I have 2 Advueu 19" LCD Under warranty which needs repair.What do I do?
  • 55 Answers
You will need to get out your warrenty info and call the Phone Numbers of the service center. they can help you with the rest of the rest good luck
Posted on Jan 27, 2009
Hello i have a monitor LCD ADVUEU model MW19E-BBM. I need drivers Can yo help me please
if this is a windows pc, the drivers for the monitor will automatically install. If you notice the screen and icons are very large, you probably need to install display device drivers. For more info post your system make and model & I will try to help.
Aug 31, 2011 | Advueu Technology ADV178T 17" Flat Panel...
Does not turn on
most of the time the issues with these are bad capacitors. if you can solider, you can replace all of the electrolytic capacitors. Or any electronic repair shop can do it for you.
Aug 15, 2009 | Advueu Technology AMW-F196B
Two Advueu flat screen monitors need service every 6 months or so
I have never owned one but when you list out monitors with the same specs Advueu always comes up as one of the least expensive.
Although there are exceptions, the lower price will almost always indicate a lack of quality. Given your experience it is safe to say that your monitor is no exception to this rule.
I have had excellent luck with the following LCD manufacturers: Samsung, LG, Dell, HP/Compaq, IBM, NEC and Mitsubishi.
IMHO: The best vendors are NewEgg.com, TigerDirect.com and the Dell Outlet. Online prices are way lower than store prices.
Aug 08, 2009 | Microsoft Advueu Lcd 19W 190Wdt Bk Slv 5Ms...
The screen is black but if you look hard you can see the background very lightly
Hi, your monitor's backlight is burned out or malfunctioning. The LCD monitor consists of two major parts - the LCD panel where images are created, and the backlight which forces light to pass through the LCD panel so you can see things. Your backlight is out. Viewsonic has great warranty support and service. You should contact them, provide them with the serial number, and they'll probably repair it under warranty for you. This is a hardware malfunction, so it needs to be repaired.
May 15, 2009 | ViewSonic VA1912w 19" LCD Monitor
Lcd screen white when turned off
The Backlight is not turning off. Try a hard reset, unplug the tv for several hours. If the reset does not correct the problem you will need the Power Supply replaced. If the unit is still under warranty you will need to return to the merchant or send to manufacturer for repair. If I can assist further please let me know. Lone99star
Feb 24, 2009 | Westinghouse LTV-19W3 19 in. LCD...
Comes on for a couple of sec's then dies.
yes your monitor comes with a 1 year limited warranty
http://www.proview.net/Support/Warranty.aspx
You will need to contact their customer support to open an RMA request and have it sent it for repair / replacement.
Nov 20, 2008 | Proview PL926WBi 19" LCD Monitor
T.v.wont turn on still under factory warranty
99% sure it's going to be your power supply. If it's under warranty then by all means use it - if not, try another power supply or get your old one repaired. Most of the time it's a 1000mF@25v capacitor in the P/S that goes bad.
Jun 18, 2008 | Proscan 19LA25Q 19 in. LCD Television
AMW F199B 19 Inch LCD Monitor - No Red
I just changed PC and and I have a "AMW F199B" monitor that will not produce sounds now. I do not have any of the original software for the monitor. What do I do?
Thanks
Jun 14, 2008 | Advueu Technology AMW-F196B
Black Line Across Screen
It's almost certainly a bad connection inside where the mylar strips attach to the LCD. If this is under warranty, you should contact Gateway. If it's out of warranty, it's not economical to repair this problem. It would require a whole new LCD panel, and - believe it or not - that part's cost usually exceeds the price of the monitor!
Jan 07, 2007 | Gateway FPD1975 19" LCD Monitor
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
