Question about Sanyo Office Equipment & Supplies
Sanyo cxzr projector shuts down after 5 minutes
Projector turns off during show
  • 7 Answers
SOURCE: Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
  • 6 Answers
SOURCE: Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Posted on Apr 01, 2009
projdoc
  • 2237 Answers
SOURCE: InFocus LP120 Projector shuts off automatically
overheating or power supply problem.
Posted on Sep 03, 2009
projdoc
  • 2237 Answers
SOURCE: my benq projector turns on for a few minutes
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Posted on Nov 30, 2009
Why Projector shuts down after turn on after a minutes ? and shows Temp LED and Lamp LED?
the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Aug 07, 2014 | Acer EY.JBY05.005, X1110, X1110A, X1210,...
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
I follow the set up proceedure to connect the projector to my acer laptop. I then switch on power to the projector and boot the laptop. After the 30 second count-down I et a no signal message which stays...
Not wishing to show Grandmother how to **** eggs, but there are three VGA sockets. One of them is VGA out.
Can you select the inputs on the menu system?
Hope that helps.
Feb 23, 2011 | Sanyo PLC XU30 Multimedia Projector
Lamp for PLV-Z2000: Hello , I have a Sanyo Z-2000 projector. Aft...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 12, 2010 | Sanyo Lamp for PLV-Z2000
Sanyo xp-56 overheating with all air intakes clean
You have thermal protection issues.
On some projectors, once the thermal protection has been activated once, it will activate again at a lower temperature!!!
Inside your Sanyo there are several temp sensors (they are actually temperature-sensitive resistors, called thermistors). I have seen this many times as an electronic technician working on multimedia projectors. For the techs out there, they are actually NTC thermistors (NTC= negative temperature coefficient, meaning as temp goes up resistance goes down).
Once a thermistor has activated to save your machine form heat damage, it may activate again at a lower temperature. The only solution is to take your projector to an authorized Sanyo warranty repair depot, and have the thermistors replaced in your machine.
Typically, there is a thermistor to monitor lamp temperature, and a thermistor to monitor optical block temperature. Better quality machines may have more thermistors, some machines only have one to monitor the lamp temperature.
Mar 29, 2009 | Sanyo PLC-XP56 Multimedia Projector
Projector overheats after 30 minutes and shuts down
Is the fan in your projector still working in high speed or not spining?
Dec 15, 2008 | Sanyo PLC-SW30 Multimedia Projector
SANYO PLV-70 - powers up for approx 5 secounds and then turns of
we had this problem and it ended up being that one of the fans under the lens assembly was not working, causing the system to shut down when it tested it at startup
Dec 11, 2008 | Sanyo PLV 70 Multimedia Projector
Shuts off
projector turns off after 30 seconds problem solution
Sep 16, 2007 | Sanyo PLC XU35 Multimedia Projector
87 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
