Question about Cobra iRadar IRAD 200
Iradar did not pick up laser - Cobra iRadar IRAD 200
Want to register product
The hard part was that you found this site to ask the question.
If you searched the internet for your product, you will easily find the manufacturers website
Product registration is in there.
https://www.cobra.com/support/product-registration
Sep 05, 2015 | Electronics iRAD 950 iRadar ATOM Radar...
Driving down the road there was a gatso van (speed detection van) with its camra facing my car I had my snooper cobra iradar connected this particular detector is fitted outside the car behind the front...
we have moved on past the use of radar type sensors most now use a above visual spectrum lasers or a type of red shift although some departments still use radar its now in a Trent digital type system that scanners can't pick up anymore because the frequency at which the radar has changed 3 time since 1995 in the USA
Sep 14, 2013 | Video Cameras
Police pointed laser at me on freeway and 7100 did not detect
the laser receiver on these are really horrible it usually only picks up the laser if its fired directly near the unit but most cops fire the laser at the front grill or rear of the back of the car and the model you are using is a low end model so the field of view for picking up the laser is really small. most rader/laser detectors that are dash mounted dont usually pick up the laser signal. and when they do its usually as soon as you pass the source of the laser
May 07, 2011 | 9-Band Radar/Laser Detector
It stopped playin cds and dvds
You can try a laser lens pick up cleaner kit - it might be dirty and not picking up.. If that does not work it is most likely the laser pick went bad.. It happens often..
Good luck ;)
Oct 07, 2010 | Pyle PLCD70MUBT CD Player
What does th uniden laser superwideband stalker do?
it picks up laser from a wider band , so even some of the newer police lasers can be picked up. keeps you from having to buy a radar detector every year.
Jan 24, 2010 | Uniden Radio Communications
Lee playstaytion two
Hi Lee,
Your lasers on the way out.
it,s all to do with the power output of the laser head, and the angle for reading the 2 different disk types.
i,d suggest getting a new laser fitted. not too expensive usually with older consoles. Try E-Bay :)
Mike @ Compurepair.
Feb 18, 2008 | Sony PlayStation 2 (PS2) Console
Dvd player
To test the laser pick-up, push the lid swith down to simulate to unit it is closed. Turn unit on to see if the pick-up goes to the middle, tries to focus and the laser can be seen on the lens. If the laser is not present during this operation, bad pick-up. Replace entire unit due to replacement cost of pick-up vs new unit. If it is 70% cost of part vs the new unit, I would opt for a new one. If you are not familiar with a repair of this nature, please do not try. There are more adjustments than just a new pick-up.
Jun 23, 2007 | Durabrand DUR7 Portable DVD Player
Change optical pick up, but still can not read the disk
you may not have adjusted the laser correctly. if you actually did place the laser in without damaging it, then what you need to do is adjust it so that it picks up the Game.
Apr 15, 2007 | Sony PlayStation 2 (PS2) Console
Cobra iRadar IRAD 200 Logo
Top Cobra Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Cobra Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
