Question about Panasonic PT-47WX42 47" Rear Projection Television
The colors are not alined
The green yellow and red colors are no alined on the tv how can I get them back in alinement
  • Panasonic Master
  • 8,617 Answers
Posted on Feb 27, 2009
Cant aline green bulb using convergence menu
There are two or three convergence modules in the TV that have to be replaced. They solder to the circuit board. You can get these parts at shopjimmy's web site if you feel you can fix it yourself. Otherwise prepare to spend $400 plus parts to have a shop do it.
Nov 19, 2014 | JVC Av-56wp30 Iart Pro 56" Widescreen...
How to fix the color alinements
You need to replace the two STK-392-560 CHIPS THIS SET USES AND DO NOT RUN THE SET WITH CONVERGENCE BOWED or soon you will have other parts bad.
May 27, 2012 | Sony KP-57HW40 57" Rear Projection...
Jvc manual
Well there is no yellow, there is only red, blue and green, Blue is the set line the other 2 need to be aligned to. If blue is bent or out of alignment then there is a problem with some internal chips that would require a good deal of soldering skill
Jan 03, 2012 | JVC AV-48WP30 48" Rear Projection...
Screen is red and I cannot adjust it enough to get the red out
Problem is going to be in the Green and Blue Tube ,you need to change the Coolant Fuild out and out in New,Philips is well known for having Bad Coolant fuild in the G/B Tubes.
With Back Off and TV on Look down inside of each Tube you should be able to see a Clear picture, in each Tube, If you do Not then you need to change out the coolant fuild.
You also have a Screen/Focus Control Block, it controls the Screen Drive and Focus to Each Tube R/G/B 3 controls on top and 3 below them. Top 3 should be for Focuse and Bottom 3 Screen Drive /Brightness to each Tube.
Now in order to aline for Correct Color you will need to adjust all 3 Tubes , Turn Color OFF in Menu then aline the Tubes untill you have a Black and white Picture ,Then go back to menu and turn Color on.
Mar 01, 2011 | Philips 51PW9303 51" Rear Projection...
How do i re aline my projection Hitachi TV out of the 6 x 5 are out of line how do I fix it
I'm not sure what you mean by: "out of the 6 x 5 are out of line"
If you are referring to aligning the colors on the screen, the settings you are looking for are called "Convergence". There will usually be a red, blue, and green cross you will have to line up perfectly. the green is usually not moveable.
May 16, 2010 | Hitachi 61SWX12B 61" Rear Projection...
After moving, tv picture has green overtones that will not go away with tint and color adjustments. Any ideas?
YOUR GUNS NEED RE-ALINEMENT{RED,BLUE AND GREEN LIGHTS}DEPENDINIG ON HOW OLD IT IS WILL HAVE TO HAVE MORE LIQUID PUT IN THE GUNS.A TECH HAS TO DO IT,NOT CHEAP.
Apr 24, 2010 | Televison & Video
My zenith projection tv model R49W36 wont aline the colors green,red and blue
Its a convergence problem. You can get complete parts and instructiosn for this fix from www.TvRepairKits.com. They put together a kit for this. I used them for a convergence problem recently and they helped me fix my set.
Dec 22, 2009 | Zenith R49W36 49" Rear Projection HDTV
Alinement of blue cross with red and yellow.
you will need to call someone in to realign the picture...
Feb 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
HP880c missing colors
you need to go to preferences and adjust the new cartridges, aline, clean, etc.
Jan 06, 2008 | Office Equipment & Supplies
Rca home theatre big screen tv
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
Aug 07, 2007 | RCA 32V420T 32" TV
Panasonic PT-47WX42 47" Rear Projection Television Logo
161 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
