Question about Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
I have a PT-AE900U with about 1200hrs on the lamp. It has worked perfectly until rcently (last 3 weeks).
Issue: Lamp will not start up and the projector shows blinking red light and lamp light.
Temporay resolution: I reseat the lamp (remove and reinstall) and the projector works fine for a day or two then the same issue happens. I have cleaned the air filter so I am sure it is not heat.
Ideas: Could it just be the lamp dying off?
Why does it work when I reseat? Is there a sensor etc in the projector?
Please help..
I am going to buy a new lamp soon I think. But I want to ensure it is not a projector issue.
Thanks in advance,
Kevin
  • 4 more comments
  • Keefa Feb 07, 2009
    I have the same issue, but I just replaced the lamp, so don't assume that will fix it.  The old lamp had 3000+ hours on it (and nearly three years of use) with no problems.  Replaced the lamp with a new one and that's when the problems started.  Same issue as boogaboo760.  Power comes on, On/Standby lamp flashes green then lamp light flashes red and projector goes to Standby.
  • snblitz Feb 08, 2009
    I just ran into the same problem. Original bulb with 1546 hours on it. It did the LAMP blinks red thing, but worked again the next day. Now it is permanently LAMP blinks red.
  • tlrorick Mar 19, 2009
    same problem, lamp eventually wouldn't turn back on. replaced the lamp - no light, just the red and green flashing lights on unit. Panasonic Tech Support didn't know what was wrong, so we took it to one of their repair shops.They thought it was the ballast, but that didn't work. It has been 3 weeks. They have contacted Panasonic - they now have 2 that won't work. I just spoke with Tech Support again and they will contact the repair shop.
  • boogaboo760 Apr 13, 2009
    Still having the same issues.
    As long as I reset the lamp, the project works just fine for a day or two. The lamp is strong and bright.
    Anyone get this fixed yet?
    Kevin
  • Anonymous May 05, 2009
    same thing..previous lamp worked for 3000 hrs. replaced it with new lamp.. and after 200ish hours.. found it started getting very slow to switch on, and now doesn't do anything.. just get the red led blinking saying problem with lamp. sometimes it does work when i switch it on and lamp seems to be in good shape...Don;t want to fork out 400euro to find out its not the lamp thats the problem...
  • elito00 May 11, 2010
    any progress on this ?
  • 93 Answers
Since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Posted on Feb 08, 2009
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
I have a Panasonic pt-ae900u projector that doesn't project an image. The lamp fires up but no light makes it past the LCD panels, no video or menu graphics, nothing...help would be appreciated
I have the exact same issue with my projector and was wondering if anybody has an idea what the problem/solution could be? Have checked all internal connections, wiring, etc. but nothing is physically wrong with it. Powers on and off with no issues; bulb is working but no light out of the lens. Please help!
Oct 14, 2010 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900E Projector not working???
I have this exact problem too, so anyone out there that can help it would be great!
Mar 03, 2010 | Panasonic PT-AE900U Multimedia Projector
Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Jul 24, 2009 | Panasonic PT-AE900U Multimedia Projector
Could be a heat sensor, fan bearing issue..have you listened to the fan speed etc, But I think more along the lines of the lamp needs replacing..each time you resit it is thinking ah a new lamp and then realises hey someone is fooling me and shuts down...this scenario is doing you a favour as typically if it blew and shattered the glass it will inevitablly scratch the mirror and lcd block... and if it does that you might as well toss it in the rubbish or sell on ebay for $50 ..
Regards Kevin Andreassend, ICE AV Technology Ltd www.iceav.co.nz iceavtech@gmail.com
Apr 03, 2009 | Panasonic PT-LB10VU Multimedia Projector
Panasonic PTAE 900U with new lamp and counter reset shut off
Reseat the lamp.  I had a similar problem.  Replaced the lamp and everything worked for about 3 hours.  Then, turned the projector off.  Next morning, when I turned it on, nothing.  Stanby/On light flashed green for a minute then the lamp light came on and the projector went into standby.
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
Panasonic pt ae900 wont fire up
First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
Let me know if this worked.
Dec 14, 2008 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900u no image
may i know now what is the age of your projector. have you done replacing the lamp of the unit before.
Lamp life varies by manufacturer and projector type. Lamp life also depends on the projector's environment: air flow, clean air, and also on the level of usage. Check the user's manual or specification pages for your projector to determine the exact lamp life.
Nov 04, 2008 | Panasonic PT-AE900U Multimedia Projector
PANASONIC LCD PROJECTOR MODEL # PT-AE900U
The manual says that it will do this as a reminder that it has ended the recommended lamp life (on mine PTAE900E this starts at 2700hrs and supposedly can blow from then until the max of 3000hrs)
sounds scary enough i guess but they put that 10minutes on/off thing in there to kinda force you to get it changed...
mine is at 2600 anyone know of a good place to get a new lamp in melbourne australia?
cheers dave
Jul 13, 2008 | Panasonic (ETLAE900) Projector Lamp for...
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
1,613 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
