Question about Philips Magnavox TS3260C 32" TV
Picture too big for screen
THE PICTURE IS TOO BIG FOR SCREEN. CAN'T ADJUST PICTURE SIZE
SOURCE: Picture size too large
We have the same problem with the same model. We already had the main board replaced. The picture has gotton so bad that you cannot adjust the pixels anymore. Well, you could never get to the pixels that were off the screen because the picture is too big
Posted on Jun 28, 2007
MikeNJ1964
  • 398 Answers
SOURCE: big black box at top of screen
If you mean that a black box appears on the screen, and you can still see the picture around the box, it means that your closed captions are on and set to TEXT. If this is the case, enter the menu, navigate to the closed captions page and set the captions to OFF. If you mean that the top of the picture has collapsed down, the vertical circuit has stopped working correctly and the set should be serviced by a qualified tech.
Posted on Sep 15, 2007
wyoed1
  • 211 Answers
SOURCE: double picture/red shadow
You may need to sinlpy adjust the convergence. Check your owners manuel for the proper way to access the convergence screen and follow it step by step. If this doesn't work, you may have a bad convergence chip. Here is my generic post for convergence.
You most likely have a convergence chip bad. In our shop, when we are working on projection TVs, we find that about 80% of the repairs we make are the same problem you are having. You need to replace the convergence chip ( there are 2 of the same chips on the convergence board, and I suggest you replace both ). If you are going to attempt the repair yourself you'll need to remember to use lots of heat sink grease so you don't have the same problem again. Also, try to get original parts, as there are times that the after-market ones don't work well. As a precaution, always remember to unplug the set from the wall before you do any work on the set. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
SOURCE: Philips LCD picture too big
depending on your cable syayem there might be an easy solition right on your remote or as a setting in your box - they have zoom settings also that seem to superseed all settings your TV has
Posted on Apr 25, 2008
Ecollier2012
  • 3459 Answers
SOURCE: philips big screen tv
I had the exact same problem. No audio or video. You can get tips and repair kits at www.magnavoxhelp.com
Posted on Jun 24, 2008
Picture size is to big how do i adjust it
check power supply volt is normal
if abnormal picture size is big
check vertical filter,preset, ic &yoke
Mar 25, 2014 | Sylvania Televison & Video
Philips magnavox 6P6030 W101 picture is too big and can't see the outer edge of the full picture
Not easy with a older set----look to see if a physical control exists in the set for Vertical size (picture too tall) and the adjustment may only exist in a hidden on screen menu.
Jun 11, 2012 | Televison & Video
Picture to big for screen
check the screen aspect. The picture has different setting that you can use. You might have your tv on a strech screen.
Feb 24, 2012 | LG 42LD520 42 in. HD-Ready LCD TV
The picture is too big for the screen. how can i make the picture match my screen size?
Posting the model number would make a response more valid but you need to go through the main menu selection and check to see if you can alter screen resolution or geometry there.Most sets offer different views such as 'Panorama,' 'Full screen,' etc.
Nov 21, 2011 | Sanyo Televison & Video
The picture is too big for my TV screen. How do i adjust the picture please.
PICTURE SIZE ON THE REMOTE IF CONNECTED WITH ANTENNA OR ORDINARY CABLE
OR THE PICTURE FORMAT CONVERTURE THAT COMMEC WITH YOUR DECODER THERE SHOULD BE A BUTTON ON THE REMOTE TOP CHANGE FORMAT
Feb 27, 2011 | Televison & Video
The picture is bigger than the screen... Picture is cut off and when I unscrewed the back of the tv I could see that the picture was showing perfect but it was to big for the screen... There's not a way to...
Have you tried hitting the format picture button on your remote control. Seems the picture is in zoom mode. If you have a cable box for HD Channels then look on the remote for a button (format) or Screen size.
Nov 11, 2009 | RCA P52960 52" Rear Projection Television
Picture too big for screen.
go to menu and adjust screen size(picture size)
Jul 29, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
you need to go into the picture menu, and play around with the screen size options.
Jul 12, 2008 | Televison & Video
Did you try chaging the aspect ratio in the setup menus yet?
Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
Philips Magnavox TS3260C 32" TV Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
