get things back to normal.
Aug 11, 2016 | Casa Vieja Dryers
Fan buttons work the light. Light button does nothing. No button causes fan to operate. What's wrong?
If there are pull-chain switches on the fixture, their operation may have caused remote control to fail. Turn off power at the source, pause for a few minutes, and turn on power. Either fan or light control, or both, may work. If not, you will have to figure out which pull-chain operation makes things right again. To avoid future problems, disconnect the pull chains at the link so only the remote controls operation.
Apr 17, 2016 | Hunter 27185 Fan Speed and Light Control,...
Can't turn off fan when light is on
Not sure, but if its a new installation, I would say that the wiring has been done incorrectly. Ceiling fans with lights should be able to work independently. both on / off or 1 on, the other off.
Feb 22, 2014 | Televison & Video
Hunter ceiling fan light will not turn off when I pull the chain. No remote. I replaced the switch, thinking that was the problem, and still the light won't turn off. I have to keep the lights on if I want...
Make sure it's wired correctly to the fan.The light should turn off when you pull the chain weather you have a remote or not. Also the model of the fan should be 5 digits starting with a 2.
Aug 31, 2013 | Hunter Ceiling Fan Remote Transmitter...
Craftmade Ceiling Fan Problems
Make sure your fan is on high with the pull chain switch. Push the remote Hi button then pull the chain until it's on the high speed, Then DO NOT use the pull chain. Same with light , Push light button on remote then pull chain until it's on then leave the chain alone. If that doesn't do the trick then you probably need a new receiver.
Jun 15, 2013 | Craftmade International CXL52 Electric...
Non responsive light or fan
Oh, that fan problem. Just for luck, remove the batteries from the remote and press all of the buttons to eliminate a stuck button as a possibility. Next, go to the source of fan power (breaker or fuse) and turn it off. Do not mess with any switches or pull chains. Turn on the fan power and try the remote. Make note of this procedure because you will have to repeat it whenever you have a power outage or you mess with the switches or pull chains trying to solve the problem
Apr 25, 2013 | Casa Vieja Probe Brushed Nickel Ceiling...
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Why won't my remote for my light on the Hunter fan work? The light also will not come on when I pull the chain.
I usually discuss this exact problem with customers that have a DIY ceiling fan. First; If you just installed this fan you noticed that there are several switches on the fan and on the remote, there is also the switch that originally controlled the ceiling light fixture (If it is a dimmer switch, it MUST be replaced with a single pull switch). All of these can be set wrong. Make sure the circuit breaker is not "tripped."
To start easy; assure that the wall switch is on, (leave all the "pull chains" alone, for now) Check to see that the remote has fresh batteries. press the light switch (on the remote, if it is a dimmer type set it to high, press it several times. If this does not work leave all the switches where they are and pull the light chain once, and again try the remote for the lights only. Hopefully that worked. Now do the same for the fan, press the remote once (on any speed) If that does not work pull the fan chain once try the remote again pressing the same switch, that should work. Now that you have it working remove all the pull chains, so it won't get "confused" again. Good luck!
Feb 09, 2011 | Hunter 27185 Remote Control
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Fan stopped working and light now only works on pull chain
there should be a remote inside of the fan that probably went bad
Sep 05, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hunter 28096 Westminster 52" Ceiling Fan with Light Logo
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
