Question about Panasonic SC-AK100 CD Shelf System
Panasonic SA-AK100 CD Player will not load. Accidently put two CDs in tray, grasped drawer to prevent closing, now tray will not close, nor will accept CDs. Please advise. Thank you.
3 Suggested Answers
Kimi
  • 277 Answers
SOURCE: Does not play CDs
If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. If it wont help and you're NOT still under warranty you should at least open the system and look for Problems with the door opening/closing: Steps: 1. Make sure the drawer-loading belt is still tight and elastic. If not, it can be replaced with a belt obtained from an electronic-parts supplier. The replacement should be of equal or slightly greater thickness and should fit snugly but not so tightly that it strains the motor. 2. Check for broken or loose gears and have them replaced. 3. Check for obvious sources of contamination such as pet hair or foreign objects that are preventing smooth operation of moving parts. Small children have a habit of inserting items into CD players. 4. Use electronics-grade contact cleaner to clean the door-position contacts.
Posted on Jan 15, 2006
SOURCE: cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
Posted on Apr 09, 2011
Panasonic sa ak27 stuck in cd mode and cd drawer will not open
Unplug the unit then check to see if there is a small hole (1/16") on the front panel of the player near the open/close button. If so straighten a paper clip and press into the hole to open the drawer manually.
Jan 06, 2018 | Panasonic Televison & Video
How do I fix drawer on Azur 640 CD player?
Might be as simple as cleaning the lens
Aug 07, 2016 | Audio Players & Recorders
I have a panasonic sa ak15 stereo system, the five cd trays have cds in them, i pressed the cd open button but cds don`t come out, the system screen says change, what could be the problem?
The door loader motor isn't working. Sometimes the plastic tray warps and hangs a bit. Mine still hangs, but I can give it a push to close. If you can see the door trying to open you can help it open but you have to be quick or you have to press the open button more that once.
Feb 24, 2015 | Panasonic Audio Players & Recorders
Home theatre (panasonic SA-PT460) drive wont open makes some noise when i press the open/close button as its closing. I unscrewed the device and removed the dvd tray from its case as i pressed the...
I also have a problem with the drawer. It opens when I switch the unit on and when I close it - it opens again!
If I switch off at the mains the drawer remains open - to prevent dust ingress I have resolved to holding the drawer in whilst shutting down the power until I get a solution.
If anyone has a solution I would be grateful.
Sep 08, 2011 | Panasonic SA-PT460
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
Panasonic cd stereo system sa-ak100
my remote control don't work. I thank it's the remote control signal sensor. what should I do.
Jun 20, 2009 | Panasonic SC-AK100 CD Shelf System
Cd changer loading problem (panasonic sa-pm53)
May 24, 2009 | Panasonic SC-AK78 CD Shelf System
Loading tray will not load or close-reopens immediately
Sounds like the tray position switch has gone wrong.
Sep 30, 2007 | Onkyo DX-C340 CD Player
Does not play CDs. After closing, tray immediately opens again and displays "Take CD out". Cycles through trays and gets stuck.
Jan 13, 2006 | Panasonic SC-AK600 CD Shelf System
Panasonic SC-AK100 CD Shelf System Logo
337 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
