Question about Exercise & Fitness
Next nx studio rowing machine
Require manual
How should the first stich in each row be knitted. I.e opposite of what the pattern calls for or pulled off Thank you.
The first stitch of the row is usually the chain that you ended in the last row. The chain essentially builds the height of the pattern to the next row so the stitches are even height from beginning to end. After you have made the chain, then begin with the first stitch in the next row pattern.
So, if the pattern says to knit 3 (or purl 3), that 3 stitches allows the height for the next row.
Jul 19, 2017 | Sewing Machines
Can the operation beep be switched off on the brother NX 400 sewing machine
Most machines have sounds that cannot be turned off. You can probably try contacting Brother support.
https://www.manualguru.com/brother/nx-400/owners-manual
Nov 22, 2016 | Brother NX-400
Manual for PennCrest P1
Nancy, if you ever give up on your machine, would you consider parting with the cord and foot pedal assembly? - I just picked up a cute machine at a thrift store. Looks like the previous owner's puppy chewed on the plug. It still works, but for how long or how safely is the question. Thank you!
Feb 08, 2014 | Brother NX-400
How do I manually eject cd tray of dell studio 1558? Eject button doesn't work. Thanks.
Here is the Dell service manual page where it shows the disassembling of the Dell 1558.
You will have to remove the DVD module to eject the DVD
Procedural steps are on this page site.
http://support.dell.com/support/edocs/systems/studio1558/en/index.htm
Oct 05, 2010 | Dell Studio 15 Laptop
I cannot find the num lock on my dell studio laptop...can you help?
Normally the num lock is marked as num Lk which is placed next to the F12 keys in the top row.
So check this out ..... This is so in my Dell vostro
Sep 27, 2010 | Dell Studio 15 Laptop
Manual required for a BT Studio 4500 phone
Go to the following site to download the manual.
www.user-guides.co.uk/.../bt/btstudio/bt-studio-4500-user-manual.html
Regards
Alan Hood
ami-man
UK
May 14, 2010 | Lands Phones
We have a La Cimbala M2 barsytem that indicates press cleaning button, where is it?
The top left button on the 2nd row of smaller buttons. It has a filled cup as an icon. press and hold until screen says 'short wash' or group wash. There is also a full cycle washing that is required some time during the day usually at night or start of a work shift. This requires the opening of the 'de-cafe' or pill drop chute. It's a small black slide about the size of a pack of gum. open it and drop a cleaning pill then close it. the panel buttons will blink and the screen will say press cleaning button. press and hold the wash button (as previously mentioned) till the cycle starts to clean. Release button and allow 8 mins for the cycle to complete. This will keep the 'clean cycle' clear until the next shift or next day when it needs to be done again. These instructions should be in your manual that came with the machine.
Sep 27, 2009 | Espresso RMI La Cimbali Espresso Machine
Slack in line on rowing machine
extend the line to its max required length while you are sitting on the machine { as using } then get someone else to adjust the slack on the line and make it taught , the adjustment should be a bolt and nut type located on the main wheel . do not adjust the line from the seat as this may dislodge the seat . happy rowing
May 06, 2009 | Kettler Coach Rowing Machine
Lifecam nx-6000 interference
this the spec from microsoft for the nx-6000
it is not for 64-bit machine. it is fir 32-bits machine, color depth is 16.
Requires a PC that meets the requirements for and has installed one of these operating systems: • Microsoft Windows Vista or Windows XP with Service Pack 2 • Intel Pentium® III 700 MHz (Intel Pentium 4 2.4 GHz recommended) • 256 MB RAM (256 MB RAM recommended) • 300-700 MB hard drive space • Display adapter capable of 16-bit color depth or higher • 2 MB or higher video memory • Windows-compatible speakers or headphones • USB 1.1 (USB 2.0 recommended). USB port 2.0 required for 1.3 MP and above video capture resolution. System without USB 2.0 may achieve 800 x 600 pixel resolution • CD-ROM drive • Broadband internet access required; access fees may apply • Microsoft LifeCam software, version 1.3 Internet functions (post to Windows Live™ Spaces, send in e-mail, video calls), also require: Internet Explorer 6/7 browser software required for installation; 25 MB hard drive space typically required (users can maintain other default Web browsers after installation) The Microsoft LifeCam NX-6000 has basic Video & Audio Functionality with Windows Live Messenger, AOL® Instant Messenger™, Yahoo!® Messenger, Skype, and Microsoft Office Communicator
hope that helps!
please do no tforeget to rate this!!!!!!!!!!! thanks
Oct 14, 2008 | Microsoft LifeCam NX-6000 Webcam
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
