Question about Samsung Televison & Video
Un46eh6000f Turns its self off and cannot be turned again ,it stays off for minutes at a time then turns on
ctf1800
  • 4402 Answers
SOURCE: tomtom 700 turns then turns its self off again
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Posted on Jan 22, 2008
SOURCE: Samsung HL-S5679W
I m having the same problem and will be calling my sales man tomorrow!
Posted on Feb 11, 2008
SOURCE: tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Posted on Oct 08, 2008
dsacco86
  • 1077 Answers
SOURCE: curtis lcdvd2223a powers on for a second then turns it's self off
Sounds like "Protection Mode". The TV automatically turns itself OFF when a part inside the TV has failed. This mode keep the other electronic parts from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searchingon the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 20, 2009
ur fortune
  • 85 Answers
SOURCE: Samsung SP50L6HD Tv turns it's self off. Time
sir it may happen if the auto off option is enabled and the timer is enabled........... check for this options if they r and enabled then disable that........... or give your tv to the service shop and check for any problems
I have philips model #42pf13704df7 when I turn it on it stays on couple second then it turns it self off, I have to turned on again and again until it finally stays on and sometimes it goes off again
I tried to find out if this is an LCD screen type or Plasma or DLP, but I couldn't find a straight answer. The only info I could find was several links all leading to your questions about the problem, which means you must have one or more of the models numbers wrong. Anyway, you have the symptoms of a DLP bulb going bad. _IF_ it is a DLP, then for sure that's your problem. The bulb is quitting. If it's a Plasma, then it's the beginning of the end for it; (the plasma display is getting ready to quit for good). If it is an LCD, then I've never heard of one doing that, so I don't have an answer; other than the power supply kicking out, but they usually quit for good pretty fast after the first couple of times. Sounds like a bad bulb in a DLP TV or a bad plasma display in a plasma TV.
Dec 31, 2014 | Philips Televison & Video
Tv won't turn on
These TVs have a self-check at turn-on, and will retry 3 x and then quit. Self-checks are like current overloads,voltages not present, IC communications not good, picture tubes not running. Can be anything without checking circuits.
May 02, 2010 | RCA HD52W58 52" TV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
My latitude d600 wont stay on u turn it on and it turns its self
remove any drive bays you may have on it such as the CD/DVD or floppy A drives one at a time and try to turn it on again after each item is pulled out. If the comptuer turns on, and stays on after one of them is pulled out, than that particular drive may need replacing. You will also want to check to seem if any of the cables that connect those drives got pinched or cut in anyway.
Aug 02, 2009 | Dell Latitude D600 Notebook
After 2 or 3 minutes tv turns off it self
CK capacitors 114,120,150 if any of them is puffed up on top it is bad so replace all 3 capacitors cp150 2200uf 16v other 2 are 220uf 35v resolder all pinns on FBT flyback Transfomer.
Feb 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Turns off / shuts down by it self
not sure if my last post was posted, but my unit has the same problem. It can randomly shut off after 2, 5 or 10 min. I have read somewhere, that it might be the fan on the back of the unit. still looking for solution....
Jul 30, 2008 | Panasonic CQ-C5310U CD Player
My RCA HDTV
see if your model has a convergence option on the menu under the setup.....mine does not so i had to pay to have mine repaired and now, a week later, the problem has returned.
Aug 31, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
143 people viewed this question
Jerry Greenberg
Jerry Greenberg
