Question about Car Audio & Video
Manual for TM4000 Car Radio
As fitten in Toyota Previa
  • 3 Answers
SOURCE: 1992 Toyota Previa van,Oil dripping onto exhaust manifold, replace head gasket? need a free manual!
The toyota previa uses a formed silicone gasket for the valve cover and the cover is held in place by metric shoulder bolts ( 10mm). The valve gasket leaks because you can't get enough preload on the bolts to re-seat the old gasket when it gets old and shrinks. The shoulder bolts only allow you to tighten the gasket enough to seat the shoulder on the bolt. If you continue to torque down the suspected bolts, you will snap the bolt off ( don't ask me how I know this ). You can either 1.)replace the old gasket with a new one or 2.) remove the existing bolts around the leak area and put in new metric bolts that do not have a shoulder. You may want to put in a small sleeve into the existing bolt hole but shorter than the thickness of the valve cover to account for the smaller diameter bolt. You can now torque down the bolt and get enough preload to seal the valve cover without removing the old gasket. Make sure you use a torque wrench ( in-lbs) or be very careful not to snap these small valve cover bolts.
Posted on Jul 15, 2009
Garagetuner1
SOURCE: 91 Toyota Previa AWD - Swap original engine for Previa Supercharged engine
I do a lot of work on Toyota Previa before; including rebuilt engine, swapping engine and transmission and lot of things in between, but never swap a normal aspirated engine to a supercharged engine or diesel. Since i have some experience in Previa, I would like to share my opinion with you regarding your plan to swapping the normal aspirated Previa engine to a Supercharged engine. When you do a swapp like that, you will not only be dealing with just swapping engine, but some wiring, computer, throttle body, air cleaner assembly, extra frame and pulley on the accessory items, transmission as well as a right rear end to get the correct gear ratio to accomodate the new engine and transmission. I can go on even more, but let me tell you this, beside less headache, it would definitely cheaper if you were to find a Supercharged Previa and fix it up. However, if you are totally motivated to do this project, keep in mind, this engine swap will be a long term and time consuming project.l I wish you best of luck and have fun!
Posted on Jan 17, 2010
hfmiles
  • 1165 Answers
SOURCE: TOYOTA PREVIA 1991 2400 CC THE SIGN OF OPEN DOOR
The door afar sensors are located in the door latches. Try spraying all the door latches with wd40 penetrating oil and see if that helps.
Posted on Jan 09, 2011
  • 31 Answers
SOURCE: I'm looking for a Manual for a Toyota Previa 2.4
Try looking looking at your local auto parts store
Posted on Jun 24, 2011
preriinte
  • 3 Answers
SOURCE: I need the repair manual for Toyota Previa
You can download very easy the service manual for toyota previa. Recommend this website, is 100% safe.
Posted on Jan 06, 2014
Toyota previa no power to radio 2003 165184
Check the fuse, there might be more than one for your radio so double check in the owners manual under fuses and the diagram will give you the fuses associated with your radio.
Dec 31, 2014 | Toyota Cars & Trucks
Jan 06, 2014 | Toyota Previa Cars & Trucks
Wheres the radiator and fuse box?
what radiator, there are many.
cab heater, engine RAD, tranny, A/C what?
the glove box, open it and remove the oper. guide, lost that , get one for best safety.
fuse box, there are 2, one (LHD car) at left ankle
and one in engine bay. LHD = left hand drive,
even causal looking finds both, do look.
best, violet, is to post symptoms... or are you just curious?
the crummy haynes
http://www.ebay.com/itm/Haynes-Toyota-Previa-1991-1995-Auto-Repair-Manual-/380500687864?pt=US_Texbook_Education&hash=item58979bbbf8
the book lost, oper guide
i use fleabay, put a watch on this search, then wait from one to pop up.....
http://www.ebay.com/sch/i.html?_odkw=Toyota+Previa+operators+guide+1995&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.XToyota+Previa++manual+1995&_nkw=Toyota+Previa++manual+1995&_sacat=0
Dec 19, 2013 | 1995 Toyota Previa
1991 toyota previa radio has no power
You missed something or you blew out a fuse.
Aug 29, 2012 | 1991 Toyota Previa
Jun 24, 2011 | 1996 Toyota Previa
Where is the engine oil stick?
The Toyota Previa is a popular car that holds its value well. It is a rare "mid-engine" car which presents some unique problems when doing basic maintenance like checking the oil. Go here for step buy step instructions:
http://www.ehow.com/how_4540025_check-oil-toyota-previa.html#ixzz1H5JrQBL3
Mar 19, 2011 | 1991 Toyota Previa
I have a 1995 Toyota Previa. The lights on the dash for the radio/cd player stay on, even when the car is off, draining the battery. I took the fuse for the radio out, it is still on. How can I...
if the lights on the dash are also lit. The problem is not with the radio it is with the multifunction switch Turn/light switch try to remove the fuse for the dash lights
Nov 30, 2010 | 1995 Toyota Previa
WHERE IS THE FUSE BOX IN A 1996 TOYOTA PREVIA?
... ALMOST all cars. In the Previa, it's in the top center of the dashboard just above the radio. If you look closely, there is a little tab above the radio that lifts upward and allows the fusebox cover to lift up, revealing the fusebox. Weird place, but actually quite handy.
Jan 04, 2010 | 1996 Toyota Previa
Where is the fuse for the rear wiper in toyota previa 1993
I believe its location is printed on the underside of the fusebox cover. If you haven't found the Previa fusebox, it's in the center of the dashboard just above the radio.
Dec 28, 2009 | 1993 Toyota Previa
Toyota Previa 1993 AM-FM Cassette Unit Model 11709
Send me the code for the radio, I have all of the unlock codes.
Jun 29, 2008 | 1993 Toyota Previa
Car Audio & Video Logo
113 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
