Question about Canon ImageClass D880 Copier
Paper jam that I cant get at
I have a Canon Imageclass D880 copier with a jam I cant get at. It has a whole sheet of paper in it with nothing on either end sticking out to get at. I can not figure what I could take apart to get at it the usual steps dont work.
  • Anonymous Feb 25, 2009
    I have a Cannon Image Class D760 with a paper jam where copy comes out. I am not able to acces the jam from the front or from the inside (after you move the toner cartridge). There's only a small piece of the paper sticking out, not enough to grab.
    Scholar:
  • 62 Answers
The paper must be jammed in the fixing assembly.
you are gonna have to remove some screws to remove the plastic covers. once you took them off proceed to unscrew what ever needed in order to free the fixing assembly, which is the one located in the upper back part of your copier. once you released the fixing assembly release the springs and remove the metal stoppers. now you should be able to remove the paper jam. good luck!
Posted on Jan 28, 2009
Can i use cardstock paper in my canon imageclass d880?
There maybe an adjustment on the rollers for different types of paper grades. If so adjust it for heavier paper weight.
Mar 02, 2012 | Canon imageCLASS D880 All-In-One Laser...
Paper jam internal, can't access. accordian at exit tray
more the likely it is in the fuser unit of the copier .
May 04, 2010 | Canon ImageClass D880 Copier
Paper jam in canon d880, Have tried every way to get paper out, but can't. Need to know what to do?
Make sure to blow off the optical device near the print head.
It may not have a paper jam at all.
Apr 07, 2010 | Canon imageCLASS D880 All-In-One Laser...
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in front roller of imageclass D880 (about 1/3 inside)
dirty pick up rollers. take the paper tray out and them you will see 2 half moon rollers, clean them with alcaho and you will be ok.
Oct 08, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
Cannon d880
Sounds as though some how you fixing assemby has been damaged and would need to be replaced.
Apr 21, 2008 | Canon ImageClass D880 Copier
Canon Imageclass D880 all-in-one
The area you are describing is the fuser exit rollers. Most likely the upper and lower rollers are worn out and the paper jammed there. You will need a technician with the background on repairing this machine to fix it. This is a major repair.
Jul 27, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon ImageClass D880 Copier Logo
205 people viewed this question
old marine
old marine
