Question about Canon imagePROGRAF W8400 InkJet Printer
Error E02D01 As soon as the printer is done loading paper, it throws an E02D01 error code.
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: uneven paper load. error 5100
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Had paper jam which have cleared. Getting support code 6001 saying turn off and restart which we have done but still keeps coming up with same error
The 6001 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
Aug 24, 2016 | Office Equipment & Supplies
Error code - Different paper size is set. Check paper size
turn the dial on front of paper cassette to match paper size in the cassette
Mar 04, 2015 | Kyocera FS-2100DN Laser Printer - FS2100DN
Hp photosmart C170 printer is giving out of paper error, it is not out of paper, what do I do?
Most likely the sensor in the back of the paper tray slot is damaged. You can try and find a replacement part or possibly a damaged printer that you can salvage that part off of. However, most of the time HP considers small inkjet printers to be "throw away" type and don't offer much in the way of parts or troubleshooting.
Mar 02, 2015 | HP LaserJet Office Equipment & Supplies
Error Number : 1003 No paper. Load the paper in the cassette correctly and press the OK button on the printer. Plain paper of A4, Letter, B5, and A5 sizes will be fed from the cassette because...
Another possible reason for getting this error is a dusty printer. I don't dust very often so dust piles on everything, including my printer. My daughter wanted me to print something for her and the first page went through just fine. But the second never started and I got error 1003. I had plenty of paper loaded and my settings for the size of paper were correct. I dusted out my printer and everything else printed just fine. My theory is the top paper had dust bunnies on it that were pulled into the printer when it pulled the first page in. Maybe the dust got caught on a sensor that told the computer there wasn't any paper. Regardless of what happened, a quick cleaning fixed the problem. I just wanted to throw in my two cents for anyone out there that may have a dusty printer and run into this error.
Sep 08, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Uneven paper load. error 5100
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Oct 01, 2009 | Canon PIXMA MP810 All-In-One InkJet...
Mpf error
MPF is refering to Manual Paper Feed or bypass tray. This tray should fold down to enable loading of paper. It is mostlikely above tray 1.
Sep 15, 2009 | Laser 3115cn All-In-One Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Printer will not feed/accept paper.
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
May 25, 2008 | Epson Stylus C48 InkJet Printer
General error - see your printer Documentation for information about clearing the error.
I solved the problem .. during the ignition printer I inserted a sheet of paper in the printer (side cartridge) while the rollers running. the printer has expelled the sheet and the problem is solved
Apr 09, 2008 | Epson Stylus Photo 925 InkJet Printer
Canon imagePROGRAF W8400 InkJet Printer Logo
124 people viewed this question
old marine
old marine
