Question about Dewalt 18 Volt Compact Drill Kit
12v dewalt slow speed?
Speed problem
  • David Ford
    David Ford May 11, 2010
    Can you be more specific, is the trigger the problem or the gearing?
    Problem Solver:
  • 15 Answers
Problems could include cold battery, worn out battery, or something has gotten into the mechanism such as sawdust. You also might check contacts to be sure they are clean and bright.
Posted on Jan 28, 2009
I changed brushes in dewalt impact drill ,now it slow is there anything I can do,
The switch is about the only thing that controls the speed of the tool.
If you post the model number I can get you the correct part#
Oct 07, 2016 | Dewalt Drills
Can I power a small appliance with my dewalt
This is what dewalt is saying...The Dewalt 12V/20V MAX work-site charger/radio functions as an AM/FM radio and recharges your 12V/20V Dewalt batteries (batteries not included). The 3-stage charger can recharge your batteries in as little as 1 hour, and the radio can run off 12V/20V batteries for cordless operation
  • 2 AC power outlets offer more versatility for jobsite power
  • Auxillary & USB ports allows for connection to CD, MP3, portable satellite receivers, and other digital audio devices.
  • USB port allows device to be charged via USB when radio is plugged into a wall outlet
  • Class D amplifier, woofers and tweeters provide full range of high and low sound for optimum sound quality,( hope this helps)
Aug 06, 2014 | Dewalt DCR015 MP3 AUX USB 12V/20V MAX*...
How long should i charge my 12v Batttery? Dewalt
generally 1 hour and there are indicator lights on the charger to notify you when charging is complete.
Jun 21, 2011 | Dewalt Drills
I replaced the blade in the dewalt DW716 mitre, now the blade spins slow and trips my breaker??
Hello, W/D here.
Remove your new blade. With the hardware, bolt, washer,blade and cups off, try the saw. If it operates correctly, re-examine how the blade is installed One blade cup goes on, followed by the blade, then the other cup, followed by the washer and bolt assembly. If the cups were in the wrong order, the blade can drag against the frame of the saw, pulling too many amps, and tripping the breaker.
Here is a link to DeWalt. Enter your model # for manual download and exploded diagrams.
http://servicenet.dewalt.com/
Best regards, --W/D--
Feb 07, 2011 | Dewalt DW716 15 Amp 12Inch DoubleBevel...
Dewalt cordless 12v drill, 3speed model...spinning problem
Sounds like your brushes are either damaged or the armature is failing the current. Remove the brushes first and inspect them, that is where your arcing is coming from. If the brushes appear ok, your problem is in the armature itself. Regardless of low use, if you store the unit with the battery attached, there are issues with the current draw while stored.
Jan 17, 2010 | Garden
My 12v dewalt drill runs like its running low on power even with a fresh battery in it.help!
The problem I have seen is the trigger. I know it's a pain, but that was the the problem with mine......The trigger has an integrated regulator and Rheostat that controls speed and voltage and when she goes,...........That's it! Sorry.....
Dr. Phil
Jan 11, 2010 | Dewalt 18 Volt Compact Drill Kit
DeWalt DW972 cordless drill has intermittent variable speed trigger. (Battery is fine, recently replaced) How can I clean the variable resistor in the trigger or must replace the whole trigger module?
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Dec 14, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Strange wurring sound and slight vibration at full speed Dewalt sds hammer drill dw25003.
On most sds drills the movement of the beat piece inside the piston cause then to vibrate, even at slow speed, this is normal, the most speed the louder the noise and vibration., note: is not a grinding noise, it should be a smooth nocking constant sound, as so the vibration.
Aug 07, 2009 | Dewalt Drills
Dewalt 12v Cordless Drill. Same speed in position 1 or 2 ???
yep and with this model you are not alone! take it back and exchange it make sure it works before you leab]ve the shop
Jun 23, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
70 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
