Question about Homelite Garden
How can i get a homelite 4218c carburetor adjustment tool
  • 211 Answers
SOURCE: need adjustment tool for carburetor - where can find this
Hi
You can try to buy it from a shop where are Poulan chain saw for sale but I am not sure they do.
best rebards savumihai71
Posted on Dec 08, 2008
SOURCE: need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Posted on Feb 06, 2009
dontbother10
  • 2220 Answers
SOURCE: I need a carburetor adjusting screwdriver for a
eBay. Walbro tools.
Lou
Posted on Jan 24, 2010
  • 4088 Answers
SOURCE: How to remove plastic limiter cap on (H) carburetor adjustment
If plastic cap is present, it should just pop off with a thin sharp hook. Look carefully at the screw heads--they may be 'D' heads which require a special screwdriver and are supposed to keep owners from moving the screws (thank the EPA for these). Only authorized saw servicing dealers have access to these tools and therefore are the only folks allowed to adjust these saws. Being nonconformist, I made my own by drilling the center of a 1/4" rod, sawed off one side somewhat and welded a flat across the cut. Hope this helps!
Posted on May 11, 2010
  • 4088 Answers
SOURCE: carburetor tool
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
Posted on Jul 07, 2010
Weedeater will idol but won't run - it will cut off when you try to give it gas
To begin with, let's start with the basics.
  1. Are you using fresh gas? If not, you need to get some. If there is any old gas/oil mixture in the machine, remove it by pouring it into some sort of container.
  2. If want to purchase a gas/oil mixture already mixed, a store like Home Depot or Lowes has quart cans at the correct mixures. 50:1 / 40:1 etc. and it's Leaded gasoline usually 91 octane.
Weedeaters will lose their carburetor adjustment over time because of vibration or the fuel mixtures may change. The carburetor settings are crucial for the machine to run properly.
Not all carburetors are the same, but which ever one you have, you will need a special adjusting tool to do this. You can find adjusting sets locally or here. https://www.amazon.com/HIPA-Carburetor-Adjustment-Including-21-Teeth/dp/B01FAAKN7E/ref=sr_1_3?ie=UTF8&qid=1467833656&sr=8-3&keywords=carburetor+adjusting+tool
Not To do this process, you will need to identify the 2 special
adjusting screws on the top or side of the carburetor.
The screws are highlighted as HI and LO. The HI allows fuel adjustment for the weedeater at full throttle. The LO is for the adjusting the idle.
Try these steps:
1. Adjust both screws clockwise until just seated (tight) using the correct tool (from a set similar to the one above)
2. Rotate the HI screw 1 1/2 turns counter-clockwise
3. Rotate the LO screw 1 turn counter-clockwise
4. Start the machine.
5. When it's running (spitting, coughing...) adjust the LO screw a 1/4 turn either way until you get a smooth idle.
6. Pull handle to run at full throttle. If the engine is sputtering then it's getting too much fuel....adjust the HI 1/4 turn clockwise checking to see if the engine runs smoother.
7. When you get the weedeater running smoothly, there are no further adjustments to be made. Just make sure you are using FRESH gas/oil that hasn't been sitting longer than 30 days.
Good Luck!
Once j
Jul 06, 2016 | Garden
Is there a special tool to adjust the Hi Low fuel mixture on a mc culloch t55 hedge trimmer
Anon, you may need a special type screw drive bit. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Lifetime Warranty 2 Cycle Carburetor Adjustment Tool 4 Piece...
carburetor tool
Adjusting weed eater carb without special tool
Carburetor Adjusting Tool eBay
May 25, 2016 | Garden
Need tool for adjusting air fuel ratio for husqvarna 235 chain saw
It should be a spline tool. It is the most common one.
Genuine Poulan Weedeater Part 530035560 Carb Adjusting Tool
If you work a lot 2 cycle trimmers and chainsaws you might buying the set of four adjustment tools.
2 Cycle Carburetor Adjustment Kit Includes 530035560
Nov 07, 2014 | Husqvarna Garden
Carburetor adjustment
turn till they seat then back out one turn to start then fine tune when running
Mar 14, 2014 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
What is carburetor setting on a2.3 chainsaw
There is no fixed carburetor setting on these engines, just two screws to adjust low-end and high-end operation. Special tool may be required, there are about a half-dozen screw head standards. Check eBay for tool. Get the engine to run and idle fast (idle adjust) so it doesn't stall, adjust low-end screw so that engine doesn't hesitate or sputter when accelerated. Adjust high-end screw to run fast and smooth on full throtle. Readjust idle to normal.
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My weedwacker starts but when i squeeze the throttle it dies out how do i adjust it
If you turn the L mixture screw counter-clockwise about 1/8 to 1/4 turn, it will improve the throttle up capability of the carburetor, providing the fuel pump diaphragm and metering-lever diaphragm in the carburetor are not dried up and worn out. They make a special tool for adjusting the screws in the carburetor. Sellers on Ebay have the tool. Of course you have to register as a member to buy. The tool is not readily available at small engine repair shops or hardware stores as the manufacturers don't want us to mess with the "lean" settings required per EPA emissions rules (esp. in California). If you don't use Ebay, there are other ways to "turn" those little splined mixture screws. I use wire plastic wire terminal connectors (ring type and splice-connecting type). I tap the ends of the wire connectors (not wire nuts, mind you) over the heads of the screws until tight and proceed from there. The wire connectors I use I think fit 22 gauge wire. If you take them out, cut slots in the heads so they can be turned with a conventional screwdriver. This is a very, very cheap alternative to buying a tool. Small, soft brass or aluminum tubing (found at hardware stores and big box stores) can also be forced down over the heads of the screws. I will include a link to the tools on Ebay and a link on how to adjust the carburetor using the 2 (L and H) adjusting needles.
Ebay Link: http://tinyurl.com/3yuybuf
Carburetor Link: http://www.zamacarb.com/tipspage.html
Dec 11, 2010 | Craftsman 25cc Gas Line Trimmer
Where do I find a carburetor adjustment tool? The
I used a Dremmel tool cut-off wheel and now have slotted screws. You don't have to remove the screws first. Remove the carb, tape it up to keep it clean, and grind the screws. The raised guard will also grind, which gives you a guide for adjustment.
Apr 05, 2010 | Craftsman Garden
What is the walbro chain saw carburetor adjustment for a
There is no set adjustment on any chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Sep 13, 2009 | Poulan Garden
Need adjustment tool for carburetor - where can find this
Hi
Dec 08, 2008 | Poulan Garden
Garden Logo
287 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
